Road Map North America PREMIUM (USB) 2022
09-10-2022, 09:58 PM | #1 |
Rep 16
Below is a torrent for the 2022 BMW North America Premium USB map files. This will only work with CIC Premium. If you're looking for a previous version click here for the 2021 Premium map.
README: Changes for 2022
Download Please seed and be patient. Initial downloads will be slow. The more seeders, the faster it is. (Torrent) Magnet Link Attached: .torrent file in case the magnet link does not work Map Version:112214.2.15 Filename: Road Map North America PREMIUM (USB) 2022.zip Size: 30.5 GB MD5: 8099e10375fa0e1a2cdbfd8cf108b8f1 Requirements
Update Steps
Happy navigating! Last edited by Right2Repair; 10-08-2022 at 01:29 PM.. |
23
FireBlaze67.00 POBEP374.50 e90ftw38.50 Mike K322.00 X20A13.50 LMB335IS1299.00 johnnyorange58.50 Tommy681.50 Johnny Boost323.50 Hoody0071335.50 billybarty3.00 SaturnX1.00 Papa Smurf10.50 happydude139.50 derbo3611.50 SaNGRia990.00 gjm1202183.00 StradaRedlands4991.00 pungo886.00 dcay1.50 bimmer_devil0.00 Torgus3781.50 frozenfire10.50 |
09-11-2022, 10:34 PM | #2 |
67
Rep 143
Thanks! This file worked perfectly for my 2012 E92 CIC. I have the lifetime FSC code so no need to enter the code this time. I will seed for the next week or so at least.
VRSF DP, VRSF 7" Intercooler, BMS OCC, Stg 2 LPFP, Custom MHD E30 Tune, Late Model E-Series N55
POBEP374.50 |
09-12-2022, 06:24 PM | #3 |
14
Rep 89
Drives: 2011 JB E90 335i xDrive SE
Thank you! Worked beautifully for my 2011 E90 CIC Professional.
09-15-2022, 02:35 PM | #5 |
324
Rep 2,014
Thank you!
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3 Michelin PSS | M3 Control Arms LUX v4 LEDs | Shadowline Grills | Lip Spoiler |
09-15-2022, 03:08 PM | #6 |
399
Rep 1,579
Thanks for posting. Does anyone know the FscShort code for this update? I need that for the FSC generator.
Edit. Got it. 0x2D 0x65 Last edited by smass; 09-15-2022 at 04:20 PM.. |
09-15-2022, 04:31 PM | #7 |
Derbo Tuning
3612
Rep 3,026
Anyone not able to use the magnet link? My Rutorrent isn't working with it.
Nvm: Rutorrent doesn't like that many announce trackers in one. I'll seed as long as I can with my 10Gbit connnection.
IG:ruhrohz_m3
Journal: Link E9x ZCP Suspension Info: Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services Last edited by derbo; 09-15-2022 at 07:55 PM.. |
09-16-2022, 08:11 AM | #8 |
Rep 13
09-16-2022, 10:28 AM | #9 |
Derbo Tuning
3612
Rep 3,026
Is your torrent application setup correctly to be fully connectable? Are you able to get the Torrent Metadata from the magnet link or are you stuck without that?
Things I would check: -Port forwarding on your router for your computer for UDP/TCP -Check if the trackers are connecting
IG:ruhrohz_m3
Journal: Link E9x ZCP Suspension Info: Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services |
09-16-2022, 01:25 PM | #10 | |
Rep 13
Edit: Just to add - it's connected to trackers, but keeps re-trying to download metadata. Last edited by SaturnX; 09-16-2022 at 01:35 PM.. |
09-16-2022, 03:38 PM | #11 | |
Rep 16
Remove ".pdf" from the file extension. Had to do that to get around the 400kb zip file max. Last edited by Right2Repair; 09-16-2022 at 03:44 PM.. |
derbo3611.50 |
09-16-2022, 09:17 PM | #12 | |
Rep 13
09-16-2022, 10:19 PM | #13 |
Derbo Tuning
3612
Rep 3,026
For the magnet link, try reducing the amount of announce trackers too, rutorrent didn't like so many at once, so I deleted half of them and it finally worked. Been seeding for a day now and uploaded about 200GB so clearly someone is grabbing it!
IG:ruhrohz_m3
09-17-2022, 09:48 AM | #14 |
170
Rep 1,843
I'm also having problems with this, was hoping to set this up to run today while I'm out. The magnet link works but it never finishes downloading metadata. the .torrent file doesn't work at all. I'm using transmission on Mint. I'm not savvy enough to know what I'm screwing up.
09-17-2022, 10:55 AM | #15 | |
Rep 16
09-17-2022, 04:30 PM | #16 |
Rep 13
09-17-2022, 05:09 PM | #17 |
Rep 16
09-17-2022, 07:38 PM | #18 | |
Rep 13
It's like I'm cursed to live with 2021 maps haha. |
09-17-2022, 09:18 PM | #19 |
Rep 6
Grabbed the magnet link in the first post and using qBittorent (for the Mac) was able to grab the file. Formatted a 256Gb USB stick as an MS-DOS (Fat) device (no limits on the size of the device within MacOS) and after unzipping and transferring over, plugged into my 2011 E93 and went for a long drive and Voila!
Many many thanks! |
09-18-2022, 06:57 AM | #20 |
170
Rep 1,843
I'm still not able to finish downloading metadata... I just retried the magnet link fresh and it got to 94% and then started over at 0%
Edit: the new torrent file doesn't work either, it just won't open. Last edited by N8N; 09-18-2022 at 09:55 AM.. |
09-18-2022, 10:09 AM | #21 | |
242
Rep 1,353
I switched to qtorrent and that solved the problem. |
SaturnX1.00 |
09-18-2022, 10:30 AM | #22 |
170
Rep 1,843
now that you mention it, all the peers showing are using qBittorrent or (mu)torrent.
In other news, I just discovered that I can't use alt-codes with my Keychron keyboard. (they work fine with my GMMK which is at work) Edit: I downloaded qBittorrent and it seems to be working now. Won't be done in time to get this loaded this weekend, but still. I am using my home music server to do this, so I'll leave it seeding for a couple weeks, it's a machine I rarely use for anything other than serving up music files to the various audio systems around the house. Don't know what the problem was with Transmission, but I've got 9.4% of the file downloaded now. Last edited by N8N; 09-18-2022 at 11:34 AM.. |
SaturnX1.00 |
