11-08-2020, 05:47 AM | #1 |
51
Rep 104
Accessories that come with 2021 M5?
Hello all!
Recently picked up a 2021 M5 w executive package and drivers assist plus package. Also opted for the 20” bi spoked wheels. My question is: what accessories was this supposed to come with? These are why I have: Manual I have 2 keys, 1 key card Tire inflation/sealer kit 2 tow hooks and a screwdriver Am I missing a jack or something? I assume we don’t have a spare wheel? Thanks |
11-08-2020, 07:49 AM | #2 |
265
Rep 720
That is correct. No spare. You can’t even (easily) pull up the floor in the trunk, where a spare would be. If (God forbid) you have a flat by the side of the road, you will need to use the canister of sealant and pump provided, and then drive to the nearest place you can have your tire repaired or replaced. Kinda unnerving, I know, but that’s what BMW does now, in at least their M cars. I had the same in my 2013 e92 M3. All the other stuff sounds like what I have, except I am not sure I have two tow hooks. I’d have to look again.
11-08-2020, 05:18 PM | #4 |
265
Rep 720
The assumption must be that there is no need, I guess, if the sealant and pump work as they should, as there is no spare to install. Oh, and also, cost... Btw, I checked and I do have two tow hooks. Wondering why...?
11-08-2020, 07:47 PM | #5 |
342
Rep 319
I would assume to be able to pin down the front and rear on a flat bed tow truck or trailer?
Current - Second 2023 XM (first one was taken back by BMW) and 2023 X7 40i
Past - 2009 X5 35d, 2011 MB E350, 2011 740i, 2015 X5 35d, 2018 M550i, 2019 X5 40i, 2021 M5C |
11-08-2020, 08:07 PM | #6 |
51
Rep 104
So, the fix a flat kit has a foam cutout for ONE tow hook. The other tow hook I have has no “home” to rest in. My M5 was transported from another state so I assume they used two hooks to secure the vehicle in transport. Every single other car I’ve had has always come with 2 tow hooks and a scissor jack that were neatly packed away in a special spot of the trunk—even if they didn’t come with a spare.
So I’m bewildered by the lack of a jack and only one tow hook in a 100+k car! |
