Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > For Help with NCSExpert Errors
      01-28-2023, 05:41 PM   #287
trippleM
Drives: bmw 330i e90
Ken Oath
Do you have any way for me to download the daten file you have that solve your issue? I’m trying to code a FRM module and I get error message.
      01-28-2023, 05:45 PM   #288
trippleM
335deez
Hey there bud did you ever solve the issue with your FRM getting that error code? I am having that exact same issue and I can’t get past it. Could you please shine some light my way I need help on that part.
      01-28-2023, 11:31 PM   #289
trippleM
Hello there guys is there anyone here that can help me with winKFP not allowing me to code my frm module ! Please guys i need help!
      04-06-2023, 08:32 PM   #290
kokoboko
Drives: bmw x1 e84
Hello I need some help, I am coding my new battery with ncextexpert and my problem is every time when I change the file to AGM battery and I go to check in impa my battery AH it is 91 AH if I switch to non AGM it is work, the command I typed in the trc, file is 80ah_AGM ,what I am doing wrong?
      05-02-2023, 10:08 PM   #291
gmax
Drives: e93 2007
Hi there, I have an issue. Most probably pretty simple:
I am trying to NCS Expert to read from the car and I got the error:
Folgendes Merkmal ist im
Fahrzeugauftrag ungültig: #4UT.
I believe 4UT is the code for Sky Bag equipment.
Can you please advise me what I am doing wrong, most probably something with the NCS Expert version?
Car e93 2007
Here is the CABDPAR.OUT content
FA_STREAM = E93_#0307*WL73%0300&LCAD$1CA$205$2C6$2VB$2XA$319$4 30$431$441$459$481$488$494$4AS$4NA$4UT$502$520$521 $522$524$534$544$563$5GA$639$645$663$677$693$694$7 04$818$823$840$845$850$853$925$9AA-A090
JOBNAME = FA_READ
APPLIKATION = SERIE
      05-19-2023, 01:36 PM   #292
wenty321
Drives: e90 320d
help with cic retrofit navigation greyed out
hi guys im hoping someone will help me with this please
anybody have the programs i need its a e90 thanks
      05-30-2023, 10:46 PM   #293
808AWD325xi
Ballin' out of control.
808AWD325xi's Avatar
521
Drives: 2009 335i
Typically, it's 80Ah for flooded or 81Ah for AGM.
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms
      07-09-2023, 07:16 PM   #294
GodStang
Drives: 2011 BMW 335D
Good afternoon yall. Trying to code out Adaptive headlights and when I run Codierdaten_Lesen I get the following errors:
[20:04:33.529] [2023-07-09] [SERIE] 2041 Error CDH.C CDHCheckIdent 3
[20:04:33.529] [2023-07-09] [SERIE] Falscher SG-Codierindex A_PL2FRX: CODIERINDEX = 33h FRM2_E70.C08: CODIERINDEX = 08
[20:04:33.630] [2023-07-09] [SERIE] 2041 Error COAPI2.CPP coapiRunCabd 6
[20:04:33.630] [2023-07-09] [SERIE] Falscher SG-Codierindex CODIERDATEN_LESEN
[20:05:09.439] [2023-07-09] [SERIE] 2041 Error CDH.C CDHCheckIdent 3
[20:05:09.439] [2023-07-09] [SERIE] Falscher SG-Codierindex A_PL2FRX: CODIERINDEX = 33h FRM2_E70.C08: CODIERINDEX = 08
[20:05:09.541] [2023-07-09] [SERIE] 2041 Error COAPI2.CPP coapiRunCabd 6
[20:05:09.541] [2023-07-09] [SERIE] Falscher SG-Codierindex CODIERDATEN_LESEN
I loaded the latest Daten Files... Well at least I hope I did it correctly. Any pointers? I have coded my car many times before and all of a sudden issues.
      12-05-2023, 08:30 AM   #295
RealPreshaanB
RealPreshaanB
RealPreshaanB's Avatar
South Africa
Drives: BMW E90 320d
Not sure where i'm going wrong with NCS Expert
Hi members
Anyone has experience with NCS Expert? I have the Bimmergeeks Package installed on my windows 10 system, INPA is working and is communicating with the car, full functionality however I'm unable to get NCS Expert to read the FA (Vehicle order) after reading the VIN from either the CAS or FRM Module. it throws out an FA Error and doesn't read the VO. The aim is to code out the rear Cold & Hot bulb checks from my FRM module to proceed with my LCI Taillight conversion which will be on my youtube channel once everything is working correctly.
Vehicle is a 2006 (05/06 Build) 320d M Sport with FRMFA E90 Fog LT (FRM1) Module. I've done some research on the net as forum posts say that this module can be coded, I'm not sure what I'm doing wrong or missing
Any assistance will be highly appreciated and I'll be sure to give you a shoutout on my channel once the video is uploaded
thank you
