09-30-2021, 07:40 PM | #3 |
Rep 22
09-30-2021, 10:34 PM | #4 |
71
Rep 185
Drives: 2022 X6M
Just get your money back and get Bootmod3 and dont ever look back. Dragy numbers dont lie.
09-30-2021, 11:35 PM | #6 |
1105
Rep 1,607
Drives: 2020 M8 Comp First Edition
This numbers are really bad almost as close to stock. Go with any other reputable companies like Evolve (custom tune utku Noa), HCP, BM3 or DME.
GT
2020 BMW M8 Comp First Edition 2019 Panamera Turbo 2021 BMW X6M Comp 2019 BMW M5 2018 Maserati Ghibli SQ4 GranSport |
09-30-2021, 11:37 PM | #7 |
Rep 22
10-01-2021, 11:28 AM | #8 |
228
Rep 298
The torque dropping from 558 to 549 to 542 - is due to the fact the dyno operator just ran 3 runs back to back with only 5 seconds apart from one another. - Geez let the car cool off a few min in between, LOL.
Not sure of the fan setup - but heat soak will for sure do that. Also note this is a Mustang dyno, and typically will read about 10-12% lower then a dynojet - so your actually in the ballpark of 620 torque. Not bad I would think. Do some draggy runs and get some real times to compare with others. Hope this helps. |
10-01-2021, 11:33 AM | #9 | ||
Rep 22
10-01-2021, 01:26 PM | #10 |
87
Rep 315
for the love of christ delete that gitani tune lmao and do what this guy said above
2020 BMW m5 with some bmc filters, charcoal filter delete, and Dinan turbo inlets.
Previous BMW model 2018 bmw 340i FBO custom e50 tune 500 wheel |
10-04-2021, 07:25 PM | #11 |
IG @bmwF9xG80
3813
Rep 7,593
junshen97 i told u via FB messenger u should do a stock (baseline) dyno too. If you plan to use that dyno again go there, if not try to find an AWD Dynojet
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
10-09-2021, 07:10 AM | #12 |
Rep 3
Did you base line this car on this dyno ? Your dragy data from your other post shows the mph change from the tune over 5 mph [ with the da going from 700 to 1400 ft ] in the 1/4 that is about 80 wheel over stock . As everyone has pointed out the 91 octane is your limiting factor . Not the tune . I don't care who's tune you run they will all be limited based on the Octane . There is no magic potion [ key strokes] when you are fuel limited . There will just be broken parts . Trust me I have been tuning domestic cars for over 15yrs . Have my own Mustang awd dyno and a 20 M8GC the I am working with Alex on .
