10-25-2018, 11:48 AM | #1 |
955
Rep 765
Had to purchase a new engine oil cooler
Ok for you guys who are lowered like me I highly recommend getting something made to protect the engine cooler. Maybe IND can help?
It's right behind the front bumper, exposed and not protected and low as F. Not sure how safe this is in the first place having it exposed and as low as it is but I'm not an engineer. Stealer tried to charge me $2100 to swap to a new one but got them down to $1300. They can't even tell me if my engine needs to be replaced until they put in the new oil cooler and try to crank the engine. Btw from something puncturing my oil cooler to the engine shutting off and not even cranking anymore was 4 mins which is not a lot of time to find a safe place to pull over. |
10-25-2018, 11:53 AM | #2 |
19222
Rep 10,145
so let me confirm, you (and I) are lowered about 3/4th of an inch on the H&R's and because of the height you got damage? Or do you think this would have happened no matter what?
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
10-25-2018, 12:12 PM | #3 |
955
Rep 765
Not sure but I'm sure that 3/4" didn't help. Either way it needs a cover or plate there to keep that cooler safe.
10-25-2018, 12:18 PM | #4 |
2866
Rep 11,374
We have an oil cooler guard coming out for this very reason. Fall-line used iND's F90 for all of the R&D.
trackday96154.50 fatih.aloglu86.00 |
10-25-2018, 12:29 PM | #5 |
255
Rep 255
I'm sure most of us didn't realize the extent to which our oil coolers are exposed to road debris. Of course if you choose to lower your car, your risk is enhanced.
My question would be, can the cooler be protected without screwing up air flow? Edit: I see in the previous post something aftermarket, so that will be interesting. Last edited by TheRealBob; 10-25-2018 at 12:33 PM.. Reason: added text |
10-25-2018, 03:32 PM | #7 |
496
Rep 812
It really surprises me that after the issues with the f80, that they would do this again. That oil cooler is really exposed in that position under the car like that, with NO mesh in front of it. I understand they want increased cooling capacity but that is a bad design in my opinion.
Formally known as BMWM3NYC
10-25-2018, 03:48 PM | #8 | |
183
Rep 795
10-25-2018, 03:53 PM | #9 |
197
Rep 572
Was it not warrantied because you were lowered or is this not a warranty issue period?
I recall over on the E63 forum something similar happening although it was to the front cooler and it was not warrantied either. |
10-25-2018, 03:57 PM | #10 |
15
Rep 49
It looks like you hit some sort of rod or a branch....you can see where it wedged behind the cooler and pushed it out a bit. It’s not like the coils were pushed in, as you would expect when making contact with the road.
10-25-2018, 09:10 PM | #12 |
955
Rep 765
10-25-2018, 09:28 PM | #13 | |
12911
Rep 18,683
I think it can be a case against BMW and/or CalTrans maybe? The only way you are guaranteed safe against road debris is when you are driving a raised SUV. A few years back, my sister's one week old car got a gas tank punctured from road debris. And it was stock height. I told her to bring it to the city to get reimbursement, I am not sure whether she did or not.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com SPRING Sale!! 04/01 - 04/15 - Code: "SPRING2024" MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
10-25-2018, 09:43 PM | #14 |
12911
Rep 18,683
Second thought, more lower probably safer for the bottom oil cooler.
Since the debri will get caught on the bumper first. Better yet, if you have a front lip.
10-25-2018, 09:55 PM | #15 |
///M
6651
Rep 3,683
I won't have problem with that. Lol
Life is too short...enjoy your life
///M |
r33_RGSport12910.50 |
10-25-2018, 11:32 PM | #16 |
554
Rep 629
Man you have had some unfortunate problems with your m5, Quickburn. I hope this is the last of it! I feel your pain though. The same thing happened to my f80 and it required engine replacement, so I hope that isn't the case for you.
I just took redelivery of my f90 on Friday after completing eurodelivery last month. I was running some errands over the weekend and a huge tree branch fell on my car and dinged up the bumper and hood along with a bunch of scratches and broken plastic grill. Hadn't even driven 10 miles since having it stateside! I hope you get quick resolution!
Gone but not forgotten: '10 X5M, '14 550ix, '17 M3 zcp, '11 aw e90 M3 zcp, ?11 sg e90 M3, '17 X5M, 19 F90 M5
Current: ?13 e92 m3 ESS 585, 22 f95 x5m Comp, Track - '18 manual 991.2 GT3, Wife's family truckster - '20 Volvo XC90 T8 |
10-26-2018, 08:08 AM | #17 | |
3618
Rep 4,532
Vegas bet is you did not wipe a bearing in 4 minutes of drain out. Fingers crossed for you.
10-26-2018, 11:44 AM | #18 | |
///M
6651
Rep 3,683
Knowing where and how to drive makes a difference, beside it's nothing that can't be fixed. If I would be afraid of that, I would drive rusty pick up truck. Lol
///M |
10-26-2018, 01:59 PM | #19 | ||
955
Rep 765
btsmith47.00 r33_RGSport12910.50 |
10-26-2018, 02:03 PM | #20 |
30
Rep 100
Mate that sucks, hope it’s not too expensive. Do insurance cover things like that?
I’m now scared to drive mine. No way I could afford an engine replacement out of pocket. |
10-26-2018, 02:10 PM | #21 | |
47
Rep 49
Any oil pressure warning on the dash means stop and turn off the motor AS SOON AS POSSIBLE, traffic conditions be damned. I'd rather back up traffic for miles than have to pay for a new engine out of pocket. Sorry to hear about your troubles OP, this really sucks. |
10-26-2018, 02:12 PM | #22 | |
3618
Rep 4,532
I really hate that happened. |
