04-07-2021, 01:44 PM | #1 |
204
Rep 243
"pre-braking" with paddle shifters to spare the brakes
Does anyone "pre-brake" as well? I come from a manual car (Audi S4), so I got used to doing this. I'm usually in D shift mode. When approaching a stop from high speed (off ramp for example), I use the left paddle shifter to downshift to the lowest gear it will let me, and continue to downshift further as the stop comes closer. By the time I actually have to brake, I'm only at 35 mph instead of 90 mph. I figure in the long run it'll spare my brakes, but shouldn't impact the gears much. Also, less brake dust.
04-07-2021, 03:40 PM | #4 | |
2594
Rep 2,683
Drives: '24 X7 M60i
I do it all the time, but if you are looking to do it to save wear on the brakes, it just adds more wear on the clutch/transmission so it's pretty much a wash (except brake pads are way cheaper to replace).
Ex Stig
'25 M5 Touring (on the list, first slot) '24 X7 M60i '22 M5 CS - (sold) |
GranitM5366.00 Maverik2594140.00 |
04-07-2021, 04:19 PM | #5 |
501
Rep 1,399
Yes, I engine break a fair amount. It's also good to coast like you mentioned to make the best use of BMW's Brake Energy Regeneration feature. Here's s snippet from the BMW Technology Insights website:
Make use of every watt: by charging the battery only when your BMW is braking, coasting or decelerating, Brake Energy Regeneration improves fuel efficiency by up to three percent and ensures that the full power of your engine is available for acceleration. Today's vehicles require much more electrical energy than older models, due to the much wider array of electric and electronic on-board comfort and safety systems. This energy is created by the generator (also known as the alternator) which converts the engine's power output into electricity. In conventional systems, the generator is permanently driven by a belt connected to the engine. BMW's Brake Energy Regeneration operates differently: the generator is activated only when you take your foot from the accelerator or apply the brake. The kinetic energy that would otherwise go to waste is now used efficiently, converted into electricity by the generator and stored in the battery. Producing electricity in this highly efficient way delivers an additional advantage: when you apply the accelerator, the generator is deactivated - so the full power of the engine can be directed to the drive wheels. Brake Energy Regeneration thus increases fuel efficiency while simultaneously enhancing driving dynamics. As a safety precaution, the Brake Energy Regeneration system monitors the level of battery charge and will, if necessary, continue to charge the battery even during acceleration to prevent a complete discharging of the battery.
Current: 2022 Donnington Grey M5 Competition, 2014 Anvil WW Jeep Wrangler
Previous: 2019 Donnington Grey M5 Competition, 2016 Silverstone M5 CP, 2013 Monte Carlo Blue M5 CP (ED on 9/1/12), 2009 Carbon Black M5, 2006 Silverstone M5, 2003 Sterling Grey M5, 2000 Anthracite 540i6, 1998 Jeep Grand Cherokee 5.9Ltd, 1990 Eagle Talon TSi AWD, 1978 Mazda RX-7 |
04-07-2021, 04:48 PM | #6 |
82
Rep 136
i have the transmission set to the 3 position and drive in sport. around town it downshifts quickly on its own. Some lights i can cruise up to and almost comes to a stop without touching brakes.
04-08-2021, 11:57 AM | #7 |
315
Rep 48
Drives: 2024 BMW M2
I do it to prevent all the damn brake dust from accumulating on the wheels!
04-08-2021, 12:24 PM | #8 |
1909
Rep 2,007
Drives: 2022 i4 M50
And it sounds cooler.
Current: 2022 i4 M50 | 2022 G07 X7
Gone: 2020 F92 M8 | 2020 G07 X7 | 2018 F80 M3 | 2017 F15 X5 | 2016 F16 X6 | 2015 F36 4 series GC |
04-08-2021, 02:56 PM | #9 |
135
Rep 196
I drive manual always....so I always engine brake. I've always done so on all my cars. Gets me to 30000 miles before changing brakes.
BrntRubber69.50 |
04-08-2021, 08:02 PM | #10 | |
204
Rep 386
Born in M Town
04-09-2021, 03:45 AM | #11 |
119
Rep 51
I do that too. As long is you dont downshift it in the hardest mode at high revs it shouldnt wear your gearbox.
I usally downshift at about 3000-3500rpm to the next lower gear. Espascially during the break-in it could help to get all that little abrasion that accoures during the break in, out of the cylinders, due to the heat and the vaccum you have by using the engine break.
Car history:
1989 E32 735i, 1992 e34 535i, 2003 E39 540i, 2014 F36 430d, 2017 F22 M240i, 2018 F87 M2, 2019 G20 330d, 2020 M4 Competition, 2020 G20 M340i, 2021 M5 Competition |
04-09-2021, 06:01 AM | #12 |
274
Rep 651
Not using the brakes is bad for them.
You must exercise them regularly and brake hard once in a while ,this is to get some movement i the caliper pistons and to get a clean rust free surface on the discs. |
04-09-2021, 08:53 AM | #13 |
We are all Longwong
138
Rep 940
Drives: F90 CP LCI
Aren't pads cheaper than tranny?
04-10-2021, 09:33 AM | #16 | |
This is my unique custom title
267
Rep 698
“Engine braking” (as was correctly identified by another forum member) uses the most powerful expensive mechanical components in your car for braking. 1.) your engine, transmission and related drive train components cost more than any of your brake system components, combined. Certainly there is a huge price delta between pads and damn near everything else. 2.) never ride your brakes. The very act of braking upsets the balance of the car and transfers weight to the front of the car. When it’s time to brake, brake. Condition yourself to find a happy medium where you can alternate throttle application on and off and only go for the brake pedal when you truly need to decelerate and stop. 3.) as was pointed out, brakes benefit from regular use. Pads should be properly seated with rotors. Good, consisten and even regularly interspersed heavy braking will get you to this state. Light braking will never get the brake system in its best shape. 4.) brakes are intended to be a consumable item component to regular car maintenance. Treating them as something to spare is wrong and ultimately not safe. 5.) take a BMW CCA driving school. You will learn all of this and much more, lots of fun, too! Enjoy! |
Pugnacious82.50 |
04-10-2021, 09:35 AM | #17 |
267
Rep 698
You’re not controlling anything with engine braking. Decelerate with the brake system and place yourself in the correct gear for acceleration. Keep the car balanced and manage weight transfer.
josec704074.00 |
04-10-2021, 09:51 AM | #20 |
838
Rep 478
I’m very surprised at the number of people who do this. Brakes are (relatively) cheap and designed for braking. Transmissions are expensive and not designed for braking. I’m no mechanic but I don’t think you should make a habit out of this practice.
04-10-2021, 09:52 AM | #21 |
267
Rep 698
04-10-2021, 11:57 AM | #22 |
1472
Rep 1,308
This seems rather dramatic. Horribly unsafe? I'm interested to see how you would you describe drunk driving and drifting at 90 mph on the highway.
Current: 2022 M5 CS
Past: 2021 M550i (BSM) Past: 2010 535 xDrive (Alpine White) |
