BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    F90 M5 Aftermarket Wheel Thread
      05-31-2022, 06:46 AM   #221
RIVI_BLUE_F90
Drives: 2019 M5 Competition
Originally Posted by Grzechos View Post
Any pic on a car?
waiting on rear tires. hopefully this week!
      06-03-2022, 01:45 AM   #222
EM5C
EM5C's Avatar
Drives: 2020 M5 Competition
Originally Posted by 916_M5 View Post
Wheels and tires to be mounted soon. Vision forged wheels. Michelin PS 4S tires. IND / BMW floating carbon fiber hub caps.
BEAUTIFUL!
Any info on weight per wheel? Thanks in advance!
      06-09-2022, 11:14 AM   #223
TT BT
The cars we drive say a lot about us.
TT BT's Avatar
49
Drives: 2020 BMW M850i
Originally Posted by DFunk22 View Post
What size are the HF-3’s, tire size, and on stock suspension? Sorry for all the questions, just looking at same exact wheels for my 19’ M5C.
21"
285 fronts , 295 rears , and stock suspension yup
for the rear wheels i think it would look much better if the tires were 305 but i think its gonna rub so check with your salesman if you can get maybe 10.5 wide instead of 11
A bad day at the Racetrack beats a good day at the office
      06-09-2022, 05:43 PM   #224
hyboost
225
Drives: '88 M3
Vossen HF-5, temporary setup until HRE wheels arrive. Ordered in January…still waiting
Lowered on Dinan HAS…may bring it down a little more with the new wheels.
Appreciate 3
      06-11-2022, 11:39 AM   #225
apsuard
195
Drives: 2021 BMW M5 Competition
Originally Posted by Stan_Chu11 View Post
No rubbing issues?
For a perfect flush fit (if lowered) do 21x10.5 et 20 front and 21x11 et 24 rear with 285/30 front and 295/30 rear
      06-13-2022, 12:57 PM   #226
Rausky
Drives: M5 Competition, Huracan
Do Vorsteiner V-FF 103 20" fit our cars? I called a few shops and got mixed answers.
      06-15-2022, 08:01 AM   #227
H1R4
11
Drives: Audi A7
Hi guys
I'm running 21s on my f90 m5
10.5j et22 285/30/21 fronts
11j et26 295/30/21 rear
I've been having a lot of issues with steering feel and the steering moving or car tramlining at higher speeds. I've had the wheels checked, rebalanced and an alignment done twice and they were both bang on.
Cars lowered on MSS suspension that was done before I had the new wheels on and it drove fine.
Any help please?
      06-15-2022, 10:15 AM   #228
DryBark
DryBark's Avatar
162
Drives: M5 / X5
2023 BMW X5  [0.00]
2018 BMW M5  [10.00]
Originally Posted by H1R4 View Post
Hi guys
Any help please?
I have this issue with my stock 706m, but only on the summer PS4 tires. The winter PA4 Alpin's are fine. Alignment didn't help and tire wear is normal. Nature of the beast I assume, unless you swap out the mono ball joints which may make it better, but it seems to me it's a combination of the aggressive tires and the steering setup.
      06-16-2022, 02:08 AM   #229
H1R4
11
Drives: Audi A7
I thought it may of been running 285/30/21s on the fronts so was looking to try and find 275s as that's what I was originally meant to get however Michelin have discontinued the 275s in 21 diameter.
There must be something that I can do to make the car drive properly again except putting the old wheels back on
      06-16-2022, 02:06 PM   #230
Holset
Sweden
274
Drives: F90 M5 Comp LCI
Hi guys
Any help please?
When my car was new and bone stock with the Pirellis the tramlining was pretty bad at places the roads around here are groved.
Did an alignment at a reputable place by a guy who know his thing (he did not do the stock settings).
With the winter tires the tramlining completely disappeared and with the summer PS4S 21 inch its almost non existing.
I think stock alignment has basically no toe in and thats creating the tramlining on bad roads.
I can take a pic of my settings and upload if you want?
      06-16-2022, 04:09 PM   #231
DryBark
DryBark's Avatar
162
Drives: M5 / X5
2023 BMW X5  [0.00]
2018 BMW M5  [10.00]
Hi guys
Any help please?
What's your toe in? Mine is 0.10.
      06-17-2022, 04:15 AM   #232
H1R4
11
Drives: Audi A7
Hi mate if you could please. The 2nd guy who did mine adjusted the toe in not sure what to but I have an image of what it was before not after
      06-17-2022, 04:16 AM   #233
H1R4
11
Drives: Audi A7
Hi mine on the front is 0.04 left and 0.06 right. Rear is 0.08
      06-17-2022, 06:26 AM   #234
Holset
Sweden
274
[QUOTE=DryBark;29019295][QUOTE=Holset;29018761]
Here you go!
Mätt is measured
Just is adjusted
Also this was done after lowering the car.
      06-17-2022, 09:47 AM   #235
H1R4
11
Drives: Audi A7
[QUOTE=Holset;29020908][QUOTE=DryBark;29019295]
Here you go!
Mätt is measured
Just is adjusted
So yours is also at 0.10 toe in. I might get mine changed to that hopefully it helps
      06-17-2022, 12:20 PM   #236
Holset
Sweden
274
[QUOTE=H1R4;29021477][QUOTE=Holset;29020908]
Here you go!
Mätt is measured
Just is adjusted
Yes you can try it out maybe it fixes it.
One thing to mention is that we have a 285 front tire which is pretty wide for the front so some tramlining can be expected ,also the tire make/model can make a huge difference.
      06-17-2022, 02:46 PM   #237
H1R4
11
Drives: Audi A7
[QUOTE=Holset;29022003][QUOTE=H1R4;29021477]
Yeah I have 285 too, I just want it to feel stable doing high speeds again. I'll try that setting out
      06-17-2022, 06:48 PM   #238
Holset
Sweden
274
[QUOTE=H1R4;29022506][QUOTE=Holset;29022003]
Good luck!
      06-28-2022, 05:14 PM   #239
hyboost
225
Drives: '88 M3
HRE 527s
Brushed Frozen Clear Center
3” lip front, 3.5” lip rear
21x10 285/30/21
21x11 295/30/21
Dinan HAS Suspension
Appreciate 4
      07-22-2022, 04:58 PM   #240
AR_Motorwerkz
AR_Motorwerkz's Avatar
Drives: BMW F82 M4, BMW WIDEBODY F13
Originally Posted by hyboost View Post
HRE 527s
21x10 285/30/21
21x11 295/30/21
Oh man! That is gorgeous! Realy lookin’ good on HREs!
      07-25-2022, 04:45 PM   #241
WheelsBoutique
WheelsBoutique's Avatar
1180
Drives: 2015 M4
HRE 527s
21x10 285/30/21
21x11 295/30/21
Thanks for the support as always brother. Got your car uploaded to our website - https://wheelsboutique.com/gallery/b...on-on-hre-527s.
      08-04-2022, 01:18 PM   #242
Holset
Sweden
274
Hi have you done an alignment yet?
Any difference?
