Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > N54 Dyno Chart Compilation
      10-27-2010, 05:16 PM   #23
kanecvl
kanecvl's Avatar
Drives: 15 535d
Tranny: AT
Mods:GIAC Stage 1, DCI
temp: low 60's
Humidity: 20%
Gas: shell 93
      10-27-2010, 11:17 PM   #24
Quisp
Does not play well with others
Drives: BMW
I notice a few of the dynos have the torque and HP crossing lower than others. It seems most cross at 5250 rpm(I heard the reason but cant remember right now) What causes the others to cross at lower rpm?
      10-28-2010, 07:31 AM   #25
kanecvl
kanecvl's Avatar
Drives: 15 535d
i would like to find out iv heard that its because I have no exhaust but I think thats bologna. Even stock cars usually cross around 52
      10-28-2010, 07:39 AM   #26
onebadmofo
onebadmofo's Avatar
347
Drives: 2008 E90 M3
Car is absolutely stock except for Procede, even stock airbox
1st run (blue) was map 0
2nd run (red) was map 2
3rd run (green) was map 2
4th run (purple) was map 1
Maps were switched on the fly and we didn't give a chance to Procede to adapt to new settings so there's possibly 10-15 more hp in there.
      10-29-2010, 09:10 AM   #27
Quisp
Drives: BMW
Kane, how dpo you like the GIAC? From the curves it looks like it has a strong low end and pretty smooth.
      10-29-2010, 09:55 AM   #28
kanecvl
kanecvl's Avatar
Drives: 15 535d
pm sent.
      10-31-2010, 07:36 PM   #29
BrianMN
114
Drives: 4 Door Family Sedan
You're correct that HP and torque cross at 5250...
I believe the answer to this is in the formatting of the dyno graph.. Notice that, on a given horizontal line, HP and TQ values can be about 50 apart.
      11-01-2010, 12:18 AM   #30
Quisp
Drives: BMW
I guess that makes sense to a degree, but the Dyno Dynamics one crosses under 4000 which wolld mean quite a large variance. Is there some other factor that would chnge the 5250 number?
      11-01-2010, 02:38 PM   #31
BrianMN
114
Are you referring to Qmax's on page 1? If so, the torque is apx. 90 units higher than the HP at the same X-axis. The TQ/HP will always cross at 5250.
      11-01-2010, 03:29 PM   #32
treytreyfeva
Puro Pinche Party!
treytreyfeva's Avatar
Drives: 2007 E90 335i TiAG
How much WHP should i expect with V4 autotuned ,DCI and AR DP's (e90/auto)
      11-01-2010, 06:30 PM   #33
BrianMN
114
Depending on what autotuning does, I'd expect somewhere in the 360-380 range.
      11-02-2010, 09:44 AM   #34
m54b25
Drives: exM3, exX5, 335i, C63 RT
Stock MY09 E90 335i with mild PAW Flash tune (for wife driving)
      11-02-2010, 09:10 PM   #35
BrianMN
114
^ Looks good! Pretty powerful for just a 'mild' tune
      11-04-2010, 03:18 PM   #36
m54b25
Thanks BrianNM for the complement. Actually, will be testing the DME MSD8.x.x. built-in overboost-mode that can be used for additional Hp increase... just need to finalize some road testing & decide holding time max & when to stop =)
      11-05-2010, 08:42 AM   #37
STONEY_M5
MAAD HEAD
STONEY_M5's Avatar
62
Drives: 2010 X5M 2013 M5
13 F10 M5  [0.00]
2010 X5M  [0.00]
07 335i  [9.26]
Dinan Stage 3 with intercooler and larger oil cooler. Also shows with stock software(dotted line).
(The people at Dinan weren't completely happy with these numbers and we are working on it. They feelit should be able to get 20% more HP)
I have a stage 2 with the same numbers and no additional mods... So yea there is def a problem with your numbers.
F10 M5 e70 X5M
Sold E90 335i
      11-30-2010, 03:13 PM   #38
m54b25
Here's a Mild Medium Hot Dynoed N54
Here's a Mild Medium Hot Dynoed N54 =)
File Type: pdf PAW Mild-Medium-Hot flash tune with upgrades.pdf (78.8 KB, 773 views)
      12-07-2010, 03:29 PM   #39
bigdog34uz
90
Drives: 2007 e90 335i
These are some really high numbers for just a tune. Are all these on legit dyno's just curious. Mild Flash tune doing 344 with 364lbs of torque is high! I want those numbers. I want to do wife driving.
13.01 @ 107.6mph Mods: OETuning........
13.00 @ 108.89 JB4 Times
      12-07-2010, 04:04 PM   #40
onebadmofo
onebadmofo's Avatar
347
Drives: 2008 E90 M3
Take a look at my graph, I was with just Procede and had 335hp / 366tq.
      12-07-2010, 11:40 PM   #41
LaLakers91tc
LaLakers91tc's Avatar
Drives: BSM E92 335i 6MT
they shouldn't ever cross at any other number....
HP is a number derived from Torque (foot pounds) x RPM / 5252
Thus at 5252 on every graph, torque will equal hp
Current 07 BSM E92 335i
Previous SGM E90 330i (R.I.P.)
      12-10-2010, 08:32 PM   #42
s2k_335i
This is it!!
s2k_335i's Avatar
16
Drives: FBO 335i without meth
New Dyno:
Degree: 70
Tune: Proceed V4, DCI, DP, Stock IC (removed AMS FMIC)
the number seem low this time for some reason.
      12-10-2010, 09:29 PM   #43
BrianMN
114
Looks very low. Datalogs would help a lot.
      12-10-2010, 10:17 PM   #44
Forcefed3
127
Drives: 2008 335i
2008 335i  [1.00]
Your numbers are very low for your mods, why did you remove IC?
