Bigger brakes for E90 320D with 17" wheels?
07-23-2022, 01:19 PM | #1 |
114
Rep 1,002
I'm thinking I should rebuild my callipers but was wondering if I could fit bigger brakes for maybe stronger feeling brakes. Any suggestions? What would be an upgrade?
07-23-2022, 05:20 PM | #3 |
114
Rep 1,002
07-24-2022, 02:58 AM | #4 |
121
Rep 601
I always thought all 330d had bigger brakes as you could never run 16 inch alloys on them due to the bigger brakes even on E46's.
I have a 325d which is 2009 and LCI it has the 330d brakes which I think are around 30mm bigger in diameter than the 320d. |
tadaska113.50 |
07-24-2022, 10:17 AM | #5 |
5532
Rep 5,443
Drives: Beige G31 40ix m sport
Maybe try some ceramic pads instead
G31 40ix M Sport
E92 335i. E36 328is coupe E39 540i V8 6SP manual E34 3.6 M5. E34 525i sport. VW Jetta Mk2 GTI 16v. 1679cc 1967 resto-cal beetle |
tadaska113.50 |
07-25-2022, 12:48 PM | #7 |
114
Rep 1,002
That's probably what I will do. Yellowstuff pads with OEM discs. Like you said, kinda pointless getting big brakes on a 320d.
07-25-2022, 01:11 PM | #8 | |
96
Rep 667
The 330d either uses 330mm (most common) or 348mm front discs, the 320d ones are smaller, either 300mm or 312mm depending on the age of the car. My current 330d is a late 2010 / 60 plate car and has 330mm fronts, my old 330d was a 2006 / 56 plate and also had 330mm fronts.
BMW E90 330d M Sport LCI in Sapphire Black
tadaska113.50 |
07-25-2022, 01:43 PM | #10 | |
114
Rep 1,002
07-26-2022, 06:35 AM | #12 |
96
Rep 667
I would be very surprised if they were 330mm
08-01-2022, 10:51 AM | #15 |
75
Rep 541
My 2006 330d came to me with 17” wheels and had 348mm brakes. My sons lci 330d had 336mm (is it?) anyway, the smaller ones so it seems very random which brakes came with which 330d.
08-02-2022, 11:48 AM | #16 |
96
Rep 667
It's definitely random and not many came with 348mm ones, most are 330mm, still can't work out why some got bigger brakes!
08-02-2022, 12:35 PM | #17 |
84
Rep 687
08-02-2022, 03:34 PM | #18 |
731
Rep 1,815
True, I run 17” as my winters on my 335i and my wife’s 328i with 335i brake retrofit.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
08-03-2022, 07:17 AM | #19 | ||
143
Rep 115
If it?s Standard Modify it
08-06-2022, 03:18 PM | #21 | |||
163
Rep 184
Drives: E90 LCI 320d SE
