03-17-2024, 10:23 AM | #1 |
Rep 16
Catless DP too raspy with Remus, solutions?
Hey all,
I’ve had a catless downpipe and tune on my OG for a while, installed a Remus cat back yesterday. While it sounds amazing at 4000rpm +, it’s pretty raspy and blowy (not sure that’s the right word for it!). Would love some input on best options, read lots about the Fabspeed sports car, but not sure I can wrap my head around $1700 for a cat after paying for the Remus. Thanks for any advice! |
03-17-2024, 03:47 PM | #2 |
154
Rep 216
The Fabspeed is more expensive partly because they "guarantee" no CEL. If that's not important to you, there are a myriad of other downpipe options for our cars. Might be worth looking around at X-PH to see if anything catches your eye.
You could also go the route of a valve controller. I have the CG Precision one on my car along with Remus exhaust and HJS Euro 6 catted DP, and it definitely helps quiet things down. Not sure how much louder catless is though. |
mike@x-ph.com24527.50 searley867.00 |
03-18-2024, 02:59 AM | #3 | |
@lbb_kev
496
Rep 516
You'll need to switch to a catted dp like the Fabspeed you mentioned. Active Autowerke is also an option which uses GESI and is a couple hundred dollars cheaper. GESI is nice and since you're already catless you probably don't care about CELs. MAD also makes a high flow dp thats over a thousand dollars cheaper than the above two options. It could be a great option for you if you don't care about CELs and don't want to push a ton of power through it. Or, you can change to a different cat back system.
Speedtech Stage 3 (8474) | Remus Exhaust | Wagner EVO 3 | XClutch | DS2 + Lift Kit | Nostrum S2 Injectors | TI E5LM | Torqbyte EKP | Intrax 1K2 | SPL | Drexler GT Race Light LSD by limitedslip.de | Schirmer Diff Lift Kit
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage |
searley867.00 |
03-18-2024, 03:08 AM | #4 |
389
Rep 585
Drives: F10 535i, M2 LCI, G05 X5 40i
I have the Remus paired with Fabspeed Sport cat DP. I also have the Remus valve controller.
The controller really lets you change the volume and tone quite considerably. I actually quite like it closed or 50% open, and really only open 100% on rare occasions like at high speed. |
searley867.00 |
03-18-2024, 11:13 AM | #6 |
BimmerPost Supporting Vendor
24528
Rep 191,521
Switch to catted downpipes instead. i recommend checking MAD or CTS
searley867.00 |
03-19-2024, 03:34 PM | #8 |
84
Rep 92
03-19-2024, 04:37 PM | #9 |
Rep 7
CanadianM283.50 |
03-19-2024, 04:50 PM | #10 |
Rep 16
I ended up finding a Wagner catted DP for cheap on Facebook marketplace. Got it installed today and it sounds incredible! All of the best parts of the remus (high pitched scream at 3500-5000 RPM) and none of the drawbacks from the catless (raspy blowing sounds).
Thanks all for your input! |
-Eidos495.50 |
03-19-2024, 08:21 PM | #11 | |
84
Rep 92
03-20-2024, 05:07 AM | #13 |
342
Rep 1,592
Catted DP is most certainly the route. Fabspeeds "NO CEL" warranty isn't quite what it seems (search threads on what they require if you actually want to use that warranty), AA is a better route if you care about no CEL, but given you are catless I doubt that, so I'd go for one of the much less expensive catted options. MAD seems to be popular and at the price it's easily worth a shot.
03-20-2024, 09:16 AM | #15 |
Rep 7
///MPhatic14200.50 Philly_sweden659.00 |
03-20-2024, 09:43 AM | #16 |
The Seeker
14201
Rep 3,427
03-20-2024, 11:21 AM | #17 | |
24528
Rep 191,521
if the CEL is a concern, get the Active Autowerke If its not, MAD catted is the way to go
03-20-2024, 05:51 PM | #18 |
84
Rep 92
03-28-2024, 08:32 PM | #19 |
Rep 29
I don’t have much first hand experience with other systems but I have an Activr Autowerks high flow catted DP (and muffler) and it sounds AMAZING. I wouldn’t say it’s raspy at all. Drone at highly speeds a bit but no rasp. It sounds incredible, I think. But loud also.
