05-13-2019, 10:34 AM | #89 |
674
Rep 757
I installed Revshift 80a poly trans mounts two weeks ago and returned them in under 12 hours. The vibration was unbearable. And no I didn't tighten them too tight I went back and adjusted it multiple times even to the point of just finger tight. I was pretty surprised that even the softest poly would be like that, so I ordered new OEM ones with lifetime warranty for $5.95 each! I just had my 80a diff bushings in and they feel great! No added NVH at all. Finnegan what would you gauge the NVH to be like with poly engine mounts?
2006 Z4 M Roadster Black/Imola Red, FBO VF-Engineering, e85 Flex Fuel-Sold
2012 BMW 135i N55 DCT Alpine White/Coral Red, FBO, TBI, Full e85, JB4 BEF-Sold 2006 Z4 M Roadster Black/Black-Sold 2021 M2 Competition DCT Hockenheim Silver |
05-19-2019, 02:17 AM | #90 | |
Dog Listener
707
Rep 7,850
05-19-2019, 02:20 AM | #91 | ||
674
Rep 757
05-19-2019, 03:58 AM | #92 | |
#buildnotbought
11079
Rep 4,928
The original transmission mounts are very very soft/squishy. I haven't measured them (hard to do) but I guesstimate them on maybe shore40A So going to shore80A is a giant leap, where considering the diff mounts (probably stock around shore70A) the difference is much smaller with shore80A And then there are also other things like how the mount is internally constructed; how much rubber is inbetween the one and other side. I used generic vibration dampeners with a stiffness of shore55A (cost about $2/piece....), which are considerably stiffer than the OEM hourglass shaped mounts but don't add extra NVH. You can also look at it from a load pov. I don't know if you've ever (personally) removed the gearbox, but the whole engine/gearbox assembly pretty much rests and pivots around the engine mounts. They take most of the weight and twisting forces. The load on the transmission mounts is very little (you can easily hold up the gearbox with one hand if the transmission mounts are removed); I guess the weight on that point is no more than 30lbs or so, so half that per mount. That kind of weight doesn't need a very stiff mount/dampener to control vibrations.
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
WeekendWarriorz674.00 Finnegan707.00 |
05-19-2019, 10:48 AM | #93 | |
1163
Rep 2,880
Drives: Anything
Regarding engine mounts, have you considered 034 Motorsports mounts linked below? It's described as a small improvement over the OEM mounts. I will give this a try when I inevitably have to change out my Vibra Technics mounts. https://www.ecstuning.com/b-034motor...34-509-0064kt/ Last edited by XMetal; 05-19-2019 at 10:53 AM.. |
WeekendWarriorz674.00 |
04-17-2023, 09:26 PM | #94 | |
Dog Listener
707
Rep 7,850
Totally agree on the RE mounts vs. John Deere tractor experience from hella hard mounts. |
04-18-2023, 12:08 AM | #95 | |
1163
Rep 2,880
Drives: Anything
Finnegan707.00 |
04-22-2023, 01:42 AM | #96 | |
Dog Listener
707
Rep 7,850
Mine are original on a 50k mile car kept most of its one owner before me life in a climate controlled garage. Suspension - everything - stock but amazingly solid and firm. Not driven hard either - mostly freeway miles. I suspect it’s all good but will check. |
04-22-2023, 08:38 AM | #97 |
953
Rep 783
I bought the 034 Motorsport engine/trans combo, https://www.ecstuning.com/b-034motor...4-509-3646~kt/
I have only been driving on them for a couple weeks but I certainly like the feel of them better compared to the old original mounts, maybe that's not saying much but so far there is no extra NVH from them that I can tell and all feels crisp. I also installed the Garagistic supreme shifter and UUC double shear selector rod with all new OEM shifter bushings. At 4,000 to 8,000 rpm with hard acceleration there is a high pitched buzzing sound and vibration coming from the shifter, I stuffed the the hollow shaft and knob with closed cell foam and that helped some what but I'm still trying to track down the culprit. Finnegan have you ever encountered something like this? I'm doubting that the 10 durometer increase in the hardness of the new mounts could be the cause.
2008 E86 M coupe
04-22-2023, 12:30 PM | #98 | |
Dog Listener
707
Rep 7,850
However, when I overtorqued the transmission mounts early on in my exploration with this car, I got some excessive vibration. If I recall the torque specs are something extremely slight. That’s just an FYI I don’t think it applies here. The the buzzing at those rpm range - is consistent no matter what gear you are in - or does that vary? If it varies, I would look for part of the new mechanics, somehow touching a bracket or the car and creating a resonance. |
grannyknot953.00 |
05-03-2023, 01:00 PM | #99 |
457
Rep 977
I am running 034MS mounts and they are an actual improvement over VT, which were harsh as hell, and 034MS mounts have not degraded the shifter quality one bit, my idle now is smooth and the car does not vibrate as it did with VT (I could see the headlights vibrating at nigh as well as interior mirror). the 034MS items are butter smooth compared with VT, but no drawbacks. Cannot tell from stock as I never drove the car with stock mounts.
i have AS SSK and it buzzes too at 5k rpm. but I am not going to mess with it, since it only happens on that range it does not bother me. |
Finnegan707.00 |
