BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    Break "Squeal"
      11-14-2018, 07:34 PM   #1
GeoRod7
Da'Toy
Drives: F90 M5
Break "Squeal"
Having a very loud "Squeal" during low speed breaking, thoughts or suggestions ?,
Dealer has the car for now over a week for the third time
      11-14-2018, 07:37 PM   #2
GUNGASLOW
192
Drives: 2019 M5
Hard brakeing once every couple days makes it go away for a few days
      11-14-2018, 08:50 PM   #3
dk79
Drives: 2018 F90 M5 Marina bay blue
Took it to dealer for the same thing. They said its normal for this car. Even 911 turbos squeal at low speed braking and Porsche actually made a video explaining it, due to big size rotors and harmonic balance, large disc actually acting as speakers when brake pads rub on them.
      11-15-2018, 05:33 AM   #4
JOHNBMWM5
Live for today tomorrow never comes
JOHNBMWM5's Avatar
United Kingdom
1989
Drives: 2022 LCI Marina Bay Blue/ Smok
Never ever had brake squeal on any "M" car I've owned, and I have had them all.
Snow Foam and Jet wash the disks/calipers each time you wash the car.
I have the CCB now same NO noises.
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather
      11-15-2018, 11:28 AM   #5
Fegelein
Fegelein's Avatar
519
Drives: 2021 X5 M50i
There is another thread on this and we all seem to be having this issue, although intermittently.
      11-15-2018, 11:45 AM   #6
turbomcgee
75
Drives: 2018 M5
I had this issue, then I bedded the pads (hawk style) as if I just installed them (only had 50 miles anyway) and they've been perfect every since and much more linear.
      11-15-2018, 08:40 PM   #7
desertfox73
676
Drives: 2018 F83 / 2018 F85
CCB may be different - OP, do you have steel brakes?
F10 M5 had this issue, there are tons of posts about it. In the end, I think the only real solution was hard braking at higher speed (coming off a highway, for example). Then it would go away for a while.
I experienced it with my F10, terrible noise. Then I switched to an F80 M3, only to have the dreaded "rock stuck between the brake disc and dust cover" issue.
      11-16-2018, 02:38 AM   #8
JOHNBMWM5
JOHNBMWM5's Avatar
United Kingdom
1989
My had steel as did my M6 GC CP never had any noise doing what I said.
PS) I have never bedded brakes in, just drove the car and let them settle. This includes the CCB and do they stop.
      11-16-2018, 02:59 AM   #9
JSR2018
30
Drives: BSM F90 Competition
Dealer told me that this can be caused by using an acidic wheel cleaner (I have not used acidic wheel cleaners for years) and then not driving the car straight away, the cleaner eats into the pads/discs causing this apparently. Not sure if its BS but figure its worth passing on.
Oh, and his comment was pro-active, I have no noise (yet) from the brakes.
      11-16-2018, 03:02 AM   #10
JOHNBMWM5
JOHNBMWM5's Avatar
United Kingdom
1989
Well i was advised and use a PH neutral Snow Foam, that MAY account for my trouble free silence.
      11-16-2018, 05:40 AM   #11
desertfox73
676
Sounds like you're one of the lucky ones. Tons of threads from M5 / M6 owners about the issue. BMW even issued a TSB about it.
It bothered some, while others just chose to live with it.
      11-16-2018, 07:41 AM   #12
JSR2018
30
I always us PH Neutral snow foam to be fair. I was using ValetPro but have just switched to Autoglym Polar Blast....its really really really good.
      11-16-2018, 12:37 PM   #13
neohh
168
Drives: F90 M5
My dealer "if you don't want the squeal don't buy a M car".
      11-16-2018, 06:39 PM   #14
shellbmb
shellbmb's Avatar
Drives: 2022 F90 M5C
300 miles into ownership and already squealing. Like someone else posted, it's not an issue, but a feature. At least the cabin is so insulated you barely hear it. I'm going to try some bedding in procedures once break-in period is up. Fingers crossed, but I expected it so it's not as bothersome.
At this point it's buyer beware. Some cars have it and some don't which seems very odd.
      11-16-2018, 10:53 PM   #15
soopa
113
Drives: 2018 F90 M5
Squealing started on day 1. Goes away after a good wash but comes back. I could care less.
      11-17-2018, 02:47 AM   #16
JOHNBMWM5
JOHNBMWM5's Avatar
United Kingdom
1989
I am using this at the moment, seems good.
Dirtbusters ph neutral snow foam
      11-17-2018, 08:27 AM   #17
neohh
168
Drives: F90 M5
It's fine in the summer where you can power wash the disc every week, but in the winter it's a big problem since you won't be able to power wash it.
      11-17-2018, 10:39 AM   #18
GUNGASLOW
192
Drives: 2019 M5
Wd40
      11-18-2018, 08:11 AM   #19
soopa
113
Drives: 2018 F90 M5
You're probably right but at least I know the brakes are working!
      11-18-2018, 11:08 AM   #20
Neptune7
1433
Drives: M5 CS
There seems to be more going for the $9000 carbon ceramic brake option every time I read about this topic! I'm feeling a tinge of regret not electing them for my car. Almost no one has complained of brake squeal on CCB's on the F90.
      11-18-2018, 02:29 PM   #21
Jez_zza
Jez_zza's Avatar
Spain
439
Drives: M5 F90
I had the same lazy feedback from my dealer !
That's a lot of rubbish, my last 2 M3s did not squeal but the M5 is just horrible.. I was also told that with time the brake pads will get more used and the noise will fade away.. again a lot of nonsense ?!
I'm taking the car to another dealer to get this looked at
      11-18-2018, 05:47 PM   #22
gblansten
gblansten's Avatar
1977
Drives: 23 Tesla S Plaid
If something is broken then I would get it fixed.
