BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    Pops and Bangs for xmas - Full Akrapovic installed
      12-24-2019, 11:02 AM   #1
Mightyhoof
19
Drives: BMW M5 COMP
2019 BMW M5  [0.00]
After 3 months of intense research its finally here. Full Akrapovic installed and we did manual exhaust sound tuning, activation of burble & bangs (same as PRE July 2019) in Sport plus mode and neutral gear, OPF removing, all made manually by factory default functionality avoiding any kind of solution emulations.
Efficient mode
Sport plus mode
Appreciate 3
      12-24-2019, 11:44 AM   #2
castilla
51
Drives: 2014 M4
Is it possible to activate pops and burbles for late 2019 cars with coding?
      12-24-2019, 12:37 PM   #3
Br0adSw0rd
Drives: M5 Competition
Hi Mightyhoof, is that car a 2020 EU model?
      12-24-2019, 01:10 PM   #4
Mightyhoof
19
Drives: BMW M5 COMP
2019 BMW M5  [0.00]
Yes sir EU October 2020
      12-24-2019, 01:32 PM   #5
Mightyhoof
19
Drives: BMW M5 COMP
2019 BMW M5  [0.00]
Yes of course
      12-24-2019, 02:24 PM   #6
Nikolov
239
Drives: '19 F90 M5C, '17 911 TTS
Can you elaborate on the “manual exhaust sound tuning” part? Also how did you remove the OPF without getting a CEL?
      12-24-2019, 03:17 PM   #7
Mightyhoof
19
Drives: BMW M5 COMP
2019 BMW M5  [0.00]
Manual exhaust sound tuning was by changing input parameter of ECUs original firmware. We checked our map and compared it to original pre-July 2019 map. So bits 0 / 1 were changed exactly where they had to be changed. And nothing else like HP or torque. As well as CEL was not triggered because factory parameters inside firmware were switched off manually as well before the car was started.
mgod483.50
      12-24-2019, 03:19 PM   #8
Br0adSw0rd
Whoa.. ok...
I've a 2020 comp and need to sort the exhaust out without impacting the warranty if at all possible. Would be really interested to understand what changes you've made. Thanks!
      12-24-2019, 03:34 PM   #9
DannyA
United Kingdom
143
Drives: C8 RS6
I am guessing even though no CEL the warranty is still voided?
2020 C8 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
      12-24-2019, 03:44 PM   #10
Nikolov
239
So you flashed your ECU, which is what we told you you’d need in the first place BMW can void your warranty because of that, even if you haven’t really changed any parameters outside of BMW standard.
      12-24-2019, 03:51 PM   #11
Mightyhoof
19
Drives: BMW M5 COMP
2019 BMW M5  [0.00]
Yes you did tell me and i never said you were wrong i only said that those morons at ACschnitzer said they guarantee it will work, but i never said you guys were wrong
And we didn't flash anything just changed the parameters. Also why would that void warranty, if it is just like it was on older cars? but anyway to tired of this car to think about that. Now it works exactly like it was on preJuly car and that is all i need to know. Cheers
      12-24-2019, 04:09 PM   #12
DannyA
United Kingdom
143
Drives: C8 RS6
Even changing a 0 to a 1 is still a flash - bit like jailbreaking your phone - once the software fuse is tripped that's your warranty gone.
From the video it does sound the tits.
      12-24-2019, 04:23 PM   #13
Br0adSw0rd
Ok cheers Mightyhoof.. great work!
So you installed the full Akra exhaust including removing the OPFs?
And changed the parameters of the ECU to match the pre2019 cars? Who did this for you? Was it straight forward?
Thanks!
      12-24-2019, 04:24 PM   #14
Mightyhoof
19
Drives: BMW M5 COMP
2019 BMW M5  [0.00]
Thanks!
Was it straight forward? Sorry what does that mean
      12-24-2019, 04:52 PM   #15
Br0adSw0rd
Was it easy?
      12-24-2019, 05:00 PM   #16
Mightyhoof
19
Drives: BMW M5 COMP
2019 BMW M5  [0.00]
Was it easy?
So you installed the full Akrapovic exhaust including removing the OPFs? Yes Full Akrapovic......It was VERY HARD finding out what exactly they changed took 14 hours of searching thru the code and compering the 2 maps but once we got that it was done in 20 minutes
      12-24-2019, 05:06 PM   #17
Aronis
Aronis's Avatar
2270
Drives: 2018 M5
So if you change the brightness of the day time running lights, or turn on VIM, or code off ADS you've voided your warrantee?????
Um...not sure..
Mike
2018 M5 and 2019 Porsche Boxster GTS
Prior. '94 325is, '97 M3 Lux, '16 M2
      12-24-2019, 05:12 PM   #18
Mightyhoof
19
Drives: BMW M5 COMP
2019 BMW M5  [0.00]
https://ibb.co/JxNvdC6
      12-24-2019, 05:28 PM   #19
krleas
Drives: BMW M5 F90 2020
The warranty stays 100%
      12-24-2019, 06:07 PM   #20
Mightyhoof
19
Drives: BMW M5 COMP
2019 BMW M5  [0.00]
Any modification to vehicle MAY void warranty if caused damage and proven to be related to that. So saying all ECU Flash will void warranty is wrong...
      12-24-2019, 06:08 PM   #21
Mightyhoof
19
Drives: BMW M5 COMP
2019 BMW M5  [0.00]
Um...not sure..
Mike
Good point
      12-24-2019, 06:29 PM   #22
Mightyhoof
19
Drives: BMW M5 COMP
2019 BMW M5  [0.00]
So how Manhart offers:
https://www.manhart-performance.de/s...petition?c=226
and publicly states "....ECM is the solution since it will deal with any OPF/GPF errors accordingly. OPF-Delete is now a piece of cake and you don’t have to worry losing your factory warranty!"
