The Basics of Tuning and Timing
02-24-2011, 11:51 AM | #45 |
23
Rep 1,179
strong post -- and good explaination of how it all works ...
one thing i would like to add: for timing to be efficient it must occur within a set window of opportunity -- when engine speed increases the time it takes the piston to reach TDC is shortened. now if you add a load factor to the speed increase the cylinder pressure must be kept at optimum levels to sustain proper engine output. if the timing occurs too early in the process (under load) cylinder pressures rise to a unacceptable level -- ie knock events start to occur. now if you add pressurization to the equation (boost) you make the engine more susceptible to knock. simple way to put it --> cylinder volume -> pressure --> start of ignition --> piston speed. with more volume and speed -- time if initial fuel/air ignition is reduced (required) -- a knock event is an indication of cylinder overpressurization and lack of combustion control .. this is one reason most engine builders/tuners search hard for the best timing under the knock threshold. so with the increase in load, and piston speed timing is moved backwards to reduce the peak pressure reached @TDC -- having the ability to move (graduated increases) the timing back up to an efficient setting is far more advanced than the old way of power timing (under load till it knocked and then back it off 2-3 degrees).. and believe you me, you never wanted to power-time a forced induction engine -- unless you had a lot of spare parts laying around and nothing to do but teardowns and rebuilds again -- great post and good information |
02-24-2011, 12:07 PM | #46 | |
103
Rep 3,460
02-24-2011, 12:31 PM | #47 |
23
Rep 1,179
trying to help --
i worked as an instructor at a local tech school for a little bit, the guys i worked with were really clueless to onboard electronic controls. but just like everything else technology, some people get caught in the past. like the guys i used to wrench with, they said i was stupid for taking personal time to go to fuel injection classes -- cars would ALWAYS have carburetors .. still gotta dig through some tech stuff and get that info -- i think it will benefit everybody on specifics of the N54 |
02-24-2011, 01:59 PM | #48 | |
56
Rep 219
I have a two year old son... and that kid has taught me more about patience and learning to let things go than any other experience I've ever encountered haha!! I'm a fairly technical person in many regards, but man, try being logical with a toddler!! That combined with being a moderator on other boards for a couple years (most mods/admins get called out/talked trash to on a fairly regular basis haha), and spending a good amount of time in Nasioc's OT section (talk about a number of fairly clever, foul-mouthed, trash talking, yet strangely comical reprobates there are over there haha)... well, what another anonymous person says online doesn't bother me nearly as much as it used to! The way I figure it, if people really want to learn, they'll at least make an attempt to listen to what another person has to say (even if they're wrong), but otherwise, not much you can do about it IMO. Just my $.02
2008 Honda S2000 (weekend/former autoX) - 1996 Acura Integra GS-R (occasional autoX) - 2008 BMW 128i 6MT (track/time attack) - 2008 Nissan Xterra (winter beater)
02-24-2011, 02:02 PM | #49 | ||
56
Rep 219
02-24-2011, 02:03 PM | #50 | |
103
Rep 3,460
No kids here...don't want any for at least 3 years either. Your name sounds familiar from msf.org.
02-24-2011, 02:21 PM | #51 | |
Joint Chiefs of Staff
4927
Rep 116,037
Mike |
02-24-2011, 02:37 PM | #52 | |
56
Rep 219
You're Laloosh right? I remember you being a bit of a guinea pig for CP-E back in the day lol. I actually worked with Jordan at CP-E back in the day and introduced the idea of developing an upgraded HPFP back when those cars were running lean around ~3500rpm or so when upping the boost (yeah, that long ago haha)... but sadly I sold the car prior to the release of their HPFP. I also soldered in the first Standback in a MS3 in this state (CO) in my buddy Josh's car... their first variation, I remember not caring for the axes (I think they were referencing TPS or something to that effect for a load reference on the original version?!? That takes me back...), but I know they eventually updated it to use a real load reference. I won't lie, I was never a big fan of Mazda's ECU's.. ridiculous throttle plate partial closure at high RPM's, horrid stock tunes, finicky at best ... and don't get me started about the piss poor, heat soak laden TMIC design haha! I'm glad to see the aftermarket has addressed most of those issues for that community though
02-24-2011, 02:42 PM | #53 |
113
Rep 4,771
You're all wrong. Everybody knows tuning is all about adding forced induction and raising boost until something shatters into a million pieces and then blaming the manufacturer of the turbo / engine. Geez. I'm gonna go start my own tuning company now. Who wants in?
We'll name it BOOM Ferrari Tuning On a serious note. It would be great if those who did understand this and tuned their own cars could post some more about it so other members can get more familiar with the process. I'm not saying Joe Plumber should go tune his own $50K car. But it's never hurt anyone to have more knowledge |
02-24-2011, 03:04 PM | #54 | |
3442
Rep 79,211
Load VS RPM usually Tables for fuel Tables for ignition Tables for Cam Profiling/advance if applicable What sets them apart is the amount of control they have and any other features they might offer. Lean Protections Knock Protection Idle Rev Limits Gear Compensation (ignition/fuel) IAT Compensations ECT compensations Oil Compensations ETC ETC Not much to "teach" for this platform until a company releases software and tune for the end user. Que Cobb ATR. |
02-24-2011, 03:07 PM | #55 | |
204
Rep 620
For example, on the stock ROM for my 2006 LGT, the map calls for 13.54 psi manifold pressure at 95.4% and above throttle plate opening at 3,600 RPM. The ECU then applies a compensation to this based on altitude, which applies a multiplier of .05208 to the current observed atmospheric pressure and then adds an offset of .25 to that product. This is then used as a multiplier to the original requested boost target to compensate for barometric pressure. Take two examples: 14.5 psi atmospheric pressure: 14.5psi*.05208 = .75116 +.25 = 1.00516 Requested boost of 13.54 psi * 1.00516 = 13.609 psi requested boost corrected for atmosphere. 12.5 psi atmospheric pressure: 12.5psi*.05208 = .651 + .25 = .901 Requested boost of 13.54 psi * .901 = 12.199 psi requested boost corrected for atmospheric pressure. My understanding of the N54 logic, which is still very limited, is that it would try to maintain that same 13.54 psi of manifold pressure, despite a drop in ambient pressure of 2 psi. Remember that the 2 psi drop in atmospheric pressure at the same manifold pressure will increase pressure ratio at the turbo. This makes me question how viable the OEM logic is for tuning the platform well beyond the factory power levels. |
02-24-2011, 03:11 PM | #56 | |
3442
Rep 79,211
IDK the specific limitations but the N54 Logic is designed to make ~300HP in any conditions. So if its scorching hot out, and 2000 ft elevation, it will allow for more boost to make up for it. If your at Sea Level, 30 degrees, it will lower boost, to achieve only 300 HP. So the car never really has that much of an advantage in cool weather as some people would like. It also pushes the car pretty hard if conditions arent ideal to get the HP back. What this does is make a really good day, the same as a really bad day. Not ideal for tuning for max power, as you could imagine, tuning in 30 degrees at sea level would yield a lot more power efficiently then at 90+ degrees in high elevation. To the tuning world, its A$$ backwards. |
02-24-2011, 03:16 PM | #57 |
153
Rep 1,809
Here are some logs from a run between me (GIAC S2) and my buddy (JB4 map7, no methanol). Outside temperature was about 1 degree Celsius. Look at the ignition timing. Seems pretty much ok (first picture is the GIAC log, second is JB4). Logs are 2-3-4-5 gear. Second gear is a mess because there was no traction.
02-24-2011, 03:31 PM | #59 |
3442
Rep 79,211
02-24-2011, 03:41 PM | #60 |
43
Rep 231
Please stop fucking up a perfectly good thread.
OP, you said things perfectly for a basic understanding of tuning and timing. Whether this DME does/doesn't do things isn't for this tread. Please people, just keep this on topic, no marketing, no vender bashing, no product boasting, etc. |
02-24-2011, 03:43 PM | #61 | |
56
Rep 219
Fuel is fully closed loop on these cars, there's no debating that.... but timing? If this is truly your belief, please breakdown how you believe this "closed loop timing" works. No sarcasm intended, I would truly like to hear your theory. Are you implying that the DME is constantly attempting to advance timing with no maximum load based values? If so, that would mean that running something like VP 110 (or any other designer racing fuel out there) would advance timing with no theoretical limit... and there would be no extra power to be made by advancing timing (manually/tune ECU for more timing) when octane permits (via race gas, meth ect) as the DME should constantly max out timing values based on knock input with no load based limits at any RPM... is that what you're suggesting? If so, do you happen to have a technical write-up of some sort we could take a look at? If not, well, '07 AP support and ATR will be out soon... I suppose I'll find out for myself
02-24-2011, 03:49 PM | #62 |
204
Rep 620
Understood. MAP is the main factor in determining load. If we look at manifold pressure on an N54 at a given RPM and IAT at sea level and then at 5,000 ft. ASL, with the same IAT and RPM, we should see almost identical manifold pressure and therefore load, no?
02-24-2011, 03:53 PM | #64 | |
4927
Rep 116,037
Mike |
02-24-2011, 04:00 PM | #65 | |
been there... done that
Rep 277
Would like to repeat myself from some of the other threads and emphasize your point quoted above. People who subject these engines to excessively agressive tunes owe it to the future buyer to do an engine oil analysis at least once a year. Search for some of the Mr. 5 threads on the subject to get baseline numbers by which you can judge the effectiveness of your tune and put all of the hypothetical arguments for and against one type of tune or the other to bed. Some dude doing WOT runs as a part of his daily drive on a mild flash tune is probably doing the same engine wear damage as a guy who is rarely gets into it with a JB3 on off-brand cheap gas. But it's easy to find out. I find all of the hypotheticals rather tiring because the reality is that none of us know the Siemens MSD80/81 control logic well enough to have any real idea as to what it's capable of doing or not. |
02-24-2011, 04:00 PM | #66 | |
56
Rep 219
I say that because I've seen several 335's at a local drag strip (Bandimere Speedway), which has an elevation of about ~5800 ft. The average trap speed for a stock 335 up here seems to be around the 95mph mark, which is a far cry from the 100-105mpg trap speeds most people seem to be pulling at sea level. 91 octane piss water and uber-thin air FTL
