06-05-2021, 01:54 PM | #24 |
431
Rep 433
Recently had mine installed by my shop
They tig welded in an aluminum grill for me to add a little extra protection Went back and forth with them about whether to notch the skid plate to accommodate the plastic rivets, but they insisted it wasn't necessary Things seem pretty secure without the plastic rivets, but I guess time will tell Last edited by 2020M2Competition; 06-05-2021 at 04:57 PM.. |
06-06-2021, 01:34 PM | #26 | |
431
Rep 433
The larger holes should still allow for good airflow It's made out of aluminum so it was easier to weld in I also think the rectangular shape of the holes look good and goes together well with the rectangular opening of the skid plate In any case, as I think most will agree, this grill should provide considerably more protection than nothing at all |
06-06-2021, 02:48 PM | #27 |
314
Rep 438
Yes I agree ,
Looks great ! |
2020M2Competition430.50 |
06-11-2021, 07:11 PM | #28 |
3104
Rep 3,043
Drives: 2019 M2 Competition
Just installed this myself, and will have a DIY video up shortly. I am really impressed with the construction and have no doubt it will do a great job. 8)
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
parraline57501.50 |
06-12-2021, 12:52 AM | #29 |
2362
Rep 4,255
What did you decide as a solution to the rogue rivet?
///M Power
06-12-2021, 01:47 PM | #30 |
3104
Rep 3,043
Do you mean the plastic push rivets on each side that need to come out? If so, I just took them out.
06-19-2021, 04:19 PM | #31 |
472
Rep 1,659
Drives: 2022 WRX World Rally Blue
I wish they made these for the OG M2!!
Rick
07-07-2021, 09:07 PM | #32 |
229
Rep 218
Drives: '20 M2 Competition & '18 X1
Thanks for the tutorial OP and for all the recommendations from the others for adding the mesh.
I finally got around to installing the TMS Oil Cooler Guard / Skid Plate. I got the black powder coated version and also installed a bit of black mesh for added protection. It took around 2 hours by myself, but fitment was perfect. Its an incredibly solid piece and provide the protection the oil cooler needs.
2020 BSM M2 Competition | Blue Stitching | 6MT | Sunroof | My M2C European Delivery Story! | AA EL Midpipe | TMS Skid Plate
BMW DIY Guy3103.50 |
07-08-2021, 04:19 PM | #33 |
847
Rep 1,962
07-08-2021, 04:39 PM | #34 |
472
Rep 1,659
I hit something a while back and took a chunk out of the plastic guard. I replaced it easy enough. If definitely buy the metal equivalent if available. I live in the country. I've seen anything from badgers to snapping turtles that are as long as two lanes wide.
Rick
07-12-2021, 03:01 PM | #36 | |
3104
Rep 3,043
Even if the oil cooler was free I would still do this upgrade, but doubly so if you uograde the oil cooler as well.
07-12-2021, 03:25 PM | #37 | |
2093
Rep 3,009
The challenge I have with the skid plate is that it has the same exact design as the factory part. If I don't add mesh that is small enough to deflect smaller debris and maintain airflow I've accomplished nothing. That leaves larger debris like rocks and tree limbs, which will take out my front end first and then probably bend the metal up into the oil cooler. So same result a new oil cooler plus if it's that big probably a new oil pan and maybe even the diff. Additionally, being more "robust" it will rip out the rivets holding it on so you will may actually have higher repair costs associated with the collateral damage. |
07-21-2021, 07:29 PM | #38 |
314
Rep 438
@omasou
The point of the skid plate being aluminum rather then plastic is for head on collisions with objects that would otherwise tear through the plastic and get to the cooler . The amount of protection beyond stock is tenfold. |
12-01-2021, 09:24 AM | #40 |
3104
Rep 3,043
It should be: 51758079566
02-28-2024, 07:15 PM | #41 | |
Rep 6
