10-26-2022, 08:29 PM | #2 |
551
Rep 638
No discernible difference between noncomp vs comp brakes.
If you are talking CCB vs Regular, there definitely is difference. |
Maverik2594140.00 jnotrom711774.50 |
10-26-2022, 09:08 PM | #3 |
133
Rep 392
Drives: 2021 M5C
10-26-2022, 09:18 PM | #4 |
4140
Rep 7,160
Drives: F90 M5 / F15 50i
Love how much people think the comp is different than a normal M5
'07 Yamaha R1 (sold)
10-26-2022, 09:20 PM | #5 |
551
Rep 638
10-26-2022, 10:40 PM | #6 |
775
Rep 569
Drives: 2019 M5 Competition
As a comp owner myself, I agree its pretty funny, they're nearly identical cars, with very little bit of difference. We should do a poll though, because I feel like its shifted a little, its not the comp owners anymore being triggered, its the CS owners being triggered or maybe its just me. |
10-26-2022, 11:26 PM | #7 |
38
Rep 36
10-27-2022, 01:23 AM | #8 | |
775
Rep 569
Only carbon, or no carbon. All M5s have identical brakes, steel base vs steel comp, or carbon base vs carbon Comp vs carbon CS. Now, I suppose one could argue minor (very minor, like maybe inches, if that) differences in stopping distance or performance (highly negligible) due to different weights of the car itself, and if any suspension would change the stopping performance. But the brakes by themselves, identical. But that argument would be a BIGGG stretch and would likely be pure semantics. |
10-27-2022, 01:48 AM | #9 | |
2511
Rep 4,381
IIRC there is also a brake boost sensor that reacts to a quick change from throttle to brakes and assumes that you are in need of some quick deceleration. On brake performance...its not going to make any difference to an M5s brake stopping distance (single stop, street driving) whether you have std brakes, carbon ceramics or even F1 brakes. The stopping distance is a function of tyre grip once the ABS is activated. Assumes CCBs are at working temp, if cold/wet then they may take slightly longer to stop vrs std. |
10-27-2022, 01:55 AM | #10 | |
775
Rep 569
However your thread is referring to comp brakes being all or nothing.... Thats not a comp difference. The brakes are the the same on all m5s. If your comp has carbon ceramic brakes, and the base you drove had steel, that would be a major difference. But the comp itself does not come with carbon brakes, its an option. Just like its an option on the base to get (the same) carbon brakes. But steel for steel or carbon for carbon theyre identical. |
10-27-2022, 02:27 AM | #11 | |
1540
Rep 2,008
10-27-2022, 06:51 AM | #13 |
Me :)
10
Rep 6
Drives: F90 M5 Competition
OK, I'm going to chime in here - you guys are correct, Carbon (composite) brakes absolutely do not give you any improvement in braking distance (except see *).
At handling limits, the decreased weight at each corner (unsprung mass) WILL assist. We'll not notice this on the road - on the track, and at 9-tenth's, the handling will be improved ever soo slightly... * On the track, when you're really pushing that brake-pedal, lap after lap, the carbon brakes DO assist with 'heat soak' - saving you from boiling the brake fluid, and thus makes braking response repeatable and, ultimately efficient 👌 You all need to try threshold-braking, where you brake until -just before- the ABS kicks-in, this decreases distances even further than relying on the ABS alone: maybe 10-20% improvement over pure ABS. It does take some practice... if you can feel 'pulsing' of the pedal, but no ABS kicking-in, then you've got it 😊 This is from knowledge gained as a pro driver (I have a race-license), and worked for Porsche. Yes I've turned from the Dark-side to The-Light 👍 |
10-27-2022, 08:55 AM | #14 | |
2511
Rep 4,381
I've tried mine at 100 mph and it activated and held ABS function no problem. No sure how it would be at 150mph...that would be a lot of energy (heat) to dissipate. |
10-27-2022, 10:29 AM | #15 | ||
982
Rep 1,797
10-27-2022, 10:47 AM | #16 |
5234
Rep 10,616
100 is nothing. 150 is the better test. The question is how many times in a row would you have to stop from 150 to 0 to trigger a problem. 5?
Over the years, I have read big brake kit tests where typically virtually no stopping distance improvement shows up until after about 10 stops in a row from 100 mph when the same grade pads and fluid are used on the original and BBK. |
10-27-2022, 12:30 PM | #17 |
780
Rep 442
I sure liked how clean my wheels stay with CCB. (and yes, I ordered them on my 23 as well for the same reason - that, plus how the fill the barrel of the wheel).
That said, I also like the initial bite of the CCBs - granted I never drove an M5 with steel and CCB back to back, my experience is limited to my F80 and my F97. Brakes in the F80 were amazing (lighter car), brakes in the F97 were not so impressive (heavy beast). Brakes in the F90 were pretty amazing to me. I don't track, I got the CCBs for me - they do perform great, they look great and M compound steel brakes make a TON of dirt (not saying CCBs are dirt free - but sure makes weekend detailing worth it). Expensive for that reason alone? Yes of course but then again spending 100K + on any car isn't exactly a rational financial decision.
2023 M5C (MBB, Tartufo, CCB, MPE, splitter, skirts, diffuser and pro spoiler), 2022 X3MC (gone), 2022 M5C (gone, not forgotten), 2020 992S (gone), 2018 M3C (should have never let it be gone), 2015 550i (gone), 2013 550i M-Sport (gone), 2010 Panamera (good riddance) (this list is getting entirely too long).
10-27-2022, 04:06 PM | #18 |
2511
Rep 4,381
10-27-2022, 05:02 PM | #20 |
551
Rep 638
my comment spurred into something way too deep...
I was simply saying the brake feel (not performance metrics) of a ceramic setup vs non ceramic setup is noticable... pedal travel is far less, and the initial bite is harder. |
10-27-2022, 06:14 PM | #21 |
351
Rep 604
I agree with this and have had both setups (current are ceramics)
