04-08-2019, 01:21 PM | #1 |
1716
Rep 1,913
Drives: 2023 M5C
Akra cold start question/issue
This one is a cold-start in Sport+ mode. Audio cuts off for a split second when it connected to CarPlay.
For some reason I can’t figure out why it starts with valves open, then closes the valves briefly before reopening... if anyone has an idea why it’s doing that I’d love to hear. |
04-08-2019, 04:24 PM | #2 |
170
Rep 403
Same thing happens to me, car starts with valves open at cold start and than valves close.
I am too lazy to take it back to dealer to find out why. Please let me know once you find out. Would be great to have cold start with valves staying open. |
04-08-2019, 04:32 PM | #3 |
13035
Rep 18,747
Is it only in Sport+?
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
04-08-2019, 04:34 PM | #4 |
Rep 29
Try setting your M1 or M2 instead of just putting it to Sport+ Mode and see what happens?
I have the same exhaust and i always start my car with the M2 button😜 Hope this helps. |
04-08-2019, 05:13 PM | #5 | |
1716
Rep 1,913
Drives: 2023 M5C
Yes this issue is in Sport+ mode only.
I set my M1 and M2 buttons to have the engine in Sport+ mode. So before this start-up, I engage M1 which makes the settings:
It may have done this before with the OEM exhaust, but just wasn't as noticeable since it wasn't as loud. When I start up with the engine in Comfort mode, the first two sounds you hear are what I get (valves open initially and then close quickly and stay closed. |
04-08-2019, 05:34 PM | #6 |
13035
Rep 18,747
Could be the car is running a check on the valve connection.
04-08-2019, 05:39 PM | #7 |
1716
Rep 1,913
Drives: 2023 M5C
Possibly so. Not sure what that module that comes with it was, but I wonder if that has anything to do with it? It's not the optional sound kit I'm talking about, but there's a little black box module that plugs in on the right side in the trunk area.
04-08-2019, 05:49 PM | #8 | |
13035
Rep 18,747
In that case then it could be Akra's module itself that is doing the check. Because all the Remus that I've installed, it uses the original Valve controller and connection.
04-08-2019, 05:57 PM | #9 |
13035
Rep 18,747
Ok, just read the installation instruction for Akra.
Since you have that Sound Module, what you are experiencing is normal. The Sound Module is intercepting the original signal from the car. So, what controlling the flap is the sound module, not the car anymore.
shahin169.50 |
04-08-2019, 06:13 PM | #10 | |
170
Rep 403
I guess its the European noise laws, and the sound module automatically quiets the car. |
r33_RGSport13035.00 Quickburn7957.00 |
04-09-2019, 09:11 AM | #11 | |
1716
Rep 1,913
Drives: 2023 M5C
04-09-2019, 11:21 AM | #12 | |
170
Rep 403
Comfort, sport, sport plus. So each level up gives you more noise. Second, if I am not mistaken the sound module does the same thing but can be controlled with the akro phone app and a small remote that it comes with. So waste of money, if we can do the same with our cars 3 throttle settings. |
