09-09-2014, 12:11 PM | #1 |
10
Rep 119
Attention! No Warning Tone
No Warning Tone popped up my NavScreen. I lose all music and warning sounds/ gongs replaced by constant static lasting for a few seconds to several minutes. Brought it to the dealer and (according to them) they updated the software. But the next day, the problem persisted. Dealer advised me to just bring the car in when the problem comes up again as it is impossible for them on waiting when it pops up. There is no way to duplicate the problem because it comes out randomly. Battery is still good. Any idea what causes it? Suggestions? CIC reset? Thanks guys
youtube and attached pic below |
09-15-2014, 04:51 AM | #3 |
BimmerPost Supporting Vendor
3388
Rep 7,542
This means that there is an issue with the fiber optic MOST loop. Dealer will have to diagnose it to determine which control unit on the loop is causing the problem. The only other potential culprit could be a loose connection on the MOST ring.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- |
09-16-2014, 04:40 PM | #4 |
10
Rep 119
Thanks Mike! I actually have the BPM Tune. The car's airbag module was replaced 2 months ago, was wondering if it's the culprit. Actually it happened again but worse the other day, while driving at a busy street the volume went full max by itself and it doesn't respond to the master volume control. Immediately pulled over. Scared the $&&@ out of me. It's back in the dealer. I took another video of the volume going up by itself
09-16-2014, 04:46 PM | #5 |
3388
Rep 7,542
Hope you're enjoying the tune.
The airbag module doesn't have MOST so that is likely unrelated. To me, based on the volume going up by itself, it sounds to be that the CIC (navi head unit) is defective. Good luck and keep us updated.
09-16-2014, 06:33 PM | #6 |
10
Rep 119
The tune is absolutely fantastic! At first I was afraid they would void the warranty because of the tune, but the service manager didn't mind it. If they replace the CIC would I lose the BPM tune and reinstall it? I'll forward your diagnosis to the service manager. I'll keep you posted. Thanks
09-24-2014, 03:21 PM | #7 | |
10
Rep 119
video link |
09-26-2014, 08:20 PM | #8 |
3388
Rep 7,542
Reading that diagnosis report tells me the dealer is a bunch of goons. This is a problem with the CIC unit, not the combox or amp from what I see on their diagnosis. The only other issue could be the AMP, but it looks like that was already replaced. That first combox that they replaced definitely wasn't defective. Also, why they would check the connections at the USB hub is beyond me, it doesn't even have a MOST connection. Reading that makes me loose faith in BMW technicians, they just press buttons on a computer and don't use their brains to correct a problem w/ a car. Has absolutely nothing to do with EDC as that's not on MOST bus either. It's the CiC or another control unit on the MOST bus.
10-06-2014, 08:07 AM | #9 | |
10
Rep 119
10-13-2014, 08:43 AM | #10 |
10
Rep 119
Problem solved (so far). All those time, in and out of the service dept, equipments replaced... the only problem was the USB Iphone charger cable having a short, affecting the whole system. Wow. Lesson learned.
04-06-2024, 02:22 PM | #11 |
Rep 3
04-06-2024, 04:47 PM | #12 |
493
Rep 487
Drives: 2009 E93 M3 DCT
One would assume by replacing the shorted iphone charger cable.
