06-28-2019, 11:21 AM | #89 |
1412
Rep 1,812
Don't add washers, the driveshaft can slide in and out from the center joint. (If I'm understanding it correctly)
I would definitely make sure that centering bushing is to spec, as that has a lot to do with vibrations.
-2014 328d Wagon, 8HP. Self-tuned, 270hp/430ft-lbs.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. |
06-28-2019, 04:31 PM | #90 |
Rep 43
Bingo-bango; I knocked in the centering bushing to within spec, put red loctite on the bolts and nuts, then tightened to 55 fig newtons. Vibration appears to be all but gone. My crappy runflats are starting to cup, so they aren't helping matters at highway speeds either.
Thanks for the quick responses. |
06-28-2019, 06:29 PM | #91 |
1412
Rep 1,812
Wow, you're fast. Glad of the outcome!
Lol at fig newtons.
06-28-2019, 06:34 PM | #92 |
247
Rep 776
06-30-2019, 05:21 PM | #93 |
Rep 43
I spoke too soon. The vibration still exists at speeds over 75 mph, and especially when driving over bumps on the highway.
I’m guessing I need to replace the carrier bearing and the locating bushing. Is there a writeup on this like the rubber disc? Also, what size star bit are the bolts on the rear subframe support legs that connect under the rear suspension? |
07-03-2019, 09:07 PM | #94 |
Rep 43
UPDATE: my issue was bent wheels. All the swapping, and torquing, and re-measuring was for not. I took the wheels to a tire shop to rebalance as I wasn’t sure if the runflats were cupping to a point of needing to be rebalanced. Well they weren’t, and 3 of the factory wheels were no longer round.
AndrewC198910932.50 |
07-03-2019, 09:34 PM | #95 |
1412
Rep 1,812
Well that was a distractor! I hope you didn't go through a lot of driveshaft troubles.
I bet it's smooth and nice now? Which wheels do you have?
07-04-2019, 03:41 AM | #96 | |
Rep 43
And I’ve yet to purchase replacement wheels as I have no clue which direction to go. I was thinking of staying the same size and offset in a different BMW wheel, but the prices are worse than aftermarket! I’ll definitely take some input here. |
07-04-2019, 06:19 AM | #97 | |
247
Rep 776
Lots of info out there in the wheel and tire section. I personally believe you had both issues and corrected one. |
07-04-2019, 10:35 AM | #98 | |
Rep 43
On a more related note, the transfer case should last the life of the vehicle now. The annoying part was that I replaced my center carrier bushing and didn’t have to. |
07-09-2019, 07:25 AM | #99 |
Rep 1
Wow, lots of useful info here. Couple questions.
1. Where do you buy the 105mm rubber flex disk? 2. Once glue 2 pieces of metal together with loctite, Can you still take them apart? I know we don’t want the rear output flange to rotate as it will wear out the teeth, but is it suppose to be loose to allow back/forth movement. (Might seem like a silly question, not a car person whatsoever, and have no idea how the car mechanic works”. Thanks a bunch! Wendy |
Enabled1411.50 |
07-09-2019, 08:29 AM | #100 | |
197
Rep 368
Loctite 660 can be removed with a torch if you need to get it apart again. I'm sure that will probably nuke the seals on the TC though, so you're likely rebuilding it if you torch it. Though I would imagine the only reason you'd want to get that piece back off is if you were rebuilding it. |
07-09-2019, 10:28 AM | #101 |
1412
Rep 1,812
That is a very smart question, especially for a non car person.
The answer is that it does not need to move back and forth. As proof: the transfer case output flange (the triangle shaped flange) has a set of shims designed to keep it affixed as tightly as possible to the shaft. However, it isn't enough to keep it from micro movements clockwise/counterclockwise. The purpose of the loctite 660 is to cancel out those micro movements before they wear out the metal splines. Yes, high heat can soften the loctite to be able to remove the flange. Would you really need to remove the flange often? Very doubtful, except for a very thorough rebuild, which assumes that the rebuilder will have the skills to do it anyways.
07-10-2019, 11:56 AM | #102 |
Rep 43
I picked mine up on ebay: https://www.ebay.com/itm/Driveshaft-...72.m2749.l2649
07-10-2019, 12:15 PM | #103 |
1412
Rep 1,812
Having not heard of LOSTAR brand, I suggest looking for an OE supplier like Febi for the giubo,/flex disk.
07-15-2019, 02:30 PM | #104 |
10933
Rep 4,551
Drives: 2015 328d xDrive
Just took the case apart at 45k miles. The splines on the output shaft don’t look too bad but the splines in the flange do show wear. Will be replacing the flange, seal, flex disc, and fluid. Hopefully that's enough to prevent any issues from arising down the road.
07-15-2019, 04:02 PM | #105 |
1412
Rep 1,812
You have very little wear.
If your car is older than 07/2015 you need the 105mm bolt circle flange. Realoem doesn't seem to have this right. After 07/2015 it went to a 96mm flange, but realoem lists the same part number. I would clean it and then loctite the new flange. I believe you can get the flange set from ATC vendors as well.
08-02-2019, 10:28 AM | #106 | |
Rep 43
All vibrations are gone now that the wheels have been replaced. Decided on Konig Hypergramm in 18x8.5 with +35mm offset; found them for $200/ea with free shipping. For reference, I put a 245/40/18 tire on them. |
08-02-2019, 03:35 PM | #107 |
36
Rep 77
Planning on changing the output flange on my wife’s X3d in a few months (after we get out of this apartment and into our house) and I was just looking at parts on FCP Euro’s site. Output flange kit is $272 - is that what you guys are paying for you F3x cars? More than I expected.
08-02-2019, 05:51 PM | #108 | |
1412
Rep 1,812
Is it a problem on the X3d as well? My dad has an X3 28d with 40k miles now, and an awesome tune I built for it, no issues with transfer case. If it's an issue, I will loctite the flange on that before it becomes a problem.
08-02-2019, 09:38 PM | #109 |
36
Rep 77
I was thinking more preventative than anything else. I’ve heard of some issues but haven’t seen the X3 forums get as in depth as here. Maybe I’ll check it when I service the transmission fluid and see what it looks like.
08-19-2019, 12:28 AM | #110 |
Monobloc
332
Rep 449
Drives: '02 M Coupe - '19 F31 330ix
Enabled is the man and a living legend. Thank you fellow wagonite and M-couper!
You are doing the job that even BMW engineers and their suppliers' engineers failed to figure out.
-2023 Honda Odyssey Elite - Sonic Gray Pearl / Black
-2019 F31 330ix Individual - Champagne Quartz / Coral Red (M-sport, Exec, Premium, Track) -2004 Honda CRV AWD - Silver / Black -2002 S54 M Coupé - Steel Gray / Dark Gray/Black |
Pittcrew34.00 |
