Classifieds Sponsors Classifieds    IND | Eventuri F90 M5 Black Carbon Turbo Inlet Set
      10-25-2022, 10:46 PM   #1
IND-Distribution
BMW obsessed
IND-Distribution's Avatar
9587
Drives: G82 M4 / G87 M2
Acceleration Time : 60-130mph Reduced By 0.12 seconds
Presenting the perfect addition to our F90 M5 intake system to optimize the flow path all the way to the turbos. Our carbon inlets have a larger volume than the stock inlets by maintaining a larger diameter all the way to the turbos. The stock inlets narrow down immediately after the connection to the intake which creates a restriction especially at higher boost levels. We have alleviated this restriction and also designed the curvature to be as smooth as possible allowing the turbos to reach peak boost sooner.
During development we also tested inlets with larger openings and redesigned the intake to have an oversized connection to the inlets. However, tests showed no further benefit and so we proceeded with this version, which allows our current intake to be used without any modification while producing the best performance gains.
Some photos show our optional F90 M5 Intake system available separately. Turbo Inlets also fit with stock airboxes.
The Eventuri F90 M5 inlets are manufactured from high temperature prepreg carbon fiber and come assembled with a number of other components engineered to perform a specific purpose and fabricated to the highest of standards.
Each inlet inlet set consists of:
  • Prepreg Carbon Inlet Pair
  • CNC Machined Turbo Flanges
  • CNC Machined Breather Valve Assembly
The Eventuri F90 M5 Black Carbon Turbo Inlet Set may be viewed at the following link to our online store:
https://ind-distribution.com/product...urbo-inlet-set
Please contact IND by phone or email for more information or to place your order.
866.963.4520 | info@ind-distribution.com
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
      02-06-2023, 08:47 PM   #2
IND-Distribution
BMW obsessed
9587
IND Exclusive Matte F90 Turbo Inlets?
Painted to order and available now via the following link:
Eventuri BMW F90 M5 / F9X M8 Carbon Turbo Inlet Set - Matte
