BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    Look what arrived to Flow Bench Test tonight
      01-15-2019, 07:24 PM   #23
Miko M
///M
Miko M's Avatar
Drives: 2020 M2C. 2020 X3M
Originally Posted by Steeve19M5CP View Post
Originally Posted by Miko M View Post
Good, you will mess MAF's if you do.
There is no MAF on the F90 M5......and no issues with oiled filters and MAF ...as long as you clean the MAF with MAF cleaner on a regular basis
Just read something about it.
I know F10 had them but looks like they use MAP sensors now for F90
Life is too short...enjoy your life
///M
      01-15-2019, 08:27 PM   #24
onfireX5
3619
Drives: F90M5,F85X5M
@onfireX5
Did you measure the cats I.D.? Is it 2.5"?
Very impressed with primary and secondary cars!
Didn't expect that stock air filter is only off from straight pipe 15%
And 10.5% from BMC filter.
Roughly 3”. The substrate is what drops the flow down from a 3.0 to a 2.5
Miko M6653.50
      01-16-2019, 05:44 AM   #25
trev230
trev230's Avatar
351
Drives: 2022 M5C
So is this thing worth putting the BMC in or not? Flow says yes.
      01-16-2019, 06:33 AM   #26
onfireX5
3619
Yes. Not a huge power gain, but 8 to 10 hp.
Appreciate 2
M 4EVER191.00
      01-16-2019, 08:02 AM   #27
devondragon
devondragon's Avatar
Drives: 2019 M5 Competition
Stay away from oiled filters for F10 and F90 M5
Miko M Since the F90 has no MAF is an oiled filter still an issue? The BMC is oiled, so are you saying you'd avoid it?
      01-16-2019, 10:01 AM   #28
Miko M
///M
Miko M's Avatar
Sense it doesn't have MAF you can probably use it.
Some oiled filters have way to much oil.
I personally would clean the filter and oil very little.
///M
      01-16-2019, 10:05 AM   #29
Ever34
325
Drives: F90 M5
Hence why I would not bother.
      01-16-2019, 10:20 AM   #30
Steeve19M5CP
194
Drives: 2019 MBB Blue M5 Competition
that 8HP always helps lol
2019 F90 M5 Comp-Marina Bay Blue-B&W,HRE 21" FF04,BMC,CarbonPro wing,H&R,ZW5
2017 BMW 330i - Estoril Blue - M Sport Package
2013 Lamborghini Aventador-Pearl Green-Modified
2004 Lamborghini Gallardo-Manual 6spd -Giallo Midas Pearl Yellow-Modified
2018 Range Rover Velar S-White
      01-16-2019, 10:22 AM   #31
Ever34
325
Drives: F90 M5
I'm good without it
      01-16-2019, 10:55 AM   #32
hybrid_eg
hybrid_eg's Avatar
Drives: 90 S13, 22 MSP, 23 JLUR 4xe
easy to remove charcoal and air filter on air-boxes like on the F10?
      01-16-2019, 10:58 AM   #33
onfireX5
3619
Yes. Very.
hybrid_eg852.00
      01-16-2019, 11:11 AM   #34
Ever34
325
Drives: F90 M5
Took me 30 min total.
      01-16-2019, 06:52 PM   #35
dmmpower
dmmpower's Avatar
32
Drives: M5
To onfireX5:
Please explain the different depression values and why the air speed is still 0 while you measure a flow.
A power gain of 8 to 10 HP would be not bad for this inconspicuous modification.
Thank you in advance.
Miko M6653.50
      01-16-2019, 07:11 PM   #36
dmmpower
dmmpower's Avatar
32
Drives: M5
BMC filtration systems give better performance to the engine, both in terms of power and torque without compromising reliability. BMC Air Filters demonstrate the highest quality, performance and reliability and have no equal in the market.
It's a pity that they don't provide dyno test to prove with data this increase of power and torque. :
M 4EVER191.00
      01-16-2019, 07:33 PM   #37
Miko M
///M
Miko M's Avatar
Originally Posted by dmmpower View Post
To onfireX5:
Thank you also to Miko M for his relentless commitment.
Thank you dmmpower!!!
Love to help and share Info
I just got back from meeting a guy from forum. He wanted to hear the car after down pipes and tune.
He was super happy, his car is coming first week in March.
///M
M 4EVER191.00
      01-16-2019, 07:41 PM   #38
dmmpower
dmmpower's Avatar
32
Drives: M5
Now you could be near to 800 HP with 100 or 102 octane 😉 and your illegal modifications. 😎
I like your enthusiams for the M5.
M 4EVER191.00
      01-16-2019, 07:48 PM   #39
Miko M
///M
Miko M's Avatar
I am sure to be close to that, will do Dyno soon.
It's not illegal where I live
Actually there is no emission test. Lol
///M
Appreciate 3
      01-16-2019, 07:56 PM   #40
dmmpower
dmmpower's Avatar
32
Drives: M5
The exhaust gas measuring equipment does not work with your car. 😂
      01-16-2019, 08:06 PM   #41
M 4EVER
191
Drives: M240/M5/X3
To onfireX5:
I think that's me.
Thank you Miko for taking your time to meet me today!!!
Didn't expect you let me drive it at all. Thank you so much
The car sounds sick man, I love it. The power difference to Competition Package is crazy!!!!!!!
Appreciate 2
Miko M6653.50
      01-16-2019, 08:32 PM   #42
onfireX5
3619
To onfireX5:
Great questions.
1. Depression, Pressure Drop, “H20 is all the same “slang” and refer to the amount of pressure delta required at that point for that amount of mass air flow due to a restriction. That restriction is a parasitic loss. So if one airbox demands 450cfm at 7000rpm at 21psi of Boost on a 70f day,etc,etc ideally it would get that flow with zero pressure drop. That would be zero hp loss. If it gets 450 at 8” of drop, there is that loss. If it gets 450 at 18” of drop , even more HP loss. So we measure those losses on a bench and try to mitigate them to a “reasonable “ number.
2. Airspeed is measured independently of drop and generally is not used for these type tests. You take a probe that is computer integrated to the bench and touch areas where you want to measure the air speed. It’s very useful in cylinder head porting as absolute CFM flow does not always equate to maximum power. Airspeed through the ports play a very important role there plus the locations of different speeds, dead zones, etc.
Appreciate 2
Miko M6653.50
      01-16-2019, 08:43 PM   #43
Miko M
///M
Miko M's Avatar
To onfireX5:
I think that's me.
No problem!
I know you would love to take it for a spin
///M
M 4EVER191.00
      01-17-2019, 03:48 PM   #44
hybrid_eg
hybrid_eg's Avatar
someone should get a group buy going on BMC..
