F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > 340mm M Sport brake discs
Studio RSR
      03-22-2024, 03:46 PM   #23
blau3er
1154
Drives: F31 30d
Originally Posted by Jon TDI View Post
And 35d?
35d (when optioned with M Sport brakes) has the 370mm fronts
35d (when NOT optioned with M Sport brakes) has grey, unpainted, front Brembo calipers - using 340mm discs
Appreciate 2
danb19791953.50
Jon TDI168.00
      03-23-2024, 03:34 AM   #24
Jon TDI
168
Drives: BMW 335d M Sport XD Touring
Hmmmm….interesting.
I always thought M Sport discs were 340mm regardless of engine size, unless you spec’d the M Performance brakes and then these came with 370mm discs.
I’m gonna physically check today to see what size discs I have.
2016 BMW 335d M Sport xDrive Touring
      03-23-2024, 03:49 AM   #25
blau3er
1154
Drives: F31 30d
Hmmmm….interesting.
I’ve sold hundreds of sets of these calipers. My info is 100% correct.
If your car is a 35d and has factory fitted blue M Sport brakes, it will have 370mm front and 345mm rear.
The M Performance calipers you mention are 370 units, but were only available as a dealer fit accessory (not factory fitted) and came in either Red, Orange or Phoenix Yellow.
Appreciate 2
Jon TDI168.00
danb19791953.50
      03-23-2024, 04:46 AM   #26
Jon TDI
168
Every day’s a school day!
blau3er1154.00
      03-24-2024, 03:22 PM   #27
ushafiq
Scotland
38
Drives: F36 435d xdrive & G01 X3
35d cars with Msport blue calipers, have 370mm front discs, and 345mm rear discs.
      04-18-2024, 02:41 PM   #28
Jon TDI
168
Quick update: After weeks of researching the best prices of 370mm front discs, I stumbled across a private seller on eBay with a pair of reasonably priced Brembo grooved/dimpled 370mm discs.
Suspect they are the same as the OEM M Performance discs as they look identical.
As for pads, I can’t seem to find the Ate ceramic pads for the fronts, just the originals.
BMW genuines are £130, as are the Brembo Xtra’s.
Any recommendations for daily/fast road use to suit the Brembo grooved/dimpled discs?
danb19791953.50
      04-18-2024, 03:59 PM   #29
danb1979
Idiotic lifter of heavy stones...
danb1979's Avatar
1954
Drives: 2015 F31 325D M Sport touring
ATE Ceramic pads: https://www.autodoc.co.uk/ate/13580115
IIRC the 340mm and 370mm calipers share the same pads
If not those then the Brembo HP2000s seem to get good reviews
I've stuck with OEM BMW and TBH they've been superb; great braking, quiet, not very dusty and have performed from some very hard/fast driving to dead stops with zero issues
https://www.ebay.co.uk/itm/265167767...Bk9SR7CEhbDeYw
My car: 2015 F31 325D M Sport Touring in Glacier Metallic Silver - Keeping it OEM 'Plus'
Project: https://f30.bimmerpost.com/forums/sh....php?t=1982298
Jon TDI168.00
      04-19-2024, 02:39 AM   #30
TurboWeasel
829
Drives: BMW 330D
OEM Jurid pads. They are quiet and bite very well from cold. Very dusty, but it comes off easily and doesn't attack the clear coat like a lot of aggressive fast road pads do.
Appreciate 3
Jon TDI168.00
danb19791953.50
MY340i731.50
      05-03-2024, 10:09 AM   #31
Jon TDI
168
Starting to build up the parts required for disc & pad replacement.
Gone for full on Brembo.
Got the matching rear discs, just waiting for HP2000 rear pads.
danb19791953.50
      05-03-2024, 10:36 AM   #32
danb1979
danb1979's Avatar
1954
If not already; worth spending another £100 and getting HEL braided lines IMO
Jon TDI168.00
      05-03-2024, 10:59 AM   #33
TurboWeasel
829
Drives: BMW 330D
Nice! That little lot should work well as a package with the Brembo calipers
What are the dimples for? I've seen holes and grooves before, but dimples!
Appreciate 2
danb19791953.50
Jon TDI168.00
      05-03-2024, 11:57 AM   #34
danb1979
danb1979's Avatar
1954
Help dissipate the gasses & aid cooling IIRC - the grooves also aid to keep pads from glazing
Exactly same design as the BMW discs
Jon TDI168.00
f30post
