01-04-2019, 04:12 PM | #23 |
12968
Rep 18,715
Got reply from Germany.
Unfortunately, they don't have answer for me. I am not sure why, but maybe it is their secret sauce to the product. But, to answer Steeve19M5CP question. RaceChip is TUV approved company and so is their products. TUV is much more strict than DOT or EPA or CARB combined. So, in order to have their product released and certified, it has to pass TUV testing procedure. Another thing, in Germany, they do warranty the engine similar to Dinan in the US. Since BMWNA operates differently than BMWEU, RaceChip unable to offer the same in the US. Now, the beauty of piggy back unit, RaceChip or any other that doesn't intercept signal other than the boost sensors. Your engine is still well protected with the DME/ECU. IF there is too much boost, which causing it to run too lean, the DME/ECU will knock out the whole car into a Limp Mode. It was the case with previous generation of RaceChip product, where you can change the boost manually beyond the limit. Similar to BMS JB+ where you can adjust the dial on board to change boost gain value. While on the new Generation of RaceChip product, the firmware set the limit. You can't go beyond Map 7 since Map 7 is the highest already. In order to do more, I will need to do datalog with the gas that you are running, send the data to Germany to create custom firmware. I hope I able to clarify some issues here.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
01-04-2019, 04:26 PM | #24 | |
///MD
1378
Rep 3,998
But thanks for reply I am waiting On another note, Most Dynos showed that M5 Non Comp F90 is a 675-680 BHP car and with RC GTS SHOULD be in the 750 range?! And torque?! Ebat about Comp package M5 does it get more?! Last edited by soooma; 01-04-2019 at 04:36 PM.. |
01-04-2019, 04:40 PM | #25 | ||
12968
Rep 18,715
Turbo engine usually gain a little more torque than hp.
01-04-2019, 05:12 PM | #26 | |
Rep 26
As for CP verion, since it is the same engine, there could be no additional gain. Map 7 will equal the engine performance between two version. However, on top of improvement in engine, CP version addresses certain other areas to make it better performer on track. Mine was built before CP available, so I went for Racechip to get more enjoyment when WOT. I cherish my daughter's winter break back from UCLA and my RachChiped F90 got me her big smile while enjoying couple of launches...... |
soooma1377.50 r33_RGSport12967.50 |
01-10-2019, 12:09 AM | #27 |
18
Rep 34
Is there issues with warranty...just leased new comp f90 m5 today and my service advisor said yes
01-10-2019, 09:31 AM | #28 | |
12968
Rep 18,715
At least it has plenty of hp stock already.
01-10-2019, 10:46 AM | #29 |
194
Rep 459
yes 625whp+ stock (725-750HP) is great for daily driving.....any tuning or piggyback automatically voids BMW warranty except Dinan (some people dont mind taking the risk)
2019 F90 M5 Comp-Marina Bay Blue-B&W,HRE 21" FF04,BMC,CarbonPro wing,H&R,ZW5
2017 BMW 330i - Estoril Blue - M Sport Package 2013 Lamborghini Aventador-Pearl Green-Modified 2004 Lamborghini Gallardo-Manual 6spd -Giallo Midas Pearl Yellow-Modified 2018 Range Rover Velar S-White |
01-10-2019, 10:58 AM | #30 | |
12968
Rep 18,715
The more you risk you are willing to take, the better the reward. Not only in car mods, life in general too.
Miko M6653.50 |
01-10-2019, 11:21 AM | #31 |
///MD
1378
Rep 3,998
01-10-2019, 11:23 AM | #32 | ||
///M
6654
Rep 3,683
Life is too short...enjoy your life
///M |
r33_RGSport12967.50 soooma1377.50 |
01-10-2019, 05:08 PM | #33 |
407
Rep 2,704
I'll bite in this thread.
The racechip fools the MAF sensor into thinking that that car can have more boost, which in turn activates the rest of the system to add more fuel and maybe timing. Maybe timing again. ? And fully relies on riding the OEM knock sensors for feed back. If it even has that capability to reduce after knock is determined, lol. good luck. My bet is when is knocks it already at your door, and this little chip did not pull back timing when needed Personally I would wait for a flash tune that is custom based on your needs, (mods). |
01-10-2019, 10:41 PM | #34 | |
12968
Rep 18,715
That's what difference RaceChip to some other brands. The max boost gain are pre-set based on their R&D process. It is not something that you can just crank up the boost until you fight the DME. That's how people blew their motors back in the day with HKS EVC which tricks the vacuum system of the Turbo system. While some other piggyback brand allows end-user to change the boost target by themselves. While some are setting the boost target aggressively high to get more sales by claiming more hp gain than others without doing a proper R&D. Not saying that DME flash tune is bad, you just need to understand it better and know what you are getting yourself into. Understanding AFR and timing is one thing, but to properly tune an engine, there are more into it. Maybe the DME tuners can explain more, I hope they are willing to share info.
soooma1377.50 |
01-15-2019, 09:47 PM | #35 | ||
///MD
1378
Rep 3,998
Life is too short even if you live to be a 100!!
As what really counts is the few moments we are really happy and excited! -Kids, Family, Success, Career, Helping others stand on their feet (Paying back and sometimes forward), Travel, Seeking the truth, Reading, Hobbies eg ///Madness - |
01-15-2019, 09:51 PM | #36 | |||
12968
Rep 18,715
Some tricking more sensors, some less sensors. It is like a cook tricking your taste buds with some spices.
01-15-2019, 09:54 PM | #37 | ||||
///MD
1378
Rep 3,998
01-15-2019, 10:20 PM | #38 | |
12968
Rep 18,715
Now as far as boost delay, I only can think that it probably caused by a slow processor speed of the piggies, not caused by the piggy system design itself. While DME ECU Flash, it is different ball game. Technically you can't compare the two on the performance. DME ECU Flash is remapping to make the engine function the way you want it. Doing it right, you will be good. Doing it wrong, you will be toast. A good flash map creator need to know more than just AFR. PS: Not saying that DME ECU Flash is bad. Just not my cup of tea playing with fire on daily/lease vehicle/on-road car. Besides, it is funny when most are worry about warranty, but then pulling a trigger on flash tune. The whole idea about piggies are to have fun with ease and safety parameters that has been set in the ECU by the car's manufacturer who designed the car.
soooma1377.50 |
01-16-2019, 12:09 PM | #39 |
Joint Chiefs of Staff
24190
Rep 190,804
Hi OP,
Are you asking about boot levels? Both can give you same power since you can just adjust the boost to whatever PSI you are comfortable with. The main difference between all 4 tunes is features not power
01-16-2019, 02:25 PM | #40 |
194
Rep 459
ok stage 1 Burger BMS kit produces a fixed 664whp at 21psi (very quick install)
JB4 BMS makes map1 664whp (21psi), map2 676whp (23psi) and map3 694whp (25psi)on race fuel What is the Racechip producing in dynojet whp power and which maps?
01-16-2019, 04:10 PM | #41 | |
3619
Rep 4,532
RC on SP7 produces a solid 21 to 21.5 psi on my logs. Strictly talking piggy boost, you will make the same rwhp static with Dinan, JB4, RC, etc,etc,etc IF THEY ARE ALL SET TO THE SAME ADDER. No magic in the HP number if the boost is the same amount and the unit is a piggy. There is some magic in other areas. |
01-16-2019, 04:17 PM | #42 | |
194
Rep 459
01-16-2019, 04:29 PM | #43 | |
12968
Rep 18,715
01-16-2019, 04:53 PM | #44 | |
194
Rep 459
Anyone with Racechip planning to dyno the car? racechip: 747ps = 737HP = 650whp (15% loss) stock: 665ps = 656HP = 571whp (15% loss) 79whp increase
