BMW M5 F90 (2018+) General Forums Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls    Tyre pressure
      05-30-2021, 02:59 AM   #1
flanker25
Drives: X5 M40d, E90325XI,
Tyre pressure
Guys, on my M5 the BMW recommended tyre pressure is written on door sil.
What I am not sure if this tyre pressure recommended is cold and in garage level or the running condition pressure
When I push my car tyre gets warm and tyre pressure increases. so
what level of tyre pressure shall I maintain?
Thanks
      05-30-2021, 10:57 AM   #2
Superjackson
122
Drives: M550i
They are for garage level cold pressure
      06-01-2021, 01:35 PM   #3
Danny D
228
Drives: M5
Interesting point I found was, as you drive and your tires warm up and the PSI gets higher - so does the I drive recommended tire pressure.
It started at 34 then got to 40+ in the system.
      06-01-2021, 01:56 PM   #4
pbonsalb
5178
Does anyone use a lower pressure?
      06-01-2021, 02:11 PM   #5
FotiosF90M5
///M Specialist South Shore BMW
FotiosF90M5's Avatar
Drives: 2021 M5 Comp BHG/Silverstone
I do 36 front 38 rear. Good balance.
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
      06-01-2021, 03:26 PM   #6
Maxlude
United Kingdom
158
Drives: E90 330D_SE_Man, F90_M5C
I run 1-2psi lower in colder months as the mps4s are summer tyres and the comp suspension is a little brittle below 12c which means F32/R33psi.
The roads in UK are fubar
      06-01-2021, 03:40 PM   #7
samj2k
59
Drives: F90 M5, 991.1 GT3RS
Go off the in car pressure monitor instead as it adjusts with heat. I run 33/34 cold usually, it's fine on the road. I wouldn't want to run any more, it's a heavy car and when pushing you get quite a bit of fluctuation in pressure. The temp and pressure gauge is surprisingly accurate in the car, my temp gun is usually displaying exactly what the in car gauge displays. If you are really pushing hard and it's warm I'd even be tempted to drop to 28f/30r and 24f/26r on a circuit.
      06-05-2021, 02:35 PM   #8
flanker25
super thanks
      06-05-2021, 02:58 PM   #9
flanker25
I settle for 2.8 in all 4 tyres. That works on Swiss road.
Waiting for mountain passes to open, Grimsel & Furka pass are due open next Friday, looking forward to it.
If you see a snapper rocks M5 in Switzerland, it would be me. My M5 is the only M5 with snapper rocks in whole Swiss.
Search this Thread:
Advanced Search
