07-10-2019, 12:51 PM | #1 |
2035
Rep 1,842
Did anyone had to add cooling fluent ?
Hi all ,
I was wondering if anyone of you had to add cooling fluent ? Yesterday , while the first start of the day (so engine cold) , I immediately got a warning message saying cooling fluent was low. I added some fluent , for the level to be between MIN and MAX , as recommended in the iDrive , and the message never appeared again on my way back home over 500km (350 miles). My car has 22 000km (13 670 miles). I took an appointment for service next week , better do it know than later (iDrive says service is requested in 3800km). Thanks for your feedback ! |
07-10-2019, 02:21 PM | #2 |
266
Rep 770
I believe there is a recall/service bulletin specifically for the F90 from BMW for this issue. I never got an actual low coolant warning message but my dealer service department did inform me that they also took care of a minor coolant issue during my 1200 mile service.
2021 A6 Allroad, 2020 SQ7, 2019 M5 Comp, 2011 GT3
past: A4, S4, X5 4.8is, SLK55, E60 M5, RS4, ML63, E92 M3, Q5, Touareg TDI, Escalade, SQ5, RS7, Velar FE, Q7 |
07-10-2019, 02:23 PM | #3 |
25
Rep 41
Yes this happened to me just last Saturday. I topped it up (maybe a pint or so low) and called the dealer. Not heard anything.
I only have about 4k miles. 19CP. |
07-10-2019, 02:33 PM | #4 |
2035
Rep 1,842
Thank you folks.
So it's a good thing that my car goes next week for the second service , a little bit earlier than it should. Funny thing , I've never added oil yet on the M5. On my X5M , I've added 1 liter of oil at 15 000km , halfway between the first and second service. |
07-10-2019, 02:40 PM | #5 |
25
Rep 41
spoke to the service dept and they said there was a "recall" for this issue. Don't know if they really meant a recall or a bulletin. This was Stevens Creek BMW. Taking it in next week.
07-10-2019, 02:43 PM | #6 |
2035
Rep 1,842
I never got a call from the dealer , or a letter letting me know about this.
I'm not driving my car until my appointment next week , I rather take no risk. |
07-10-2019, 04:15 PM | #7 | |
///M
6654
Rep 3,683
I did the sam on mine after 7K
Life is too short...enjoy your life
///M |
07-20-2019, 10:28 AM | #8 |
2035
Rep 1,842
My car was in for service yesterday , 3600km before the "normal" schedule.
I prefered to have my car checked ASAP. I've explained that I had to add some cooling fluent , ant they said that there was an actual recall on my car car for this purpose. They checked everything , and all is fine. No leaks. I can't explain why my car needed cooling fluent to be added , but I'm glad everything is fine. |
08-06-2019, 02:49 PM | #9 |
57
Rep 211
Dropped my car off today for service have about 4700 miles on it. Coolant light came on second time, my SA said there's a recall with the coolant. I will post part number after job is done.
08-23-2019, 11:17 AM | #10 |
4074
Rep 5,233
I had coolant added at some point but it was only that one time.
08-23-2019, 08:55 PM | #11 |
47
Rep 67
Drives: M5 competition
Error for coolant
I just had my car serviced for coolant. Car gave error to add coolant. Advisor asked my if I had added any. Apparently, the level of coolant was low. No leaks but why was it low? They added the coolant and will see. Thought it was odd. Car has 4500 miles. I have owned many BMWs, first time to add coolant.
11-23-2020, 11:28 AM | #12 | |
134
Rep 254
11-23-2020, 01:57 PM | #13 |
Rep 21
I had the warning last week. The dealer took it the next day, did a pressure check and added coolant, job done. I asked was there a recall, they said no. There’s two coolant tanks apparently, classic one-upmanship!
11-24-2020, 08:26 AM | #14 | ||
4140
Rep 7,160
Drives: F90 M5 / F15 50i
Now track use is a different story. This isn't a track car. It will heat soak.
'07 Yamaha R1 (sold)
SatinblkF90134.00 |
11-24-2020, 07:42 PM | #15 |
2272
Rep 3,297
Every winter....when the weather gets cooler, I have gotten that low coolant warning, I have added ?8 ounces each year? Seams like that is not that unusual in the colder climates. It is just that the newer cars actually have sensors for the coolant level, were older cars did not and you would just check the levels by eye on occasion.
Mike
SatinblkF90134.00 |
11-26-2020, 11:10 PM | #16 | ||||
134
Rep 254
https://f90.bimmerpost.com/forums/sh....php?t=1726722 And check this insta post |
11-27-2020, 10:49 AM | #17 | |||||
4140
Rep 7,160
[QUOTE=SatinblkF90;26952975]
SatinblkF90134.00 |
11-27-2020, 11:10 AM | #18 | ||||||
134
Rep 254
[QUOTE=Maverik259;26953855][QUOTE=SatinblkF90;26952975]
I think the thermostat is computer controlled but they are saying installing this one integrates into the car as the OEM one does just that it triggers the cooling at 90C instead of the stock 105C. |
11-27-2020, 02:12 PM | #19 |
74
Rep 86
Just FYI, since I didn’t see anyone mention it:
This car has two coolant loops with two places to add coolant. Make sure you do both if you’re doing it yourself. When this came out BMW claimed something about not accounting for expansion/contraction and then just being under filled from the factory IIRC. Nothing about consumption they admitted to. |
SatinblkF90134.00 |
11-27-2020, 11:29 PM | #20 |
51
Rep 230
I got this cooland level low warning at 11.000 km.After taking this warning message several times I added 250 ml drinkable water to my coolant, and i never get this message again.I think it's a common issue for m5 f90.
SatinblkF90134.00 |
12-05-2020, 11:45 PM | #22 |
4140
Rep 7,160
What is fluent?
