MHD "take a look at my log" thread
06-07-2016, 09:50 PM | #23 | |
199
Rep 1,070
Still, from what little i have read, timing doesn't seem to be a problem and your turbos don't seem to be over stressed.
JWebb335xi
MHD / Wedge / 93 Octane/ xHP / FMIC / Inlets / Catted DPs / CP / DVs |
06-09-2016, 10:30 PM | #24 |
Rep 4
2008 535i sport 48k miles completely bone stock.
I just replaced sparks and coils, I plan on flashing soon. Can someone take a look at my log and let me know if it looks healthy enough to flash? thanks. http://www.datazap.me/u/bayarea510/l...og=0&data=4-21 |
06-09-2016, 10:51 PM | #25 | |
Jewel Runner
332
Rep 911
If you dont mind me asking, where you at in the Bay?
06-09-2016, 11:12 PM | #26 | |
Rep 4
I'm originally from Hayward, now I stay in Tracy. |
06-09-2016, 11:17 PM | #27 |
Jewel Runner
332
Rep 911
06-10-2016, 11:56 AM | #28 |
25
Rep 74
Drives: 2008 335i Coupe 6-speed
So, I've gotten these codes a couple of times so far, but only after I put in about 3gal of e85 (not sure what the actual percentage is, waiting on the gas co to get back to me but won't be using it again). 2c7e and 2c6a with 30ff code at 5k
My boost isn't hitting target either, but I haven't checked for leaks/solenoids, etc. Stage 2 93oct v6.1 MHD OTS, 3rd gear pull. http://datazap.me/u/335iguy/3rd-pull...7-19&zoom=7-94
'08 E92 335i 6MT Coupe SGM | MHD Stage 2 93oct | Cp-E CP | AA BOV | DCI | VRSF DP | VRSF 5" Stepped FMIC | Apex Arc-8 | Cyba Air Scoops | Failing HPFP....
06-10-2016, 04:11 PM | #29 | |
1978
Rep 345
06-12-2016, 07:18 PM | #30 | |
92
Rep 322
on the 2nd log you have RPM jumps. Also your bank 2 AFR is rich.. and differs too much compared to bank 1 |
06-12-2016, 09:27 PM | #31 |
38
Rep 202
what is the solution?
2009 E90 335i
MHD Stage 2 | BMW PE | X-Pipe/Resonator Delete| K&N Drop-In |VRSF CP | VRSF 7" FMIC | VRSF DP's | Apex Arc-8 |
06-14-2016, 07:15 PM | #32 |
236
Rep 358
http://www.datazap.me/u/justdriveit/...og=0&data=4-23
Anyone mind taking a look at this? 2007 Stock 93oct E20-25ish mixture MHD V6.1 Stage 1 93oct Map Last edited by JustDriveIt; 06-14-2016 at 07:29 PM.. |
06-14-2016, 08:54 PM | #33 |
48
Rep 161
A bit ago I was having problems with 30FF firing off on my car. This past weekend we did a boost leak test and it tested great with no leaks. All the vacuum lines are changed out on it and in good shape. It's running a charge pipe with a SSQV and DCI; I had to return it to stock for warranty work a bit ago and haven't added anything additional. It's also running MHD v6.1 Stage 1 95oct w/ E35. All the lines were taken off and tightened back up; the 30FF hasn't fired since.
I was able to get a good 2nd gear pull and most of a 3rd gear pull before someone pulled out in front of me. It definitely appears that I'm not going to where I'd expect boost wise. Does anything look odd in this log? http://datazap.me/u/rosullivan04/tro...og=0&data=4-23
2008 335I 6MT
Tune by Wedge Performance |
06-14-2016, 09:14 PM | #34 |
49
Rep 203
Finally loaded v6.1 Stage 1 and its a lot smoother than v5. I used to get a surge around 4k to 5k and now the power is felt throughout the entire RPM range..
Check it out and let me know your thoughts. http://datazap.me/u/rgfinn76/335i-v61?log=0&data=4-24 |
06-15-2016, 09:54 AM | #35 |
42
Rep 50
New plugs and coils from Bosch were just installed. Cyl 2 correction is zero with new and old plug/coil set (also Bosch). Corrections are present on other cylinders. No misfire, no code. Running Mobil 93 octane fuel. Fuel should be good, since Cyl 2 has zero correction?
Datazap log: 535i 6MT running 93 oct, stage 1, no FBO. ambient air 78F I look forward to your comments. |
06-15-2016, 12:52 PM | #36 |
163
Rep 376
Just posting here. I'm a complete newb when it comes to cars.
My background is flashing android phones lmao. Flashed to Stage 1 v6.1 91ACN. Stock everything. K&N air filter <-- aww jeah http://datazap.me/u/aoh83/stage-one?....45&tmax=14.40 Any issues with the data log provided? This car is a friggin beast. I don't see a need to go Stage 2. Overall I am happy.
2010 E92 Monaco Blue 335i / Gray Dakota Leather / Steptronic / Sport / Premium / Navi / L7 / 18" Performance Wheels / HPFP fail @ 8400 miles (replaced with #933 pump) // MODS: Mishimoto OCC | VRSF CP + Turbosmart Dual Port BOV | RB PCV Valve // Maintenance: Walnut Blast @ 56k | Spark Plugs Replaced @ 56k | Addons: BN2000 Combox // Andream Carplay // Rear Camera // Spark Plugs (.022 gap) and Coils Replaced 73.1k
2019 G01 Carbon Black X3 M40i / Premium / Driver Assist / 21" on Bridgestone Alienza RFT |
06-15-2016, 01:07 PM | #37 |
Stuff and Things
39
Rep 103
MHD stage 1 91oct
DCI, muffler delete, no other performance mods I've been getting 30ff during long pulls, get the half engine light and reduced power message. On one log it happened around 4500rpm, on the other log it didn't pop up but the car felt slow. Seems obvious Im not making as much boost as I should but I'd like some insight as I'm not an expert at reading these logs http://www.datazap.me/u/89mustaine/l...og=0&data=4-23 http://www.datazap.me/u/89mustaine/l...og=1&data=4-23 Last edited by 89mustaine; 06-15-2016 at 01:17 PM.. Reason: attachments didnt work |
06-15-2016, 01:07 PM | #38 |
35
Rep 86
First time posting but long time lurker. I am pretty new to logging and would like some feedback on my log. I am FBO + inlets running 93 oct.
Flashed Stage 2+ http://www.datazap.me/u/gxmac/log-14...data=1-4-16-21 Car seems to be running fine other than the occasional rough idle on startup. Much appreciated. |
06-16-2016, 08:34 AM | #40 |
188
Rep 670
I have a third and a fourth gear log. I had a 30FF at the track, but seems to have resolved itself after a couple days. I have new solenoids on order to rule those out. Replaced solenoids and vacuum lines last summer after same issue on the track.
3rd- http://datazap.me/u/davidwarren/log-...=0&data=4-6-23 4th- http://datazap.me/u/davidwarren/log-...=0&data=4-6-23
2010 335i e90 Le Mans Blue/Chestnut Brown | M-Sport | 6MT
06-16-2016, 12:26 PM | #41 |
163
Rep 376
Does anyone on this thread with expertise look at these logs? Would be great if someone with knowledge contributed
06-16-2016, 01:17 PM | #42 |
Rep 11
335i E90 10' AT
91 OCT 61880 Miles Michlien PSS AS STOCK oil changed every 10k plugs, coils changed at 30k and 60k Please take a look http://datazap.me/u/turducken/single...og=0&data=4-21 When accelerating between 2k-3k RPM the car has a little "jutter" in low and high gears. Other than that she's a dream to drive. |
06-17-2016, 06:38 PM | #43 | |
92
Rep 322
06-17-2016, 06:43 PM | #44 | |
92
Rep 322
