05-03-2024, 09:13 AM | #2 |
F15 daddymobile
2358
Rep 3,535
if i take your post literally, dropping the X a couple inches isn't accomplished without coilovers. BC racing, KW are the two main coilovers i've heard mentioned here. there's a budget coilover (silvers?) also available now. keep in mind a 2+" drop may need new arms to correctly align your car for optimal performance and tire wear.
for a less aggressive drop, you have other spring only options like H&R VTF (front adjustable) or sport springs, eibach, and other budget friendly brands. search the forum and google for pictures of drops and the brands i mentioned.
05-04-2024, 12:09 PM | #4 |
2155
Rep 3,658
I think H&R will get you lowest, I think 1-1.5? You need to look it up.
Ride quality will be noticeably diminished, not a great trade-off IMO. Dinan or Eibach springs will ride much better, but not get you as low. If you want 1.5+ coilovers are the only option. Costly, but won't have crappy ride quality like some of these springs, specifically the ones with the most drop. |
shimmy232357.50 |
05-04-2024, 02:54 PM | #5 |
F15 daddymobile
2358
Rep 3,535
as jiggz mentioned, lowest drop and stock shocks/struts are not a good combo. expect a shitty ride if you do that. search the forum or even google the brands i mentioned. you can read up yourself on the drop values
05-04-2024, 11:54 PM | #6 |
399
Rep 667
I've done the H&R drop with Bilstein B6 on all 4, drops about 1.5" front and 1.2" back. Ride quality is shit, I cringe on every unevenness on the road. If you run 19" or larger wheels, good luck going on pot-holes. I've lost a few RF tires due to pot-holes on the H&R/B6 setup.
I've then settled for Eibach springs paired with KONI Active Sport FSD shocks, Drops about 0.8" front and 0.6" back. Ride quality is way better and refined than the previous setup, but not soft and squishy like stock setup. The FSD from the shocks actually does a great job keeping the car very nimble even at high speeds, great confidence cornering. The best I can describe it is like on my G30 5-series, going from comfort mode to sport mode on those factory DDC's. By the way, amongst all the different combinations, my X5 is also fitted with the Ultra Racing sway bars on both front and rear. So my cornering experience may not be relative to yours in comparison; factory sway bars are very soft.
2015 X535i - CP Piston, Manley Rod, ACL/King bearings, MILVs VRSF full charge Pipe, Wagner FMIC, Hybrid Turbo, MHD2+ VRSF DP, UR Front/Rear Sway Bars, Eibach springs, Bilstein B6
2015 MINI COOPER - Mahle Pistons, Max Rods, BMS intake, CTS charge pipe, Wagner Intercooler, ByteTronik Tune, VRSF DP 2017 540i - MHD2+, VRSF DP, TU Pump |
cjcampbell0.00 SJTrance19.50 |
