      10-29-2011, 11:18 AM   #1
toni8284
toni8284's Avatar
Drives: N/A
2011 BMW 1M  [10.00]
2016 M3  [0.00]
Sharing my 1M coding
Hi,
I just got my car on 10/27.
And I already coded all the stuffs I needed.
So I would like to share that info for the others before I forget:
Function
Module
Field
Value
Close Windows/Roof with CA
CAS
KOMFORTSCHLIESSUNG_PA
aktiv
Close Windows/Roof with Fob
CAS
KOMFORTSCHLIESSUNG_FB
aktiv
Unlock Doors when turn off the car
CAS
ER_KEYOUT_AUTOVR
aktiv
Corner Delete Mod
NFRM
SIDEMARKER_US_MIT_FRA_V
nicht_aktiv
using your remote to open and close Mirror
NFRM
ASP_KOMFORT_EINKLAPP
aktiv
this is for the CIC (with iDrive)
NOTE: make sure you update it with the daten v43.
Disable iDrive Disclaimer
CIC
LEGAL_DISCLAIMER_TIME
kein_ld
for video in motion ( you required all 4)
1.
CIC
VIDEO_NUR_MIT_HANDBREMSE
nicht_aktiv
2.
CIC
SPEEDLOCK_X_KMH_MAX_C0E
3_kmh
3.
CIC
SPEEDLOCK_X_KMH_MIN_C0E
3_kmh
4. The most important
I found out for my car, it used CIC.C1A file.
Happy Coding!!!
2021 F87 HS M2C
2018 F80 SO M3 (SOLD)
2016 F80 AY M3 (SOLD)
2014 F10 M5 LCI (SOLD)
2011 VO 1M (SOLD)
      10-29-2011, 11:40 AM   #2
robertm
450
Drives: 2020 M2 Comp
I understood the following from above:
Hi, I just got my car on 10/27.
Happy
Appreciate 5
      10-29-2011, 12:28 PM   #3
KIYO
Austria
23
Drives: 1er M Coupé
Thanks for sharing.
I have disabled the seat belt chime.
ABG module
CC_GURTWARNUNG_1
nicht_aktiv
SBR_FAHRER_1
nicht_aktiv
SBR_PREWARNING_BF_MRS
nicht_aktiv
SBR_PREWARNING_FA_MRS
nicht_aktiv
SBR_BEIFAHRER_2_CD
nicht_aktiv
      10-29-2011, 12:29 PM   #4
M3 Adjuster
Albania
7909
Drives: 1M, X1 M Sport, E46 325ic
Happy
ha! yeah me too. Actually.. many items are configurable... Corner marker light flash.. whether or not the lights stay on when you unlock the doors.. etc.. chime. etc.. Fortunately... Dackel set a few of these items for me in Germany.. Other than that.. I have been too busy driving to sit in the car with a manual to figure this stuff out.
      10-29-2011, 12:33 PM   #5
1mGator
1mGator
1mGator's Avatar
Drives: Valencia 1M
Happy
+1, LOL .... I was seriously thinking the same thing as I read the OP thread ....
Where do we sign up for the "coding for dummies" classes M3Adjuster
      10-29-2011, 02:16 PM   #6
CH1M
Switzerland
Drives: 1M AW
Happy
Same here. Obviously I need to brush up on the IT part of owning a 1m
      10-29-2011, 02:20 PM   #7
toni8284
toni8284's Avatar
Drives: N/A
2011 BMW 1M  [10.00]
2016 M3  [0.00]
Sorry for my short instruction.... and I am not a good writer too...
1mGator, if you want it, I can help you with that.
2021 F87 HS M2C
2011 VO 1M (SOLD)
      10-29-2011, 02:41 PM   #8
ADVANT123
15
Drives: 2018 M3 ZCP
Any way to code the car to turn off traction control when the M button is pressed?
2018 BMW M3 ZCP
1999 BMW Z3 M Coupe Turbo
2017 Ram Rebel
2015 Porsche Cayman S
      10-29-2011, 02:54 PM   #9
scaramanga
United Kingdom
89
Drives: Looking to buy a 1M
CAS
aktiv
CAS
aktiv
CAS
ER_KEYOUT_AUTOVR
aktiv
Corner Delete Mod
NFRM
nicht_aktiv
NFRM
aktiv
Hi - couple of questions...
My car already closes/opens the windows via the remote (if I hold down the lock/unlock button). Does your first coding mean something different ?
Second, I can configure the door unlock when ignition is turned off in the idrive settings (or am I confusing this with something else?)
I like the idea of the mirrors folding/unfolding when the car is locked.
And what is the corner delete ?
Is there an independent garage that can do somet of this coding for me in the London/Surrey area ? [UK] ? I don't fancy having BMW extort more money out of me...
      10-29-2011, 03:47 PM   #10
toni8284
toni8284's Avatar
Drives: N/A
2011 BMW 1M  [10.00]
2016 M3  [0.00]
Answer # did you code it already or your car comes with the close/open window via the remote? if you applied the code, it will close/open the window via the remote.
Answer # For my car, i have comfort access, and if i turn off the car (push the start/stop button), before coding, it won't unlock the door for me. but after I change that, it will.
Answer # if your car is in UK, you dont have to do that. it's only USA car.
2021 F87 HS M2C
2011 VO 1M (SOLD)
      10-29-2011, 03:51 PM   #11
nachob
Drives: 2004 330i ZHP, 2022 Cayman T
Do you know how to set M Dynamic Mode on as Default?
      10-29-2011, 04:53 PM   #12
LOVEM
Drives: 2011 1m VO
Happy
      10-29-2011, 05:24 PM   #13
eeghie
Kind of a big deal
301
Drives: an 1M not often enough
Congrats on the car, and kudos for kicking of the 1///M coding party.
As my car is in transit, just wanted to run by someone who does not have the electric seat memory option, if making:
SPIEGELMEMORY aktiv
enables the mirror memory on stripper cars?
      10-29-2011, 06:45 PM   #14
mkPOTO
Mr. Nice Says Hello
mkPOTO's Avatar
637
Drives: BMW M3 | X5 xdrive 35i MSport
Great post!
      10-30-2011, 12:50 PM   #15
eeghie
Kind of a big deal
301
Second freebee I hope to get from coding: do you know / can you find the parameter that controls the passenger mirror tilting down on reverse aka Curb Monitor?
thx
      10-31-2011, 12:40 AM   #16
nicoz
11
Drives: 1M
How/where do you enter these codes?
      10-31-2011, 12:58 AM   #17
ATSR
Drives: 1977 Honda Civic
+1
      10-31-2011, 02:07 AM   #18
eeghie
Kind of a big deal
301
Found the Curb Monitor parameters (freebee for those of us with stripper cars):
AUT_SPIEGELVERSTELLUNG
aktiv
SPIEGELABKLAPPEN
aktiv
BEIKLAPPEN_B_KOMFORTSCHL
nicht_aktiv
MEMORY_SPIEGELABKLAPPEN
aktiv
SPIEGELHEIZUNG
ptc_kl_15
SITZMEMORY_VERBAUT
aktiv
V_VAR_SPERRE_BEIKLAPPEN
wert_01
LL/RL
linkslenker (use rechtslenker if your steering wheel is on the right)
SPIEGELHEIZUNG_VERBAUT
aktiv
ABKLAPPWERT
wert_02
Mirror memory in the key fob (without memory seats) is not yet confirmed, looking into that. TBC
For the AngelEyes there should be some options for those of you who would like to not use them. So far the only confirmed solution is the delete of the individual broken bulb warning: Because of that, if you take out the bulbs, you will not get a warning. TBC
BTW, these coding options are mostly not accessible via the idrive (although there are a few coding options to add menus to the regular user interface). The coding is done by using PC software to change the values of the parameters used by the BMW OEM software for the various micro processors (called xxxx Control modules) in the car. Then loading the changed settings from the computer via the USB port to the cars OBD connector. Query bmw coding if you're interested.
Not that I'm a nerd or anything; the above was told to me by a captian Kirk look-a-like at the last StarTrek convention
      12-22-2011, 09:07 PM   #19
E30 Racer
E30 Racer's Avatar
Drives: '11 1M, '09 335i M Sport
Hi,
Happy Coding!!!
What cable did you use? GT1?
      12-23-2011, 04:12 AM   #20
eeghie
Kind of a big deal
301
+1
Can U pls post links to the USB-OBD cables you use?
      12-23-2011, 06:10 AM   #21
Oaktree
Oaktree's Avatar
Drives: 2012 X5 - 2010 M3 - 1999 M3
This is the best post I have found on the procedure.
f you are interested in coding your own car, you can do that with a $85 cable, a bit of time, and a computer. It's really much easier than one thinks.
#1: You need a cable that plugs into the OBD port. Many people have had success offering $85 including myself. This is the cable that works consistently, including 2011s. (update I heard lowest price is $90 now)
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_7189wt_958
#2: Download the programs required for coding (NCS Expert, INPA, EIBAS)
http://rapidshare.com/files/429882289/NCSEXPER.rar all files needed
#3: A simple DIY guide to get started
http://rapidshare.com/files/429875523/NCS_DIY.pdf
#4 (Optional): You will need newer daten files for NCS Expert to code 2011 CICs (iDrive). I was able to read a 2011 CIC with v39 daten files. This can be found in newsgroup and/or bittorrent sites. Or here's one from from rapidshare:
http://forums.bimmerforums.com/forum....php?t=1590923
Update instruction from
http://forums.bimmerforums.com/forum...8&postcount=13:
In each “sp-daten-Exx” folder in the subfolder “daten” find a file “laden.bat” … execute this .bat file and your ncs will be updated automatically with the new data for the corresponding model.
Or u can do the following copy-paste procedure:
Target ---------------------------Source .(SP-Daten-Exx directory from ISTA-P)
\NCSEXPER\SGDAT\ -------- .ipo files
\NCSEXPER\DATEN\ -------- coding data (daten) for models
\EDIABAS\Ecu\ -------------- .prg files......
Please make sure you make a backup of your \EDIABAS\ecu folder. When you get error message from NCS Expert that you have a "Version" problem, you need to put your original prg file back to \EDIABAS\ecu folder.
Credits go to xxxjecxxx & NiVeDh and all other users who have contributed @ e90post.com
Here's a sample of the coding process:
      12-23-2011, 12:00 PM   #22
eeghie
Kind of a big deal
301
true, unfortunately the link to the first step (the cable) is obsolete!
