03-09-2018, 03:50 AM | #45 |
985
Rep 1,885
Unless you like pouring money down the toilet - keep ceramics off the track.
Ceramics for the street. BBK for the track. |
Tonymiabmw551.50 |
03-09-2018, 06:38 AM | #46 |
397
Rep 855
One note (and I know times are different now), I put 50k miles on my first E60 M5 (2008) over 3 years. The brakes were phenomenal and I even tracked it a half dozen times or so. I never even had to have a the pads replaced in 50k miles.
The steel brakes these days are VERY good. |
03-09-2018, 01:38 PM | #47 |
1716
Rep 1,909
Drives: 2023 M5C
I haven't seen anyone mention brake warping as a reason to go CCB. Anyone besides me run into this issue with their steel brakes?
03-09-2018, 01:48 PM | #48 |
751
Rep 1,857
03-09-2018, 02:04 PM | #49 |
552
Rep 2,633
This is why you never let the car sit after you get off the track or after going heavy braking. You are suppose to drive the car around the pit to allow them to cool. I've never seen anyone warp the stock steels.
03-09-2018, 07:09 PM | #50 |
292
Rep 605
So after all of the replies on this thread and doing some research, it would seem that CCB should last much longer than steel for daily driving with less dust, but may be suboptimal when cold and/or wet, and may make excess noise. However, it seems that if you track the car, the CCB rotors will wear out much more quickly than one would like, making them cost prohibitive for track use. So, I propose a solution, and would like some input on making it work.
Could one simply use the CCB for daily driving to reduce dust and their extended life, but for any track days, find a set of quality aftermarket steel rotors of the same dimensions and swap them and the pads, keeping the CCB calipers? Also, ine could just use this method when the CCB rotors wear out instead of paying to replace them? |
03-09-2018, 08:19 PM | #51 | |
3619
Rep 4,532
03-09-2018, 08:24 PM | #52 |
3619
Rep 4,532
"Both test cars were also fitted with optional carbon ceramic brakes, which are pointless on the road. Especially in autumn and winter, they rarely operate in the desired temperature window, and performance in the rain tends to be poorer than standard brakes, as low initial bite is typically followed by sudden and extreme deceleration. Chafing and squealing noises can also be an issue."
2018 M5 vs AMG Automobile Mag March 4. |
03-09-2018, 10:23 PM | #53 | |
595
Rep 824
03-09-2018, 10:41 PM | #54 | |
233
Rep 354
Drives: 335XI MPerformance edition
03-11-2018, 12:00 PM | #55 |
292
Rep 605
Yes, I know the rotor size is different from steel. Does anyone know the dimensions of the F90 carbon ceramic rotors, and if so, any high quality aftermarket steel rotors and pads that would match the CCB dimensions?
03-11-2018, 04:26 PM | #57 |
292
Rep 605
Thanks. How about the rear CCB rotors?
Now assuming I could find a quality 16" steel rotor, any thoughts on being able to find pads made for said steel rotors that will fit the CCB calipers? |
03-11-2018, 08:41 PM | #58 |
552
Rep 2,633
The rear 2 piston caliper looks the same as the steel on the f90. It was this way on the f10 as well. The f80 came with a completely different 4 pistons caliper the f10 and f90 is 2 piston. Which is why I always thought the CCBs on the f80 were a better deal for 8.5k. The steel rotors should fit the CCB on the f90.
03-20-2018, 10:50 PM | #61 |
292
Rep 605
I would really appreciate thoughts on this option, which are allegedly steel rotors and pads that fit the CCB calipers on the F10. Can anyone confirm that the F90 CCBs are the same specs?
http://www.racingbrake.com/RB-2pc-ro...-Ir-p/2472.htm |
03-20-2018, 11:14 PM | #62 |
49
Rep 51
I was doing a bit of research on CCB and what I found on the racing brake kit wasn't great. I think the F80 forums have quite a bit of data on them. I think the consensus was that if you were going to do heavy track use, then getting a track specific aftermarket brake upgrade was the way to go.
I plan to track my car but got CCB anyway. |
03-21-2018, 12:08 AM | #63 | |
751
Rep 1,857
03-21-2018, 06:11 AM | #64 |
1232
Rep 1,918
Drives: 22 M8C Coupe, 21 X5MC
Really depends on the manufacturer. I've never owned CCB on a BMW but have owned them on a Mclaren 570s and Audi R8.
Audi felt like normal brakes with none of the downsides mentioned here, McLaren's brakes were finicky. Some of the issues mentioned here I've experienced on ther Mclaren.
Previous
21 X5M MBB, 20 Evora GT, 20 C63S Coupe,19 X5 50i, 18 Giulia QV, 18 M5, 17 Evora 400, 18 LX570, 17 GT350,18 M4 Comp,17 R8 V10 ,17 M3 Comp,17 GT350,16 Escalade Plat ESV, 16 570S,16 911 GTS,15 M5, 15 LX570, 13 M5,13 Viper,14 Cayman S,13 M3,13 S4,10 RX8,12 A4,10 G37, 04 Mini Cooper S, 08 Scion TC, 06 Altima V6, 05 Altima, 01 Altima, 00 Altima, 94 Explorer, 92 Toyota Pickup, 98 Altima |
03-21-2018, 08:18 AM | #65 | |
Plenipotentiary
2614
Rep 3,046
03-21-2018, 09:17 AM | #66 |
292
Rep 605
Thanks. That's unfortunate. Hopefully there will eventually be aftermarket rotors and pads compatible with F90 CCB calipers in case we don't want to replace the whole system or buy new CC rotors when/if they wear out.
