05-10-2014, 04:16 PM | #23 |
11827
Rep 15,400
05-10-2014, 04:30 PM | #24 |
26
Rep 504
Lol I used to be exactly like some of you on this forum. I'm not gonna call you badge whores or anything like that because I used to be the same.
It's more like being in a box and not willing to leave and explore. Is it a comfort thing? Insecurity thing? Who knows? All I know is the day I crawled out of my box and started driving other cars besides bimmers was the day I truly started being a real car enthusiast. |
05-10-2014, 04:36 PM | #25 | |
64
Rep 386
05-10-2014, 04:39 PM | #26 |
26
Rep 504
You sure about that? I am pretty sure I've seen a few reviews where the larger m models have lost comparison tests to amg and rs models.
05-10-2014, 04:48 PM | #27 |
26
Rep 504
No I'm not comparing I'm just mentioning some of the other cars I've owned besides Bmw. Put aside the gt3 and r8. I prefer my s4 to any n55 n54 powered bmw. Please read my initial post.
05-10-2014, 04:48 PM | #28 | |
3451
Rep 4,983
The RS7 does beat the M6 GC but loses to the M5 Comp. E63 AMG beats the RS7 in one competition and loses to it in the other. And the RS5 loses to the M3 in almost every competition I've read. |
05-10-2014, 04:53 PM | #29 |
64
Rep 386
I did read your initial post, you devolved into nonsense by trying to cite top of the line sportscars with BMW when talking about M cars which don't include those category of cars. Clearly the person you responded to with the R8/GT3 comment was talking about their M equivalent models, ala RS5,7 line. Simply put you're attempting to draw false comparisons, and people here aren't idiots (well most). If you want to argue about the S4 vs 335i or whatever then stick to it and those engines, stop citing supercars as to why other manufacturers are better than BMW.
05-10-2014, 05:00 PM | #30 |
9
Rep 116
Because of USA, you, OP.
We pay 4X what you pay for gas in Europe. You,will soon catch up, be you democrat or republican. Enjoy what we can now. In 10-15 years our motors will be illegal to be made. I3 and I8 are clear markers of where we are heading. Politics! So, you do not perhaps do not like the sound of the new M4....? How about next version, fully electric? Dead silence....... |
05-10-2014, 05:04 PM | #32 | |
Law Enforcer
25114
Rep 22,288
Drives: '22 Chalk Gray Porsche C2S
05-10-2014, 05:12 PM | #33 |
26
Rep 504
05-10-2014, 05:14 PM | #34 |
3451
Rep 4,983
05-10-2014, 05:22 PM | #35 |
26
Rep 504
05-10-2014, 05:25 PM | #36 |
3451
Rep 4,983
05-10-2014, 05:27 PM | #37 |
21117
Rep 20,741
Drives: 2021 911 turbo
Actually they do (it has the same engine as the RS5). They just don't import it to North America.
www.youtube.com/watch?v=4HYdVXmYA-w |
05-10-2014, 05:42 PM | #38 | |
Rep 27
05-10-2014, 06:07 PM | #39 | |
26
Rep 504
05-10-2014, 06:36 PM | #40 |
50
Rep 1,061
Superchargers are a load, even before they can provide much of any boost, so sitting at idle (unless you add in a clutch, and even then, some load) you're wasting some fuel without the benefit. They may not handle the engine rpm near the top and need special controls for that. Since they're engine driven, they can also affect the throttle response since it's mechanically connected and has some inertia directly geared to the engine, rather than uncoupled like in the exhaust gasses with a turbo.
A turbo uses what would be wasted energy captured from the exhaust stream. Implemented like most of the BMW engines, it provides more torque over more of the RPM-band than the supercharger does. The original turbos were usually designed for either lower power at lower rpms, but they ran out of boost higher up, or a bigger one that could make lots of boost, but did it at higher RPMs and was slower to respond. BMW gets around this normal effect by their novel control of the exhaust gasses. A supercharger configured to let the engine run at super low RPMs with high torque wouldn't work particularly well at high RPMs with it. The drive gears from a supercharger need to be able to handle the rapid engine RPM changes between gear shifts, and that rapid change is slowed by the inertia of the thing, unlike a turbo...exhaust gasses are a lot better spring coupling than gears. Certainly, you could engineer a system with both a turbo(s) and a SC, but because of their relative internal RPM differences, getting a SC to be able to pump much air at lower RPMs creates much bigger problems at higher ones. At some point, the parasitic load of pumping all that air means, you've limited your top end with a SC. A turbo can be engineered to dump excess, with no parasitic losses, if that happened. All in all, they produce an engine with different characteristics...I prefer the way BMW has worked out their turbo control. |
05-10-2014, 06:55 PM | #41 | |
226
Rep 1,064
/thread It is a curious thing that a 556hp supercharged 6.2L V8 got almost the same gas mileage as a 414hp NA 4.0L V8. I suppose it's all RPMs. CTSV/ZL1 14/19 vs M3 14/20 |
05-10-2014, 07:32 PM | #42 |
50
Rep 1,061
FWIW, an engine with over 50% more displacement will be able to produce more torque just because of the displacement. It's all about how much fuel you can burn, and keeping the air/fuel ratio proper so you don't burn up the cylinder head or valves. A larger displacement engine, before either the SC or turbo is really moving much air will have an advantage at takeoff...the parasitic load comes more into play once it is running more at cruise or accelerating.
BMW's engine power ratings tend to be conservative...IOW, most engines produce more than the spec...it seems that spec is the 'low end' limit for one, and one that saw all of the stars aligned when built and the weather conditions are ideal, could have considerably more. And, you have to be careful they used the same test procedure and conditions to measure the output. The EPA ratings, based on the procedure, call for legal speed limits...at city and highway, especially at cruise, the amount of power you need is based on the drag factor and weight...those EPA procedures never stress those engines, which are only probably using 25-30Hp to keep them moving at cruise in the speeds listed. The EU test procedures differ, and while I haven't looked, I'd guess there's a bigger difference in their stated economy since their highway portion uses higher speeds. |
05-10-2014, 08:58 PM | #43 | |
192
Rep 1,292
But audi's are so boring.. no offense i've driven several s4,s5, rs5 and the new rs7 and God! the steering is horrible and no driver involvement. If i didn't decide on the M4 the next option would be AMG. |
05-10-2014, 09:30 PM | #44 |
26
Rep 504
The s4 is not boring, It's a load of fun and the eps in the 2013 model feels great. Very accurate and quick. I had a 2007 335 and that car war boring mainly because of the engine, no character, no thrill, no excitement. I have more fun sometimes in the s4 than I do in my r8. The rear torque diff along with the Quattro awd and super responsive and satisfying supercharged six pulls you out of corners with amazing speed, sticks to the road like glue with no body roll.
