ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Engine, Exhaust, Drivetrain Modifications
  TireRack
      11-20-2022, 08:50 PM   #155
dre99gsx
512
Drives: 1994 Toyota Supra
Some images of the diff cooler. Exits out of some holes behind the original license plate area.
wdb4738.00
      03-18-2023, 09:41 PM   #156
Dan [Sac]
Drives: 2006 Z4 Si
Originally Posted by 3GFX View Post
Redneck mathz:
If the stock drivetrain is built for 200,000kms at 325hp. Wouldn't that mean you should get half the life from twice the power?
NOW TURN UP THE BOOST
You did that like my wife does cooking...
"It says 30 minutes at 225F, so I'll just do 15 at 450F"
I go through more pans than ratchets
'06 3.0Si
      03-19-2023, 08:54 AM   #157
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1624
Drives: 2007 Z4MC
Good job mate, that oughta help quite a bit. Extra fluild too.
      04-10-2024, 04:28 PM   #158
dre99gsx
512
Just a quick recap on the GS6-37BZ transmission and how it's holding up, as well as the Z4 non-M 3.64 Diff (with a Quaife).
I have no idea how much longer these two will last, but:
- I'm on my 2nd transmission. 1st one lasted ~155 20 minute HPDE sessions before it blew. I am pointing the finger at heat. I've since installed two oil coolers and a pump, keeping it below 230F. Latest transmission is at ~70 20 minute sessions and going.
- I'm on my 4th? diff, this latest one is on ~49 20 minute sessions. Again, added larger oil cooler and pump.
I'm not sure if the cooler fluid will extend the life of these any further, but I'm at 630+whp for all of these events. I do not launch the car.
I think it's safe to say these two can handle 630whp with quite a bit of abuse. I went into this thinking the transmission would be a box of marbles but it's somehow holding the power. Perhaps don't spread this secret because I need spares to exist
The diff is smaller than the Z4M, and I may upgrade the entire rear end at some point. I'm itching to bump this to 700whp soon because why not.
I do wish there was someone else with evidence of power limit on this transmission. Doesn't seem to be much data out there...
wdb4738.00
      04-12-2024, 12:20 PM   #159
wdb
dances with roads
wdb's Avatar
4738
Drives: '07 E86, '02 996, '95 Seven
Great data, thanks for sharing it.
I imagine that most of the race prepped cars are built for a particular class and don't have the kind of power you do.
      05-05-2024, 01:58 PM   #160
Dr. Minimus
Drives: BMW z4 3.0si coupe
Long time follower of the build, happy to see it's still running strong.
I realize this was awhile ago, but what inputs besides the crankshaft position sensor did the BMW DME require before the EPS was enabled? I am planning an LS swap for the same model year.
Also, in case the rear differential is still giving you problems Seem legit garage sells a carrier for a Ford 8.8 diff. I assume you have seen this, but just in case.
https://www.seemslegitgarage.com/pro...frame-axle-kit
      05-09-2024, 01:17 PM   #161
dre99gsx
512
RPM signal was all that was needed.
I'm saving up my coins for a Z4M rear frame/diff to replace this when ready. Parts alone will be a fraction of the cost of that cool subframe, but thanks for bringing it up. Didn't know there were other options
zpost
