Performance Suspension on clearance from tischer $133.06!?!?!?!?!
11-19-2010, 09:58 PM | #24 |
Moderator
618
Rep 10,858
Does it have sports seats, sport steering wheel, etc? The package is termed "ZSP". If you don't have it you want it, depending on how violent NYC potholes are on your back.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
11-19-2010, 10:01 PM | #25 |
767
Rep 2,362
nah im only going to be here for another week, then id be up in NH, roads are beautiful there!!
so all i need are the ones tischer is selling now? my car feels so much stiffer and i can feel almost everything on the road...already switched to non rfts... excuse the noobness, totally stepping into new territory in suspension world Last edited by WingZeroX5; 11-19-2010 at 10:08 PM.. |
11-20-2010, 12:41 AM | #26 |
8
Rep 119
Stressdoc you have any side pics of your e90 with the performance suspension and springs? Just bought the suspension still trying to figure out if i want the performance springs or go after market.
Thanks! |
11-20-2010, 01:48 AM | #27 |
530
Rep 6,149
I believe this is on the VIN plate on inside the drivers door or under the hood. Not sure which but it is one of those.
If you will be purchasing ANY AT&T services online or in store could you mention that you were referred by me? My Employee Referral ID is eo4489. This would be a great help and it costs you nothing, thank you!
11-20-2010, 02:27 AM | #28 | |
77
Rep 940
11-21-2010, 10:52 AM | #30 | |
Moderator
618
Rep 10,858
IMO the best solution here unless you are anal about sticking with BMW parts is to get higher quality Swift springs. Surely Harold can recommend a good match. Broken record here, different strokes for different folks etc., but I would strongly recommend against "dropping" the car for appearance. The point of a BMW is the handling. Why fu#%^ up the engineered design of the suspension? Do it right.
11-21-2010, 11:47 AM | #32 |
991
Rep 1,495
Do these fit an E92? I know KW coilovers are interchangeable from E90/92 (non-xi of course) because I'm running E90 V1's on my E92 right now but thinking about going for a "simpler" OEM set up. TIA!
Edit: According to RealOEM, both the E92 and E90 performance suspension (the whole package including sway bar) is part no 33500444832. If this is true, this clearance set up should also work for E92's. Thinking about ordering to find out.
Then - E53, E85, E92, E82, F15, F80, G01
Now - F97, Macan S Last edited by jzmundy; 11-21-2010 at 12:00 PM.. |
11-21-2010, 01:31 PM | #33 | |
146
Rep 1,922
Drives: E90 335i, E70 X5
my car is running the perf struts with perf yellow springs setup and i can barely tell if there's any drop on it. most people told me to drop it more by putting in some coilcover. i was thinking there's gotta be a reason why bmw engineered their suspension setup at certain height. and doesn't like generic aftermarket suspension, bmw perf has different springs design for different setup ie auto/manual, coupe/sedan etc.
-eric
E90 335i TiAg *STOCK* see my garage for mod list.. E70 X5 SGM *try to stay stock* :/ |
11-21-2010, 02:56 PM | #34 | |
Rep 195
11-24-2010, 02:04 PM | #36 |
30
Rep 425
11-26-2010, 11:52 PM | #37 |
9
Rep 338
Was thinking of doing the same. I'm currently at 22k miles. At what approx mileage does stock stuff "get soft"?
11-27-2010, 08:44 AM | #38 |
Rep 195
It is hard to say an exact mileage, as so much of it likely depends on how the car has been driven. But, if it is daily driver that sees a mix of crummy urban streets and highways I would say 50-60k would be the time to replace your struts and shocks. Not saying the old stuff would really be completely worn out at this point, but they would definitely have loosened up a bit.
11-27-2010, 09:54 AM | #39 | |
I do my crosswords in pen.
17
Rep 751
GRUPPE TITAN Midwest
11-27-2010, 07:18 PM | #40 |
894
Rep 9,034
What's the difference between this version and the NEW version mentioned in the description?
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
11-29-2010, 12:41 AM | #41 |
Rep 44
Does anyone know if this will fit E92? I need a new rear shock because mine is blown and this package is about the same price of a single shock alone.
11-29-2010, 04:08 AM | #42 | |||
62
Rep 1,452
11-29-2010, 06:54 AM | #43 |
Original Gangster
Rep 69
What $133.06!?!? That's not everyday price for an entire oem performance suspension kit. One aftermarket performance shock/strut cost more. If anyone finds it cheaper anywhere else, please inform the rest of us.
11-29-2010, 11:15 AM | #44 |
Rep 44
Are you sure it wont fit the E92? Because on the link you posted above, it said that the E92 kit is compatible with the E90. So theoritically this kit should fit too, correct?
