10-13-2021, 01:17 PM | #1 |
Rep 3
Are these tires done? 2021 M5C
Only 4K miles on the tires, Pirelli P-Zeros, but multiple track days...
Thoughts on whether or not I should replace them? Thanks Last edited by kondrami; 10-13-2021 at 01:18 PM.. Reason: add picture |
10-19-2021, 12:47 PM | #5 |
1830
Rep 1,315
Let's address high performance tires at the track...
Unless CORDS ARE SHOWING, or unless you have rain to deal with (wet track), or the tires have "heat cycled out" (you have no traction while turning, because the tires have gotten "hard" due to the high heat cycles - hot and cold), high performance tires are good all the way down to NO TREAD AT ALL. In fact, for dry traction, high performance tires are best at the lower levels of tread (the reason Tire Rack offers "shaving" service). If you have to drive them home, you have to think about rain and tread and mud and snow, etc. But other than that, performance tires are VERY VERY durable. Your wear pattern looks pretty good. I'd like to see the inside edge of both fronts, and the outside edge of the tire with the sidewall showing to comment on pressures, but what I can see looks good. Shawn |
