08-20-2020, 05:41 PM | #45 |
Petrolhead
1949
Rep 3,520
I agree. But then, we’d miss out on parking mode. But I’d still prefer a hidden power socket over the one in the centre console. I thought I’d route the long wire to the trunk and use the power cable in there but I want to hardwire mine to enable parking mode.
Current:
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige |
08-21-2020, 03:53 AM | #46 | |
561
Rep 1,181
I had the Thinkware voltage configured quite conservatively, but would still see issues after periods of short journeys or holidays. Used to get all sorts of weird electrical faults - handbrake was usually the first one. On one occasion, parked at the airport for a week in the winter, car wouldn’t start. Hooking the battery up to a charger and reconditioning it always fixed it but it was a bit annoying. |
VipinLJ1949.00 |
08-21-2020, 09:06 AM | #47 | |
Petrolhead
1949
Rep 3,520
I was hoping the poster in the previous page who has the exact same dash cam I got hardwired would check his account but it looks like he doesn’t check his account here anymore which is unfortunate.
Current:
08-21-2020, 09:14 AM | #48 |
561
Rep 1,181
I recently had a Thinkware Q800 with an iVolt battery pack installed in my wife’s new 118i. Works really well. Battery is charged when the engine is running and think takes up to 45 mins to get from flat to fully charged.
The iVolt should be good to keep parking more running up to the 48h limit in the Dashcam. I just waiting for Thinkware to release the T700 as keen to get one with an inbuilt SIM so you get instant alerts. |
VipinLJ1949.00 |
08-21-2020, 09:15 AM | #49 | |
Petrolhead
1949
Rep 3,520
Current:
08-21-2020, 09:24 AM | #50 |
561
Rep 1,181
08-21-2020, 09:30 AM | #51 |
Petrolhead
1949
Rep 3,520
The cellink neo is the one that seems to be selling like hot cakes here. Costs $330 plus tax for a 24-48hr boost.
Current:
08-21-2020, 10:00 AM | #52 |
561
Rep 1,181
I was thinking of that for my car, but it seems to be overkill for the Thinkware dashcams at least, which have a hard stop at 48 hours. I don’t understand why they don’t have an option to say it’s connected to an external battery and not the car battery and continue recording until its dead.
VipinLJ1949.00 |
08-21-2020, 03:10 PM | #53 |
Petrolhead
1949
Rep 3,520
themur I got a notification saying you’ve replied to a post of mine whereas I can’t see anything on here. Happens to me a lot in this forum. I get lots of notifications but don’t see anything. I think it’s because the forum is wonky for me. If you could repost, that would be great.
Current:
08-21-2020, 05:16 PM | #54 | |
67
Rep 117
I tried hardwiring but I would always get battery management warnings though it would never kill my battery with cutoff. To err on the side of caution I opted for a hefty priced battery. |
VipinLJ1949.00 |
08-21-2020, 05:27 PM | #55 | |
Petrolhead
1949
Rep 3,520
And regarding the warnings you got. Was it when you went to start the car or when you were driving around? After reading about all these warnings, I think I'll just wire it to the socket in the trunk and then get a battery later to use parking mode. I don't want my car throwing up errors if I can help it
Current:
08-21-2020, 05:43 PM | #56 | ||
67
Rep 117
Only caution with the cigarette adapter method is hearing that the cheap parts would cause the adapter to overheat but again I never went this route so hopefully it won't be an issue. |
VipinLJ1949.00 |
08-21-2020, 08:07 PM | #57 | |
Petrolhead
1949
Rep 3,520
Thank you very much for all the info! It definitely did help me a lot. Can't wait for the hardwire kit to reach me.
Current:
08-27-2020, 11:58 PM | #58 |
Petrolhead
1949
Rep 3,520
I finally mustered up the courage to hardwire the dash cam today. I spent lots of time reading up on fuse taps and hardwiring and potential problems and decided to test my luck.
I followed the method my3ung posted in the previous page. The worst part is the location of the fuse box in the footwell. Today was the day I discovered how flexible I can be! I used the screw holding the passenger airbag to ground the dash cam. A 10mm wrench socket was what got the nut loose enough for me to slide the ground ring between the washer and the metal bracket. Tightened it and everything was as good as it was before. I also disconnected the battery before messing with the screw, just to be on the safe side. I didn’t want the airbag exploding on me while my face was right next to it, in case something went wrong. I set the voltage limiter to 12.4V. I’ve seen people set it to 12 and 12.2. My car is always garaged and never parked in a public space overnight. So I don’t need more than 5hrs of parking footage at most. I also don’t want my battery dying out on me. I’ll check tomorrow morning and see if the car throws a hissy fit. If so, I’ll probably have to resort to using the charger socket in the trunk or centre console. If it doesn’t, I might try 12.2V. All in all, I’m happy with the outcome for now. PS - I was surprised at how horrible the headliner in my car is! I went to route the wire inside the headliner and thought I’d have a tough time hiding the wire. But lo and behold. I put my fingers between the glass and headliner and found out that there was more than enough space and it already appeared to be separated/separating. I also managed to push it in near where the headliner meets the A pillar airbag cover. All this without isn’t any force. I checked the headliner of my Audis and those are much much better. My car is due for service soon. I’ll be checking out a few G20s on the lot to see if those have similar headliners.
Current:
minakoto0028.50 |
09-02-2020, 08:33 PM | #59 |
15
Rep 44
Hey everyone. I just got a G20 330i Xdrivd and got a BlackVue with power magic pro. I just got it installed, and the installer said that due to BMW’s power management system, he had to wire it directly to the battery and that that would be fine because the power magic pro has a cutoff.
Reading your posts it sounds like there are alternatives. Since he already did the install, however, do you see any downside leaving it connected to the battery directly? It seems like you all mostly used the fuse box in the front - we went through the fuse box in the trunk. Maybe that’s why he couldn’t go through the fuse box? |
Soul_Glo13395.50 |
09-02-2020, 11:27 PM | #60 |
Petrolhead
1949
Rep 3,520
I've hardwired my dash cam as mentioned in my previous post. Almost a week now and no issues at all. Mine records when it detects impacts or any motion in its field of view. It easily runs for 12hours without any problems (I've set it to record for 12 hours on my cam).
No voltage drops. Car doesn't show any errors. I've also set it to switch off when the battery charge drops to 12.4v. People usually set it to 12.2v. For my usage, I don't see a need to change the setting for now. So far, I'm happy.
Current:
09-09-2020, 08:42 AM | #61 | |
15
Rep 44
09-12-2020, 02:47 AM | #62 |
141
Rep 395
I was having issues with the power magic pro when set to 12.5v it wouldn't even record for one hour so I went and set the cutoff to 12.0v which makes it record more but now getting the discharge error when I get into the car the next day.
Doesn't help the car gets barely driven anymore But I do keep it plugged into the wall so I am hoping that charges both batteries (could be wrong though) Thinking about a Cellink/Blackvue battery pack to get rid of that |
09-24-2020, 01:42 AM | #63 |
13396
Rep 7,484
For anyone allowing their starter battery to drop below 12.4v, don't!
Read this: https://www.optimabatteries.com/en-u...mber-batteries The article mentions it briefly but there are more detailed ones around which I have lost the links too. Either limit your parking mode use off your starter battery or install a dedicated power bank. I have the Cellink neo 6 but there are many alternatives. On my 2 ch set up parking mode is around 18-20 hours with the battery bank. If you can then use a battery tender once a week if you're driving less than 20 minutes once a week. Mine is a Thinkware F800. |
BigWagonFan34.50 |
09-24-2020, 04:59 PM | #64 |
659
Rep 1,480
Drives: 2020 M340Xi (G20)
Hi,
OK, I've done some checking things out and have narrowed my options for a dash cam down to these two:
Thanks
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
09-24-2020, 07:28 PM | #65 |
Petrolhead
1949
Rep 3,520
I've read OK reviews about the Garmin and very good reviews about the Viofo A129 Pro Duo. I would get the Viofo because I have the A119 V3 and video quality is stellar for what I paid for it. I'm extremely impressed by Viofo. I haven't personally used a Garmin or any other dash cam but yes. Just my $0.02.
Current:
RSnic658.50 |
10-02-2020, 10:31 AM | #66 | |
659
Rep 1,480
Hardwire Kit Question
You mounting looks terrific!! Did the hardwire kit for your camera have a "brick" -- a step down transformer from the 12v to something less?? If so, how did you handle that? The reason I'm asking is that I just got a VioFo A129 Pro dashcam and its hardwire kit has one of those "bricks" (albeit fairly small)? Thanks
Al
