BMW M5 F90 (2018+) General Forums F90 M5 General Forum    New personal best 1/4 mile in 2020 M5 Comp
      10-30-2019, 10:08 AM   #23
limeypride
limeypride's Avatar
Drives: 2022 M8 Competition GC
Originally Posted by Vic55 View Post
Dean I didnt check all the posts but what is your octane? I wonder what your exact map on my shitbox 91 would yield with probably less optimal conditions here in CA?
Oh nice numbers Mister.
92 octane plus 20oz of Klotz which, if their claims are to be believed, adds 2psi and change. On the topic of Klotz, I'm a believer—I don't think I've concluded that of any other brand.
As it stands, I'm running a tank with no octane booster hence my earlier comment around being uncertain if 5.5 feels right. Terry reviewed logs and didn't call anything out but I'm not convinced yet so may end up with 5 flat
I have a 20oz metal bottle of the stuff in my trunk so that may become my normal fill up additive.
      10-30-2019, 10:12 AM   #24
limeypride
limeypride's Avatar
Originally Posted by gpdriver17 View Post
That's flying for just a JB4 basically. How much can the 60' time improve though? I don't know if it would be much better on a track. Maybe a 10.2. Is pump gas 93?
92 here (but with octane booster for that run I think—I'm uncertain because I've been going back and forth to get a sense of how the car feels. I originally thought that run was flat 5 but when I went into the JB4 the morning after it was mostly at 5.5 as described earlier so I'm assuming I must've had Klotz in the mix... ugh, me again brain).
      10-30-2019, 10:21 AM   #25
limeypride
limeypride's Avatar
I should also emphasize that not only did that run yield amazing numbers, it also felt just as strong. For the launch, I used full-on launch control letting the car do its thing, when it shifted to 3rd I literally shrieked at how hard she pulled—I don't usually do that.
      10-30-2019, 11:01 AM   #26
onfireX5
3619
Drives: F90M5,F85X5M
I’m going to try a bottle of Klotz if it adds 2psi.
Awesome ride btw !
limeypride4425.00
      10-30-2019, 11:06 AM   #27
limeypride
limeypride's Avatar
Awesome ride btw !
That's what it claims... at 1oz per gallon IIRC.
      10-30-2019, 11:14 AM   #28
onfireX5
3619
PSI or PTS hmmmm
      10-30-2019, 11:55 AM   #29
limeypride
limeypride's Avatar
PSI or PTS hmmmm
Well, I've given it some thought and concluded... I don't get it.
Gimme a hint?
      10-30-2019, 01:56 PM   #30
Hockeytyme
Hockeytyme's Avatar
575
Drives: 2020 M5C
Vic, have you happened to see 93 or 100 oct pumps anywhere near us? There used to be one off the 405 near Laguna but that was years ago.
DME: 1848 DA 0-60 2.42 -- 1/8 Mile 6.38 -- 1/4 Mile 9.89 -- 60-130 5.91
Evolve: 1418 DA 0-60 2.48 -- 1/8 Mile 6.47 -- 1/4 Mile 10.05 -- 60-130 6.48
JB4: 1096 DA 0-60 2.54 -- 1/8 Mile 6.50 -- 1/4 Mile 10.05 -- 60-130 6.18
IG: @hockeytyme All runs on street with no prep on 21 inch wheels and PS4S tires
      10-30-2019, 01:57 PM   #31
onfireX5
3619
Gimme a hint?
Just kidding ya since you’re Comp is blazing fast ! Octane points !
limeypride4425.00
      10-30-2019, 02:07 PM   #32
Vic55
Vic55's Avatar
19365
Drives: 2023 BMW M8 Competition Coupe
Newport 76 on San Miguel is prob the closest.
They got 100.
There is a Corona Del Mar Chevron that might have too but I cant confirm.
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White
2022 Porsche Carrera GTS Coupe Shark Blue
2020 Audi R8 V10 Performance Suzuka Gray
2012 Mercedes Benz C63 AMG Black Series Obsidian Black
      10-30-2019, 02:10 PM   #33
Hockeytyme
Hockeytyme's Avatar
575
Drives: 2020 M5C
They got 100.
Thanks, that's not too far actually. Just a couple toll roads away :P
      10-30-2019, 02:26 PM   #34
Vic55
Vic55's Avatar
19365
Im too lazy to even go---My car is plenty fast on shitcansuckmyass 91 octane LOL.
      10-30-2019, 02:50 PM   #35
Hockeytyme
Hockeytyme's Avatar
575
Drives: 2020 M5C
haha yea I hear ya. I just might need it on a few occasions to push the envelope a little
      10-30-2019, 02:54 PM   #36
limeypride
limeypride's Avatar
<Arnie accent>
"I laugh at your girlie gasoline."
</Arnie accent>
      10-30-2019, 04:43 PM   #37
Vic55
Vic55's Avatar
19365
<Arnie accent>
</Arnie accent>
Ill be BACKKKKK
      10-30-2019, 06:15 PM   #38
gtenedio
Drives: '%E2%80%9909 e92 m3, '19 X3, %
Originally Posted by gtenedio View Post
great results man!
care to share your map 6 set up?
Sure. 5 psi from 1500 rpm through 3000. Then 5.5 through 6000 rpm and 5 psi at 6500 and 7000 rpm.
Again note: the stock JB4 firmware doesn't work on 2020 M5 Comps (possibly non Comps, too, I don't know for sure on that one). This run was on firmware I got from Terry in an effort to fix what he referred to as changes to boost targeting in 2020 models.
Note also: I'm still not convinced that 5.5 feels quite right without octane booster—still tinkering—so I may lower my daily to 5 flat or just get used to adding 20oz per tank.
im confused.
are you referring to 5psi over request?
      10-30-2019, 06:19 PM   #39
gtenedio
great results man!
im confused.
nvm. re read map 6 rules.
      10-30-2019, 06:39 PM   #40
limeypride
limeypride's Avatar
Likewise, I wasn't aware of that change until I was chatting with Terry due to 'implausible boost target' errors.
      10-30-2019, 06:45 PM   #41
gtenedio
any changes on boost by gear, or boost safety?
      10-30-2019, 06:59 PM   #42
limeypride
limeypride's Avatar
No boost reduction in 1st, 2nd or 3rd--doesn't need it so far.
I had to up boost safety to 27 to stop it triggering valet mode--this is one of those changes where I spend days carefully monitoring the end result through logging and feel. <-- * THIS IS RISKY; DO SO AT YOUR OWN PERIL **
      10-30-2019, 07:51 PM   #43
gtenedio
these turbos are good up to mid 30 spike.
but agreed. im currently set on 28
      10-30-2019, 08:14 PM   #44
limeypride
limeypride's Avatar
Good to know!
May I ask how you know?
