BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    H&R springs... M5 or M550i?
      05-20-2019, 11:00 PM   #23
clutchdj
1879
Drives: a few cars
F90
Hey guys, F90 non comp on stock 19" pirelli's
I have noticed the stock rebound dampening in the rear is aggressive without being bouncy; looking to soften things up for road trips tbh. I like I slight fwd rake that the F90 H&R's display above.. sort of like splitting hairs as they both look awesome
Can anyone comment on which spring set (m550 H&R or F90 H&R) offer a more compliant ride. TIA
isanube24.50
      05-22-2019, 03:47 PM   #24
creedthings
creedthings's Avatar
78
Drives: BMW F90 M5 Comp
I have 21" rims on mine will the 550 springs work with that or should I do KW HAS???
      05-22-2019, 04:38 PM   #25
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
Usually, lowering spring will not soften up your ride.
My suggestion is to play with tire pressure before looking into lowering spring.
21" will work with M550iX spring, just depending on how is your 21" setup.
But, if you are not sure about how low that you want to go, KW HAS will give you a range of drop that you can play around with to your liking.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      05-22-2019, 08:28 PM   #26
clutchdj
1879
Drives: a few cars
I run 28psi cold all round. I am beginning to think it’s the brick
hard pirelli sidewalls that I’ve experienced in the past. I have KW coil overs w/Michelin’s on my F80 and the ride is less harsh. Do you sell springs. Which H&R is more compliant?
      05-22-2019, 08:54 PM   #27
r33_RGSport
Have you check that the delivery block in the shock has been removed?
Spring wise between M550iX and M5 should be similar.
I've rode in Vic55 with H&R M5 spring and my local customer's with KW HAS. None on the M550iX H&R spring on F90 M5 yet.
I am fine with either of them, no complaint at all.
So, my guess, the M550iX spring on F90 M5 should be good also.
      06-13-2019, 12:53 PM   #28
clutchdj
1879
Drives: a few cars
it was the harsh 19" Pirelli tires as I had suspected. Even at 28PSI cold, the side walls did not compress which was actually amazing. Put on stock 20"s w/MP4s and the ride's less jarring. I did check for suspension blocks - did not find any :-)
      06-13-2019, 10:13 PM   #29
th3hitman316
th3hitman316's Avatar
34
Drives: Frozen Red F90
M550
dardeca499.50
      06-18-2019, 02:22 PM   #30
clutchdj
1879
Drives: a few cars
How's the suspension compliance around the boroughs with the springs. Looks nice.
      06-20-2019, 10:35 PM   #31
th3hitman316
34
Not gonna lie on NYC roads it's harsher but whenever I go upstate you can feel the difference. #NYCRoadsSuck
clutchdj1878.50
      06-30-2019, 06:00 PM   #32
TrevorM3
3322
Drives: 6.3 AMG
should have my fathers H&R 550i springs on in two weeks, will post pics.
      06-30-2019, 06:09 PM   #33
FloridaM5
FloridaM5's Avatar
Drives: 2021 M3 Comp RWD
  [5.83]
I bought the 550 springs too. haven't installed yet...thinking about going the dinan route. looks like a nice solution.
      06-30-2019, 07:14 PM   #34
TrevorM3
3322
Drives: 6.3 AMG
dont like the 550 springs?
      06-30-2019, 07:22 PM   #35
FloridaM5
FloridaM5's Avatar
  [5.83]
I do like the way they look on members' cars. Haven't installed on mine yet. Was waiting until after 1200 mile service. Seeing the dinan kit, which looks quite nice and effective, may head in that direction.
      06-30-2019, 07:28 PM   #36
TrevorM3
3322
Drives: 6.3 AMG
same here, waiting to do 1200, and will have tech install for me.
where in fla are you?
      06-30-2019, 07:35 PM   #37
FloridaM5
FloridaM5's Avatar
  [5.83]
I'm in orlando
      06-30-2019, 07:39 PM   #38
TrevorM3
3322
Drives: 6.3 AMG
I'm in orlando
ah ok.
some roll racing going on the 13th down here in Sofla, was going to extend the invite.
      06-30-2019, 07:45 PM   #39
FloridaM5
FloridaM5's Avatar
  [5.83]
I'm in orlando
ah ok.
oh cool man. appreciate that thought.
      07-05-2019, 01:17 PM   #40
Pazzo009
Pazzo009's Avatar
1113
Drives: X5M,M3(46&36),812SF
M550 sits perfect
Instagram-Pazzo009
F90 M5(gone), S580 (until G90) X5M, 812SF
E46 M3 (LSB on LSB)
E36 M3 Avus
saveywil1230.50
      06-28-2021, 02:12 PM   #41
2URSITE
Drives: BMW M5 Competition
Hello,- i have 19 M5 Competition. Currently on 20" looking lower car. I know the M5C sits a bit lower than the regular M5. Any suggestions on H&R Springs - M5 F90 or M550i. Looking to lower to fill in gap
FRONT and RESR picture attached
      06-28-2021, 09:36 PM   #42
GTATX
GTATX's Avatar
Drives: 2020 M8 Comp First Edition
So I had 20 inch Titans before 21 inch BBS so u can see both in these pics. I'm on H&R m550i springs. Thx
GT
2020 BMW M8 Comp First Edition
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
2018 Maserati Ghibli SQ4 GranSport
      07-11-2021, 10:42 AM   #43
Damzz
51
Drives: 2019 M5 Competition MBB
Hello,
I have a ‘19 M5C and looking to lower it, however, just the front. I’m happy with the way the rear is set up, but I’m planning to put a 10mm spacer and dropping it on H&R springs. Curious to see if anyone here has a similar set up and how does the car run afterwards? Is there a possibility of issues with the fronts having spacers and different springs to the rear?
      07-12-2021, 06:37 PM   #44
GTATX
GTATX's Avatar
Originally Posted by Damzz View Post
Hello,
I wanted to something similar but was advised against it as spring tolerance in front versus rear will be different and wouldn't work with the car and may cause ride issues. Thx
GT
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
