Tim_s's 325i n53 e91 lci with 330i flash and 3 stage manifold
06-13-2017, 03:39 PM | #1 |
40
Rep 71
Hi guys,
Thought I'd say hello on here and post about my e91 lci 325 sport that I bought a month or so ago. I bought it to accompany my 4dr e36 m3 evo and have been busy doing odds and sods to it since I bought it. I actually wanted a 330 with a pano roof, but this one came up pretty cheaply with a few issues but it had a nice spec with pro cic nav, heated seats, folding mirrors etc in le mans blue with oyster leather, and in the interest of time and appreciating that there aren't loads of high spec'd ones out there I decided it was worth a go. Stuff I've done so far. Dent in roof taken out by dentman: Before After (they're all reflections, no dent at all now) New ABS sensor and clean up/ ACF50 of underside: Before After Fix bodged downpipe Before - actually worse than it looks here: After Nav map update, coded the auto folding mirrors on the key Cleaning New performance BM gearknob and gaitor, Also replaced a few bits of trim, some rusty bolts, front undertray, dealer plates etc. Combox fitted: Driver's seat redyed: 330 3 stage inlet fitted Gave the inlet ports a good clean with first seafoam in the inlet, then carb cleaner and toothbrush Not really got any great ones of the finished job but they look good now. Then coded on a new tuned map that I bought, supposedly 265bhp, certainly with 9000 odd bytes different in the parameter space it appears to have quite a few differences to the original! This made part load feel much better esp at low rpm, I'm not sure but still think there's some more performance to be found however. So... with a lot of research, I managed to work out how I could flash an original 330i map on to the car without tripping any errors/DTCs/limp mode etc. WinKFP flashing: What happens when you try to flash a 330 map on to a 325 And 2FA3 and 2FA4 DTCs logged. To get it working required modifying the binary, checksum correction and reflashing. Flashing rig No idea how well it works as I've not yet driven it on this map, but pretty confident I should have the full 330 power now! Lastly, got my DA polisher on it: Thanks for reading! Last edited by tim_s; 06-13-2017 at 03:48 PM.. |
06-13-2017, 07:16 PM | #3 |
7
Rep 43
Lovely, you certainly know your way around the system with all the tinkering and wires!
Would love to hear more about the process involved with dyeing the seat, turned out really well! |
06-14-2017, 03:29 AM | #4 |
624
Rep 3,200
Drives: E92 325i MSport Coupe
Good work Tim! Two questions:
1. How much was the undertray? 2. How bad were the valves before you cleaned them? I'm thinking they were nowhere near as bad as the pics I've seen of the turbo engines? Any 'before' pics?
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
06-14-2017, 05:04 AM | #5 |
40
Rep 71
06-14-2017, 05:05 AM | #6 | |
40
Rep 71
Seat dyeing is something I've done a few times now. This one I haven't been as thorough as with other cars, mainly as it really didn't need it. On this one I just used alcohol, two dye coats then a couple of semi-matt finishing coats. I'll probably go back and stick some gloss coats on and then some more semi-matt as that gives a more durable finish. In terms of the process, here are some more instructive pictures of a recolour job I did on some e63 m6 seats to go into my e36. first off acetone and rubbing alcohol: Sponged on first coats into crevices: Then spray coat, can still see some ghosting here: Then final dye coats: Then final pics after sealing and semit-matt finishing coats |
06-14-2017, 05:12 AM | #7 | |
40
Rep 71
2. Valves were pretty good before (but only got to see them after I'd done the seafoam inlet clean). I'll have a goose later for some proper before pics. There was some buildup on the backs of the valves and on the bottom of the stems, but nothing major. Carb cleaner and one of those cheap disposal electric toothbrushes worked really well. Wouldn't mind going in there again to give it another clean as it was pissing down when I did the job and so wasn't too keen to mess about for too long! Your 325 n53 has been remapped hasn't it? What flash has it got on it and what are your experiences? Quite keen to see how the proper 330i flash I have on there now compares to the generic flash. |
06-14-2017, 05:28 AM | #8 |
624
Rep 3,200
Thanks Tim. No mine isn't mapped. Just not worth the money for the very small gains, in my opinion. Do have K&N, silicone induction pipe and Performance exhaust though...
Do you mind posting the link to the Chinese supplier of the undertray please?
06-14-2017, 05:41 AM | #10 | |
40
Rep 71
Do you have an n52 then and not an n53? The gains on an n53 of over 50bhp are obviously quite significant. I was actually really impressed at the factory air filter on the n53, would be surprised if there are any gains at all to be found there. How do you find the BMW performance exhaust? |
06-14-2017, 06:45 AM | #12 | |
Rep 31
06-14-2017, 07:46 AM | #14 | |
624
Rep 3,200
Perf exhaust is the best mod I've done to my car (well maybe second to my Ohlins coilovers). Fantastic sound. Hardly ever use the ICE as I'm always listing to that PE roar!
06-14-2017, 07:50 AM | #15 |
624
Rep 3,200
Hmmm. If you see a repeat of that, let me know. Cheapest I can see on eBAy is from Poland at about £60...
06-14-2017, 09:33 AM | #17 | |
40
Rep 71
For what it's worth, I expect more or less all the companies out there are all using the same generic flash that I bought and ran on my car until I managed to get a 330 map to work (it also was a claimed 265bhp one). That map made quite a difference, but it was mainly felt on part load low rpm - the stuff you actually use all the time. Even if it 'only' gave 12-15bhp at the top (I don't use it enough up there to quantify and the car's not been anywhere near any rollers), that's still a great result given the transformation to driveability. Like you say, each to their own, but to choose other bolt-on performance modifications over a flash on a torque-limited ecu seems a bit misguided. The flash I put on had some 9000 bytes altered in the parameter space. Basically pretty much all the maps I've identified in the binary were modified. That's more parameters altered than between a factory 325 and 330 map. Last edited by tim_s; 06-14-2017 at 10:27 AM.. |
06-14-2017, 10:00 AM | #18 | |
40
Rep 71
The difference is all in the flash. Again, not sure how the generic flashes compare vs a proper 330i flash until I've used mine some more. |
06-14-2017, 10:18 AM | #19 | |
40
Rep 71
You definitely need to sort out the engine mgmt light and look at all your DTCs before going any further. You ideally want to diag it on a proper BM tool - INPA would do. You could then also read off your ZB etc and see whether it changes with a flash! |
06-14-2017, 10:25 AM | #20 |
40
Rep 71
06-15-2017, 06:55 AM | #21 | |
Rep 31
What about this one for example? http://www.ebay.co.uk/itm/BMW-FAULT-...4AAOSwZKBZIMlt Whereabouts are you based? Just wondered if you were local, I'm in Cheshire, North West |
06-15-2017, 08:16 AM | #22 |
40
Rep 71
Yup, that K+DCAN lead there is fine, am sure the software is too - but you can just download it from the web and save some money! Probably the simplest of all is to get an ELM327 bluetooth usb adapter and use Carly or Carista, but it will give you less info and is less powerful. All depends on how good a tool you want and how much effort you're prepared to invest. If you google around e90 diagnostics and INPA/ISTA it will throw up loads of info.
I'm in London I'm afraid! I come to west country quite a bit but rarely up north! |
