BMW
X1 / X2
BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Code Ambient Lighting with BimmerCode
      11-23-2021, 10:22 AM   #1
djadam
Italy
28
Drives: X1 F48
So whilst I was installing my new screen I found out I had the LED connectors preinstalled behind the dash trim.
I bough and installed an OEM light strip and LED head and everything works (see pic for result).
My current questions are:
I did not have the factory ambient lighting option so this is basically a retrofit, which means I have no settings in the iDrive menu, can they be added somehow (BimmerCode)?
Has anyone tried taking apart the doors? Is there a chance the connectors are also inside the door panels (before I start opening everything up)?
Thanks!
      12-03-2021, 04:26 AM   #2
djadam
Italy
28
Drives: X1 F48
Does anyone have a clue?
I might just open the door trim to check if the connectors are also there, but, it would be nice to be able to adjust everything through the idrive.
Cheers
      12-04-2021, 12:40 PM   #3
SDriver18i
SDriver18i's Avatar
80
Drives: BMW X1 s18i 2019
Cheers
Search Ambi and light in expert mode>Headunit in bimmercode. There should be a few options related to lighting.
No idea about the connectors tho, should be present.
djadam28.00
      12-06-2021, 12:45 PM   #4
djadam
Italy
28
Drives: X1 F48
Cheers
Ok I searched, but, got hundreds of results
I think I'm gonna keep searching for something a bit more specific
      12-31-2021, 11:02 AM   #5
Beams
11
Drives: X1 2018
What is the part number for the dash OEM light strip?
      01-02-2022, 06:51 AM   #6
djadam
Italy
28
Drives: X1 F48
Hi, this is what I ordered:
Light strip: 63319321262
LED module: 63319353133
Appreciate 2
Beams10.50
ratajj1.50
      01-05-2022, 05:07 PM   #7
Beams
11
Drives: X1 2018
Thank you! I've found the parts and placed order
      01-13-2022, 07:16 AM   #8
rzorsan
Drives: BMW X1 F48
Thanks!
Did you open the doors at the end to see if there were connectors?
I have the same connector behind my dash trim.
How much did it cost?
      01-13-2022, 07:17 AM   #9
djadam
Italy
28
Drives: X1 F48
Thanks!
Total for both LED module and light strip shipped was around €30.
Have not opened the door trims yet, I tried but it sounded like I was about to break something so I stopped lol
      01-13-2022, 08:36 AM   #10
rzorsan
Drives: BMW X1 F48
Thanks!!!!
this afternoon I will order mine in bmw and I will ask the bmw mechanics if they know if there are connectors on the doors.
djadam28.00
      01-14-2022, 03:51 AM   #11
djadam
Italy
28
Drives: X1 F48
Thanks!!!!
Ok let me know what they find!
      01-14-2022, 08:14 AM   #12
Homersbud
Drives: BMW X1
Thanks!!!!
you'd be surprised how easily the door panel comes off. basically, two torx screws and just clips - you can do this in under 5 mins & see if the connectors are there.
Here's a video i used when I installed the oem tweeters moulding.
      01-14-2022, 09:19 AM   #13
djadam
Italy
28
Drives: X1 F48
Thanks!!!!
Yeah I saw this too, it was removing the door handle that it felt like something was about to break real bad.
Might give it another go over the weekend 😅
      01-14-2022, 10:08 AM   #14
Homersbud
Drives: BMW X1
Thanks!!!!
yeah - i felt the same way when i first tried this but it's like the clips that sound like they're breaking but they arent. just got to be careful and all is good.
      01-17-2022, 06:39 AM   #15
rzorsan
Drives: BMW X1 F48
I have opened the other trim on the dashboard, the small one that is next to the steering wheel, and it does not have an ambient led connection wire.
      01-19-2022, 04:58 PM   #16
X1_Gold
Drives: X1 Orange
Very beautiful and cozyman
      01-19-2022, 05:05 PM   #17
djadam
Italy
28
Drives: X1 F48
Should there be one that side? 🤔
      01-19-2022, 05:13 PM   #18
Homersbud
Drives: BMW X1
don't think so - my trim lighting connector is on other end of the dashboard close to the furthest vent from steering wheel.
      01-20-2022, 10:09 AM   #19
rzorsan
Drives: BMW X1 F48
Thanks!
hello friend, today I put the led light on the dashboard. Did you code to be able to regulate light intensity or color change? Do you get the interior light option in idrive? Thank you!!!
      01-20-2022, 10:57 AM   #20
djadam
Italy
28
Drives: X1 F48
Nope, still haven't found an answer to this...
      01-20-2022, 12:14 PM   #21
rzorsan
Drives: BMW X1 F48
The light intensity It can be done with the light intensity roulette of the box, next to the light selector....we will continue investigating....
      01-21-2022, 06:57 AM   #22
djadam
Italy
28
Drives: X1 F48
Yeah, that I knew, still haven't found out how to code it into the iDrive though
xbimmers
