The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > DIY: Setup BMW Standard Tools 2.12 on Windows XP > 10
      12-10-2015, 08:32 PM   #1
wildcatcrazy
wildcatcrazy's Avatar
Drives: E90 335i
2009 335i  [0.00]
Many have asked for the easy way to install BMW Std Tools, and I have developed a proven method that can be done in less than 15 min depending on the processing power of your machine.
The only requirement for this install is Windows XP through Windows 10, 32 or 64 bit version and a working KDCAN cable. Instead of writing a lengthy detail in this post, I generated the instructions that's included in link below.
If this install has assisted you in achieving a working set up, please click the appreciate link, thanks!
MediaFire: https://www.mediafire.com/folder/a7jvirbs559ib/Software
NOTE:
For everyone who's having issues setting the default folders, it is because some of the downloads excludes "empty" folders. Therefore, make sure your folder structure on the C drive are as follows (if you're missing a particular folder, create an empty one):
C:\EC-APPS\INPA:
BIN
CFGDAT
DEMO
DOKU
english
english.met
HELP
PRT
SGDAT
source
C:\EC-APPS\NFS:
BATCH
BIN
CFGDAT
DATA
DOKU
FORMAT
KMMDAT
SGDAT
TRACE
WORK
C:\EDIABAS:
API
BIN
DOKU
ECU
HARDWARE
HELP
SIM
TRACE
TUTORIAL
C:\NCSEXPER:
BIN
CFGDAT
DATEN
PFL
SGDAT
STDAT
TAB
VERPLATZ
WORK
Chassis family guide for choosing your proper DATEN: http://www.e90post.com/forums/showthread.php?t=642883
Edit 1: Added F series files for INPA. Added support files for N47.
Edit 2: Added working copy of NCS Dummy.
Edit 3: Updated DATEN link.
Edit 4: Added notes about setting default folders in BMW Coding Tool.
Edit 5: Updated DATEN link to 60.0.
      12-12-2015, 08:43 PM   #2
paranoidroid
9
Drives: 2011 135i DCT
Just wanted to give a HUGE thanks for this. Downloaded the link, followed your instructions and everything is running great!
Appreciate 2
      12-12-2015, 09:31 PM   #3
wildcatcrazy
Drives: E90 335i
2009 335i  [0.00]
Thanks and you're welcome. Hopefully the community can benefit from this.
Appreciate 3
Brake_Late1937.50
      12-21-2015, 01:10 PM   #4
Autobarn234
21
Drives: 2006 BMW 330i
Installed perfectly smoothly.
Thanks.
Brake_Late1937.50
      12-22-2015, 06:16 PM   #5
secrethero
15
Drives: 2008 335XI
The only requirement for this install is Windows XP through Windows 10, 32 or 64 bit version and a working KDCAN cable. Instead of writing a lengthy detail in this post, I generated the instructions that's included in the link below.
https://mega.nz/#F!e0V0RIAY!MdeDwDmzWVjeHiRshXq1Pg
Thanks Dude! you made it so easy
Appreciate 3
ionu70.00
Brake_Late1937.50
      12-23-2015, 09:57 AM   #6
secrethero
15
Drives: 2008 335XI
E90 DATEN files
Hey wildcatcrazy,
Is it possible to get chasis e90 DATEN files in RAR parts chunks? Its a 4.5GB file and I having problems downloading it.
I was able to download all other files with no probs.
Thanks again. You rock
Appreciate 2
Brake_Late1937.50
      12-23-2015, 11:03 AM   #7
secrethero
15
Drives: 2008 335XI
Never mind wildcatcrazy.
I was finally able to download it.
Thanks again.
I wish if there was something this simple instructions and downloads for ISTA NEXT
Brake_Late1937.50
      12-24-2015, 12:04 PM   #8
Autobarn234
21
Hey wildcatcrazy,
I am having problems downloading it.
If anyone has a torrent link or rarred bits, kindly help.
Appreciate 2
Brake_Late1937.50
      12-24-2015, 05:42 PM   #9
MiniXP
MiniXP's Avatar
69
Drives: 08 335i, 06 X5 3.0
For the NCSExper_64 and EDIABAS folder, when I try to select them in BMW coding tool I am getting an error saying "not a valid NCSEXPER_64 (or EDIABAS) folder"
Any ideas? I have both the folders in the root C: drive and they are both extracted.
I'm on Win 10 64bit
EDIT:
For some reason it looks like not all the files are downloading when I download them. The ECU folder does not download from the EDIABAS folder for example.
EDIT 2: I figured it out I think. Mega wasn't downloading empty sub folders. For that reason coding tool was viewing the EDIABAS NCSEXPER and EC-APPS/NFS folders as invalid since those were all missing empty folders.
Compared what was on Mega to what I had and created any of the empty folders and it looks like it worked.
http://www.e90post.com/forums/signaturepics/sigpic228641_1.gif
      12-25-2015, 02:35 AM   #10
Autobarn234
21
Still waiting for my cable to arrive. But when I open NCS Expert, its in German. Is this normal?
      12-25-2015, 09:30 AM   #11
wildcatcrazy
Drives: E90 335i
2009 335i  [0.00]
If you copied over my folders, everything is in English.
Appreciate 4
      12-26-2015, 07:48 AM   #12
PichaDis11
PichaDis11's Avatar
Drives: E90 N52
Is anyone getting trouble on Windows 10 pro 64bit?
Currently at step#16 trying to select default folders for NCSExpert.. etc. Shows error "C:\NCSEXPERT is not a valid NCSEXPER folder." says the same for the others as well.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit
      12-26-2015, 03:35 PM   #13
wildcatcrazy
Drives: E90 335i
2009 335i  [0.00]
It's because Mega won't download an empty folder. I'll have it fixed tonight and post an update.
Appreciate 2
      12-26-2015, 05:06 PM   #14
wildcatcrazy
Drives: E90 335i
2009 335i  [0.00]
Link is fixed and shouldn't contain empty folders, so you should get a complete download.
      12-26-2015, 05:51 PM   #15
hththt
11
Drives: '15 F02 N74, '10 E90 N54
Thanks a ton for this Joseph. I followed the steps and things seem to install and launch just fine
One question I have is that once I imported the DATENs, can I delete the original DATEN folder? It looks like the DATENs are sucked into C:\EC-APPS\NFS\DATA?
      12-26-2015, 07:02 PM   #16
wildcatcrazy
Drives: E90 335i
2009 335i  [0.00]
You can delete the chassis folder you downloaded that contains the DATENs, but you obviously can't delete the Daten folder under NCSEXPER.
      12-28-2015, 10:08 PM   #17
Venoml2k
Drives: 135i
Hey whats up guys, I have a question about the 3 folders the guide says to delete and then copy them over again. are we supposed to delete or merge them with the other folders? i keep getting errors when i delete them trying to proced with step 17. any help is appreciated, thank you
      12-29-2015, 02:17 PM   #18
Autobarn234
21
You shouldn't have any problems deleting them if you have administrator privileges. Just select and delete.
      12-30-2015, 03:26 PM   #19
evo97
evo97's Avatar
Drives: 335d
Thanks for the files
Can anyone recommend a good switchable Dcan cable I can purchase in the UK
      12-30-2015, 06:53 PM   #20
Venoml2k
Drives: 135i
Hi, I've reinstalled this a few times and followed the instructions and added the missing files to the 3 folders. Using only e89 daten and I keep getting an error after clicking the Cas module. I took a picture of it but don't know how to upload it here
https://mega.nz/#!Up50nKaa!ytk5stZAW...5QEKr0C-qUPOt8
      12-30-2015, 07:17 PM   #21
wildcatcrazy
Drives: E90 335i
2009 335i  [0.00]
More than likely your cable is bad. What color is the PC board, and where did you get it from?
      12-30-2015, 07:20 PM   #22
wildcatcrazy
Drives: E90 335i
2009 335i  [0.00]
http://www.cable-shack.co.uk
Tags
coding, inpa, ncs, tool32, winkfp
