03-07-2023, 05:42 PM | #1 |
26
Rep 74
Carbahn stage 1 tune
Has anyone had a Carbahn tune done and gotten a dyno? I had one installed about 18 months ago and finally took it to the dyno about 6 weeks ago. The numbers were disappointing and seemed very much like stock. They had a dyno on a stock M5 CS and I was a bit below that, which I would expect stock. I would think a tuned car would be much higher than a stock CS. I talked to Carbahn and then said they had a poor tuner back then (not sure why it took me to contact them for them to inform me of this) and had me bring it into the dealership where they re-did the flash. It definitely feels like there's more power, but I took it back to the dyno and still stock-like numbers. I just seeing if anyone else has gotten the numbers after the install.
03-07-2023, 07:15 PM | #2 | |
4092
Rep 3,673
Drives: 2022 M5C
Not a BMW guy...but certainly an M5 guy.
03-08-2023, 12:20 PM | #4 |
IG: @M5RCY_
365
Rep 317
My stock TUNE base M5 (only has CIA, secondary downpipe and cat back exhaust) dyno'd at 552 on an AWD DynoJet Dyno.
Autotecknic.com - code: M5RCY for 12% off
Project Gamma - code: M5RCY for 5% off Dura-Coating - code: M5RCY for 20% off |
03-08-2023, 08:40 PM | #6 |
26
Rep 74
I apologize for my earlier post where it was making you download my files. I'm not overly familiar with links/images. I have updated my previous post with jpg files.
The place I got the dyno done, said they typically see 610 on a stage 1 type tune on the Mustang dyno. I believe they showed me the results for a different stage 1 tune with some other upgrades and it was 620. |
03-08-2023, 11:35 PM | #7 |
5234
Rep 10,616
For a stage 1 tune, 10% over stock is common. 15% for stage 2 and 20% for a custom stage 2 tune. Maybe the OP is in the ballpark. I don’t really trust “Dynojet conversions” from other brands of dynos though Mustangs contend to read lower.
03-09-2023, 08:57 AM | #8 |
26
Rep 74
I don't really use the Dynoject conversions either, but when you compare 2 cars on the same equipment, you should see the differences. I'm concerned that a stock CS had about the increase in hp you'd see from a stock Competition. Regardless of the equipment, all things the same, a stage 1 tuned Competition should be higher than a stock CS. Especially given Carbahn gives a projected 100+ hp increase.
03-09-2023, 03:27 PM | #9 |
Rep 7
I have a carbahn stage 1 on my pre-LCI M5 Comp and although I didnt dyno it, it was without a doubt night and day. I realize without actual dyno numbers its all speculation but there is no doubt the car is on another level from stock after the tune. I had mine done at GMP in charlotte, and waited while they did it. They had some initial 'issues' and my rep said the tuner from Carbahn wrote my tune while they watched. I assume the tune should perform pretty much the same on any apples:apples build, but there is no way you wouldnt notice the difference over stock.
03-09-2023, 04:28 PM | #10 |
IG: @M5RCY_
365
Rep 317
Unfortunately, I do not
03-10-2023, 10:12 PM | #11 | |
Senior Technician
10
Rep 20
03-14-2023, 09:32 AM | #15 |
26
Rep 74
03-17-2023, 11:38 AM | #17 | |
682
Rep 527
03-20-2023, 03:18 PM | #19 |
26
Rep 74
03-20-2023, 03:52 PM | #20 |
682
Rep 527
03-20-2023, 08:59 PM | #21 |
26
Rep 74
03-25-2023, 12:24 PM | #22 |
123
Rep 105
