06-01-2023, 10:44 AM | #1 |
Rep 4
My car feels like the tires are slipping
Sorry if this has already been dealt with, but I could not find anything by searching the forum.
I have a 3 month old M5 Comp with Pirelli P Zero 275/35 ZR 20 and 285/35 ZR 20 at the back (factory mounted). Tire pressure is 2.3 in the front and 2.4 at the back. When I make a turn from a stop the tires invariably slip, particularly at the back, even if I give very limited gas. They slip even more of course when the road is wet. When I start on a straight the problem is hardly noticeable. Is this normal (and I just need to get used to the power) or it shouldn't really happen? If it shouldn't really happen, what could be the problem? Thanks to everybody! |
06-01-2023, 11:04 AM | #2 |
Rep 17
Mine feels the same, somewhat normal, our E-diff is set up to lock & unlock when it detects circumfrence differential between the right and left wheel as the car's making a sharp turn.
06-01-2023, 06:10 PM | #3 |
1484
Rep 1,315
I know you said you haven’t had the car long but check the wear on the rears. This is exactly what happened to me at like 4k miles with the Pirelli P Zero Corsas — which wear a lot faster. It took me a while to realize it’s because the tires had worn so fast that this was my issue. I kept just thinking it was in my head or something I was doing and then it dawned on me it was was worn rears.
Current: 2022 M5 CS
Past: 2021 M550i (BSM) Past: 2010 535 xDrive (Alpine White) |
06-02-2023, 06:17 AM | #4 | |
Rep 4
06-02-2023, 06:21 AM | #5 |
Rep 4
I guess you have a point here. I am just wondering how long are the tires going to last with all this slipping...
06-02-2023, 09:08 AM | #6 |
335
Rep 413
Drives: 23 M5C, 19 X5
I see you are in Italy. How are the temperatures? I assume when you got the car a few months ago it was still somewhat cold. Temps around 40f/4c will make the tires hard.
Assuming it isn't too cold where you are now, with light throttle in the wet there should be no slip in a turn. If you are getting that then it sounds like a problem either with the rear diff or perhaps the shocks. In the dry starting in 2nd gear I can take a pretty fast left turn from a stop with no spin that I can feel. |
06-02-2023, 10:40 AM | #7 | |
Rep 4
