BMW M5 F90 (2018+) General Forums iDrive, Nav, Stereo, Bluetooth, Electronics    Anyone adding a sub to B&W system?
      12-26-2018, 09:37 PM   #23
elitex
elitex's Avatar
Drives: 22 M8C Coupe, 21 X5MC
Originally Posted by shellbmb View Post
Originally Posted by elitex View Post
I already did this to my car. Added a JL Audio 12w6 in a sealed box. No need for pass through, plenty of bass makes it in the cabin.
Thanks for the information. Was it a custom box, or did you buy one of JL Audio's pre-fab boxes/driver setup? If so, which one? JL amp as well?
Are you pleased with the result?
I went with the pre-made JL sealed box. http://www.jlaudio.com/cs112g-W6v3-c...-systems-93307 . Paired it up with Alpine 600 watts mono amp. Sounded pretty good.
Previous
21 X5M MBB, 20 Evora GT, 20 C63S Coupe,19 X5 50i, 18 Giulia QV, 18 M5, 17 Evora 400, 18 LX570, 17 GT350,18 M4 Comp,17 R8 V10 ,17 M3 Comp,17 GT350,16 Escalade Plat ESV, 16 570S,16 911 GTS,15 M5, 15 LX570, 13 M5,13 Viper,14 Cayman S,13 M3,13 S4,10 RX8,12 A4,10 G37, 04 Mini Cooper S, 08 Scion TC, 06 Altima V6, 05 Altima, 01 Altima, 00 Altima, 94 Explorer, 92 Toyota Pickup, 98 Altima
      12-27-2018, 04:19 AM   #24
Who's on first
Who's on first's Avatar
Drives: A-10C
How do you have it secured? Any pic's?
      12-28-2018, 12:07 PM   #25
zuschnell
zuschnell's Avatar
556
Drives: '19 m5, '18 991.2 gt3,
Any of you check out this thread? Pretty cool solution, though requires a custom enclosure.
Bowers & Wilkins - Adding more Bass https://g30.bimmerpost.com/forums/sh....php?t=1443805
Gone but not forgotten: '10 X5M, '14 550ix, '17 M3 zcp, '11 aw e90 M3 zcp, ?11 sg e90 M3, '17 X5M, 19 F90 M5
Current: ?13 e92 m3 ESS 585, 22 f95 x5m Comp, Track - '18 manual 991.2 GT3, Wife's family truckster - '20 Volvo XC90 T8
      02-17-2019, 06:20 PM   #26
shellbmb
shellbmb's Avatar
Drives: 2022 F90 M5C
Did you have to wire a sub-control knob to the dash anywhere?
Also, how are you enjoying it?
      02-17-2019, 06:54 PM   #27
jeffscott1
Drives: 2019 M5 Competion
JL audio amps to all speakers and a dedicated JL 1000 watt amp to the w7 12 sub
2019 M5 Comp, 2017 AMG GTC Edition 50 Coupe, 2016 Porsche GT2 RS,
2018 Ferrari California T, ,2017 Corvette Z06 C7.R, 2016 Aston Martin V12 Vantage Manual, 2019 Ferrari 488 Pista
      02-17-2019, 07:00 PM   #28
Who's on first
Drives: A-10C
What was the cost, all in?
      02-17-2019, 07:01 PM   #29
jeffscott1
10k
      03-24-2019, 01:43 PM   #30
Terrier15
Terrier15's Avatar
Drives: 2019 BMW M5 Competition
I'm putting in a trunk subwoofer for my HK system. For me, it's crucial not to weigh the car down or take up all my trunk space, so I am trying out a Digital Designs SL710 redline slim profile 10" sub (just one), paired with a DD amp. I'm Having a custom box built that will match the trunk carpet and will face the sub downward so the whole thing looks factory. It'll only sit up about 5", and while taking the full width of trunk space pressed up against the pass through, won't fully impede it if I want to use it. Should be done in the next week and I'll post a review and pictures.
2019 M5 CP
formerly - 2018 M4
and before that - 2013 M3
Appreciate 4
      06-01-2019, 02:17 AM   #31
BMWAUDIO
64
Drives: F90 M5 Frozen Gray , 997 C4S
I'm sorry to tell you the Jl enclosure with the 8w3v3 woofers in it has a slot port on both sides . You need at least 2-3 inches from the sides for ports.
There are other solutions if you want to upgrade the under seat subs if you don't have b&o .
Couple of things I found out today. There is a very small sub under both front seats. Just move the seat all the way forward and you can see it from the rear seats. It's very small and I'm surprised that's all they did for the upgraded B&W system. I'm not going to waste my time trying to replace that.
Also, stopped by my local car stereo place. JL Audio makes an enclosure that has two 8" 8W3v3 speakers in it. It fits perfect in our trunk. See attached picture. They also make a powered version of this, but it's a bit wider. They didn't have one in stock so I couldn't test fitment of that one. And it only weighs 32 pounds.
I think there are ample places in the trunk to get a speaker level input for a converter as aren't the amps for the system housed behind the liners? Adding an amp should be easy since the battery is in the trunk. The only thing they'd have to run up front is a bass control knob.
So overall it seems fairly easy to add. Box w/ speakers is about $500 on sale. So not cheap. Amp can range from 250-600 depending on which level JL amp you go with. So I figure 1000-1500k with misc parts and labor.
      06-01-2019, 10:37 AM   #32
MWcoupe
24k GOLD
MWcoupe's Avatar
Drives: Mineral White M4
https://technicpnp.com/product/logic...sub-t-harness/
So we need this for a easy pnp
What's this blue device in the video
Is that from technic as well?
      06-02-2019, 08:26 AM   #33
shellbmb
shellbmb's Avatar
Yeah, I was worried about that so I kind of checked that one off my list. Honestly put this project on the back burner for a bit, but was probably going to look at one of the H.O. Wedges instead. I think those are ported to where it would be facing the trunk so it might work better.
I do have the B&W option and funny, my sub under the driver's seat was blown. I'm waiting on a replacement from Germany under warranty.
      06-08-2019, 02:20 PM   #34
stocksure
31
Drives: '19 BMW M5C
I'm about to add an AudioFrog 12" sub in the trunk on my F90. Hopefully this trunk isn't too insulated.
On a 2016 M3 I replaced the underseat speakers with Earthquake SWS 8XI and ran them as subs from a new amp. I'd assume they would fit in the F90 as well. I remember the installer making some sort of MDF ring to make sure they fit perfectly. https://www.sonicelectronix.com/item...d-SWS-8XI.html
2019 F90 M5 Comp | Marina Bay Blue, stealth PPF
2016 F80 M3 | Mineral White - sold
2011 E92 M3 | Jerez Black - sold
2001 E46 M3 | Carbon Black - sold
      03-09-2020, 03:46 PM   #35
jmf
Drives: 2018 BMW M5
It's not the B&W, it's something else...
I was just thinking about adding a sub. Then I hopped in the car, heard the most incredible bass for about 5 seconds from my music and then the base/volume got clipped.
I'd never heard that bass before, but i'm not always listening to something w great bass for the first 5 secs in my car either. I notice the volume gets clipped EVERY time, and apparently the bass range does too. I'm on a Google Pixel 3XL, bluetooth, spotify, B&W sound.
Has anyone figured out how to get around this?
      03-09-2020, 06:04 PM   #36
subterFUSE
subterFUSE's Avatar
564
Drives: 2023 Audi R8, 2023 Audi S8
You are saying you are running the factory system and running it into distortion? Or you upgraded your sub and that's what is distorting?
      03-14-2021, 01:24 PM   #37
Terrier15
Terrier15's Avatar
I just realized that I never posted the pictures of my sub. I ended up facing it towards the backseat as there are rarely people in the back. I simply used two strips of Velcro to secure the box, so it doesn't fall over when I punch the gas. Also, note the positioning of the amp under the trunk floor.
2019 M5 CP
formerly - 2018 M4
Jamesmick131.00
      03-21-2021, 10:13 PM   #38
TXDroneRacer
TXDroneRacer's Avatar
Drives: 21 M5 Comp, 21 X5 M50i
Terrier15 Did your solution make a significant difference?
How do you control the amount of added base?... Any remote control?
What adapter did you use for the line-in?
I would love to see additional photos showing power connections, audio adapters, how you mounted your amplifier near the battery...
      03-22-2021, 12:25 AM   #39
GTATX
GTATX's Avatar
Drives: 2020 M8 Comp First Edition
What wires did u tap into? Thanks
GT
2020 BMW M8 Comp First Edition
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
2018 Maserati Ghibli SQ4 GranSport
      03-23-2021, 09:52 PM   #40
BrntRubber
BrntRubber's Avatar
United Kingdom
69
Drives: 991 Speedster and F90 M5
I am about to order a jl 12" w6v3. Excited
      03-23-2021, 09:54 PM   #41
BrntRubber
BrntRubber's Avatar
United Kingdom
69
The earthquakes are an option for the f90 m5
      04-03-2021, 07:04 AM   #42
BrntRubber
BrntRubber's Avatar
United Kingdom
69
Advice please guys.
I am addi g a 12 jlw6 in the trunk of my 2018 F90 m5 noncomp with b&w. The sub will be in a jl sealed enclosure and easily removable with the amp under the trunk floor.
My installer is saying he can get the feed from disconnecting one of the underseat subs and using that to feed the trunk sub. He said this will allow the bass to be controlled via the bowers and Wilkins idrive eq.
Can someone please confirm this is the best option? Will this cause any issues or limitations?
Thanks
      05-28-2021, 11:32 PM   #43
GTATX
GTATX's Avatar
Just to let everyone know for an easy option which bangs. I ended up getting
https://www.bestbuy.com/site/kicker-...?skuId=3526208
of which I had experience in my Tundra. I tapped into sub wires and installed it on top of rear deck in the center. Sub comes with 2 straps which can be looped around center head rest and that's all. All I can say is that my son said, now we have massaging back seats as well due to bass. I have set the gain to little less than half and bass is just amazing. Sub wouldn't work in trunk due to its design and size. Its more suited for inside cabin verses outside. I'll add some pictures to show install tomorrow. Thx
GT
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
      06-25-2021, 07:50 PM   #44
ResidualJinx
114
Drives: 2018 BMW M5
Man GTATX you got some pretty decent mods going on bro!! Looking forward to the installed pics. I'm still looking to score a 12.3 screen but couldn't find anything promising on eBay
GTATX1105.00
