KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
03-13-2024, 12:37 PM | #1 |
Rep 23
Best Wheel setup for lowereing springs E92?
Hey yall,
Just bought my E92 M3, the car was already on springs when I got it. Looking to buy new wheels, right now looking at the Apex VS5RS, trying to go for a flushed look without any rubbing. Front: 19x9.5, 22 offset wrapped in 265/35/r19 Rear: 19x10.5, 22 offset wrapped in 295/30/r19 |
03-13-2024, 03:34 PM | #2 |
Dont listen to me
810
Rep 579
you will rub with a 265/35/19 front tire. A better choice is the 265/30/19, but best is the 275/30/19).
your rear proposal is perfect and will not rub and give you a pretty nice, flush fit. You could also go with the 11" +25 offset option and 295/30/19, which would stick out 3mm more than your 10.5" +22 and be super flush. Overall, that will be a great fitment and setup for a lowered E92. Your proposed setup of wheel sizes with 265/30 or 275/30 front and 295/30 rear will look like this as far as fitment and flushness goes with standard lowering springs.
Instagram: @thatwhitem4
MSYm4116.00 |
03-13-2024, 03:51 PM | #4 |
Rep 23
Slight issue, they don't have the rear setup you recommended.
I still want to get that very flushed look on the car, should I still go with 10.5 rear with 25 offset? |
03-14-2024, 01:07 PM | #5 | |
Dont listen to me
810
Rep 579
Either of these wheels are going to be very close to flush, its only 3 mm, and worst case scenario, you can add a 3mm spacer if necessary. The 10.5+22 will look EXACTLY like my two pics above as far as flush goes. So if you think you want the wheel to stick out an extra 3mm, get the 11" +25.
03-15-2024, 01:08 PM | #7 | |
Dont listen to me
810
Rep 579
yes.... 19".... your best rear wheel options are either the 19x10.5" +22 or you can get the 19x11" +44 and add a 15mm to 18mm spacer in the rear. If you are against spacers, the 10.5" +22 will work great with a 295/30/19 tire.
