Classifieds Sponsors Classifieds    IND | Motorsport+ F90 M5 CS Style Yellow Daytime Running Lights LED Module Set
      11-28-2022, 05:24 PM   #1
IND-Distribution
BMW obsessed
IND-Distribution's Avatar
9587
Drives: G82 M4 / G87 M2
One of the special details of the new BMW M5 CS are the motorsport yellow daytime running lights. Evoking the look of GT racing cars, the BMW Laserlight headlights with yellow running lights bring a touch of the racetrack to the front of the new BMW M5 CS. Both in the welcome sequence triggered when unlocking the doors and when the low and high beam headlights are switched on, the angular daytime running lights illuminate in yellow rather than white.
Now you can bring the same motorsport detail to the front of your F90 M5 with new LED boards for your Daytime Running Light modules.
NOTE: Fits Pre-LCI Models ONLY! Professional installation recommended to access the DRL modules located on the bottom of the headlights. Once access to module is achieved, install only requires T20 torx; does not include install instructions.
Product Details:
  • Application List
    • F90 M5 Pre-LCI (2016-2020)
    • Also fits G30 5-Series with Adaptive LED corresponding headlight option
  • Plug and Play installation; no ugly wiring, no error codes
  • The OE LED boards utilize a single Torx screw to fasten to the heatsink. The new CS boards include a pre-applied special thermal adhesive to aide in heat transfer and help longevity; remove original LED boards and just peel and stick the new CS Yellow LED boards before replacing the screw.
  • Set includes a pair of LED boards for both driver and passenger side headlights; each board run both the low and high beam DRLs.
  • Professional installation recommended to access the DRL modules located on the bottom of the headlights.
The Motorsport+ F90 M5 CS Style Yellow DRL LED Module Set may be viewed at the following link to our online store:
https://ind-distribution.com/product...led-module-set
Please contact IND by phone or email for more information or to place your order.
866.963.4520 | info@ind-distribution.com
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
