BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    Pops and Bangs for xmas - Full Akrapovic installed
      12-25-2019, 02:47 AM   #23
Nikolov
239
Drives: '19 F90 M5C, '17 911 TTS
They’re not modifying the ECU, they just feed it false info through the sensors, so it doesn’t trigger a CEL. Same as the JB4.
Snapper Rocks Blue on Tartufo leather | All options except Homelink and tow hitch
      12-25-2019, 03:34 AM   #24
Br0adSw0rd
Drives: M5 Competition
Originally Posted by Mightyhoof View Post
So you installed the full Akrapovic exhaust including removing the OPFs? Yes Full Akrapovic......It was VERY HARD finding out what exactly they changed took 14 hours of searching thru the code and compering the 2 maps but once we got that it was done in 20 minutes
Thanks Mightyhoof.. are you able to share what you changed? I'm based in the UK and will need to find someone here to make these changes!
      12-25-2019, 07:23 AM   #25
krleas
Drives: BMW M5 F90 2020
We can change back to default any time and there is no mark of changing anything in ECU. There is no tunning just few clicks to get sound back. So this cant be reason to loose warranty.
Its every owner choice. You can have real M5 with pops and bangs or nothing.
      12-25-2019, 07:24 AM   #26
krleas
Im getting my M5 on 3.1.2020, first thing Akrapovic then Mighyhoof solution.
      12-27-2019, 04:24 AM   #27
bpma
155
Drives: M5C Stage 2
Can you share the settings changed or the ready map itself?
      01-04-2020, 03:19 PM   #28
RodyP
RodyP's Avatar
Netherlands
61
Drives: 19 Bmw M5 Competition
Yes please share, same problem here based in Holland.
      01-04-2020, 03:37 PM   #29
Mightyhoof
19
Drives: BMW M5 COMP
2019 BMW M5  [0.00]
Please contact
www.carpro.si
info@carpro.si
+38631695666 - whatsapp
You can say Mighty gave u the contact
      10-29-2020, 01:40 PM   #30
Perryf90lci
Drives: 2021 m5 comp
Guys how can I get pops etc for 2021 comp ? I have all master tools
      10-29-2020, 01:43 PM   #31
Perryf90lci
Manual exhaust sound tuning was by changing input parameter of ECUs original firmware. We checked our map and compared it to original pre-July 2019 map. So bits 0 / 1 were changed exactly where they had to be changed. And nothing else like HP or torque. As well as CEL was not triggered because factory parameters inside firmware were switched off manually as well before the car was started.
Can I contact you mighty to discuss this by email.or text thanks
      10-30-2020, 08:51 AM   #32
F90M5C
F90M5C's Avatar
Sweden
155
Drives: 19 F90 M5C,17 F82 ZCP M4
perry can you please update when this will work on your LCI ?
cheers
      10-31-2020, 10:01 AM   #33
Maverik259
Maverik259's Avatar
Drives: F90 M5 / F15 50i
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Is it possible to just get a good sound exhaust without popcorn? Sounds too ricer for my blood.
'07 Yamaha R1 (sold)
'06 C55 AMG (sold)
‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe
'14 X5 50i (wife’s now)
      10-31-2020, 12:50 PM   #34
Perryf90lci
cheers
Will post up if I manage to speak about it and get it done
      10-31-2020, 06:08 PM   #35
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
Aftermarket exhaust and flash to kill the 🍿 but you know the risks with this, especially to simply remove the pops. F10 M5's with aftermarket exhaust sounded amazing and no 🍿.
I went iPE cat-back on my current F90 and simply close the valves when I'm over the bangs and pops.
My car in Sport + Valves open sounds insane when in WOT but the pops literally scares the shit out people.
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
      02-22-2021, 05:43 PM   #36
HZX540e
HZX540e's Avatar
Drives: 2021 X5MC
Any update on coding the F95 to reintroduce burbles and pops for the comp exhaust?
      02-23-2021, 09:15 PM   #37
rgill95
34
Drives: F80 M3
Has anyone figured out the process of getting the original sound back?
      05-31-2023, 04:19 AM   #38
MaximK
MaximK's Avatar
25
Drives: F10- Bimmer Works Car
The OP posted video burbles ...sounds almost inexistent = 0
Here you can see before and after F90 LCI model
      06-01-2023, 04:03 PM   #39
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
Just put the engine in Sport instead of Sport+. You'll get the opened valve sound without the pops and bangs.
IG @windtendo_m5
