TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Australia > Transmission Fault Error!
      09-02-2016, 07:37 AM   #23
CYL
131
Drives: E92
Originally Posted by ash335 View Post
Hey, cool, what DIY guide did you use?
Mind sharing a link... or posting a guide.
Would love to do this too.
+1
      09-02-2016, 07:44 AM   #24
Grohouse
Grohouse's Avatar
Australia
12
Drives: BMW e90 325i
It's a preventative service, in my case it helped and smoothed out my gear changes. I couldn't say it would be a fix for you, but at 100,000kms I would certainly look into it.
If a differential slip error is coming up, is there anything out of ordinary you've heard? Loud diff, grinding diff or felt any slippage?
For those wanting the DIY:
[u2b]https://www.youtube.com/watch?v=_n2Yfl-zBzg[/u2b]
I used a large 100ml syringe to extract the old fluid, much more user friendly. Used Castrol castrol syntrax longlife 75w-90 which is the factory fluid.
      09-02-2016, 10:34 AM   #25
Avex
Australia
51
Drives: F22 M235i AW
i had no symptoms of the above. funny enough everytime that error pops up my car is cruising at fairly low speeds 20kmh-50kmh. No jerky movement felt. I've been trying to replicate that error going from Sport M5 to M4 but no cigar.
i'm gonna chalk that last error up to tranny reprogramming itself after they clear the codes, maybe that it's taking sometime to adapt again...
      09-11-2016, 07:10 AM   #26
Avex
Australia
51
update; hopefully it benefits people with the same problem:
So, with a working cable in hand, i've managed to dig deeper and find out exactly what the whole deal is with this transmission fault. i'm almost convinced it's an issue to do with software rather than hardware...
INPA shows error in the EGS module code 4F8D, quick google redirects to a post on e90:
http://www.e90post.com/forums/showthread.php?t=1036295
I have always been very skeptical of all these finicky process driven solutions, but I understood the logic behind what the method was trying to achieve, it was obvious that the aim was to change the adaptive values stored in the transmission ecu through rote repetition.
But what was most valuable from that thread was figuring out how to successfully recreate the problem over and over again. I manage to have the transmission fault pop up at command knowing what driving patterns were bound to give me the error. From the thread, it was the 'D' downshift pattern (or engine braking with no interference from using my brakes) from gear 5-4-3 to stationery. So I tested that on a quiet street and sure enough, I had the fault come up each and every time it slowed to a crawl using engine brakes.
The fix? I would've assumed the workshop would've done this during service as I was told it was during the handover but I didn't wanna leave it up to chance and did it with INPA again anyway. I reset the adaptive values in the transmission menu and verified the mappings were all showing 0. Drove my car out and attempted to recreate the transmission fault again, voila, this time car was still slightly jerky but no error came up. Did this for another 10 or so times and I'm now fairly confident the car has learnt the proper downshift and slip differentials in the ECU are in tune. So the problem seems to have been solved, for now anyway.
If you don't see any further updates from me on this thread, then the above could be a helpful and inexpensive fix if your mechanics are unsure why your transmission is giving you errors and are suggesting a rebuild to make it go away.
      08-04-2018, 03:33 PM   #27
JohnWinemaker
Drives: 2011 335is
I have a 2011 335is DCT with 67,000 miles. Yellow cog light came on and went into limp mode. Dealer drove it three days in a row and could not duplicate the behavior. Error code 0x005A53 DKG:Gearbox overheatinghase red. Fluid sample was withdrawn and found metal filings. Recommendation: DCT replacement for $10,000. The car was never tracked, never driven in stop-go traffic, mostly highway miles. No one knows what caused this DCT to fail.
      08-04-2018, 04:37 PM   #28
Aus335iguy
Aus335iguy's Avatar
Australia
650
Drives: 2009 e92 335i MSport DCT
2009 BMW 335i  [10.00]
The dealers dont do DCT well generally and will almost always say that. A second opinion on a 10k fix froma qualified independent mechanic might help. Where are you located ?
Over heating generally occurs when the car is being driven hard or might simply be low on fluid.
When you doppelkaplung you doppel your fun.
      08-04-2018, 07:19 PM   #29
JohnWinemaker
Drives: 2011 335is
I am located in Paducah, Kentucky USA
      08-05-2018, 03:08 AM   #30
Aus335iguy
Aus335iguy's Avatar
Australia
650
Anyone familiar with that area help this guy find an Indy to help out ?
I'm in Sydney Aus so won't be much help to you
      10-12-2020, 05:41 AM   #31
closer_ist
Drives: bmw e90 320d
2007 e90 320d 167k km 4f8d warning automatic transmission on my car. but but there is no gear shift gap or slippage in the car. and this way I have received this warning 4 or 5 times in the last 1 year. the mechanic says the transmission needs to be renewed, but it didn't seem convincing to me. Because as I said, there is no problem in shifting any gear in my car. Anyone know about the software update? or is there someone to help in general .. Thanks...
      06-08-2021, 09:57 AM   #32
Bimmer_Seb
227
Drives: 2022 X7 M50I, M4 F83, M3 E93
2023 BMW X7  [0.00]
2019 BMW M4  [0.00]
2011 BMW M3  [0.00]
Here’s my 2011 335i
      06-09-2021, 01:20 AM   #33
Socket
Socket's Avatar
4547
Drives: 335i
2008 BMW E92  [0.00]
Originally Posted by calisebas105 View Post
Here’s my 2011 335i
Feel free to start a new thread and introduce yourself. You have posted in a old thread about transmission problems nice car btw
      06-19-2021, 12:40 AM   #34
Bimmer_Seb
227
2023 BMW X7  [0.00]
2019 BMW M4  [0.00]
2011 BMW M3  [0.00]
Thanks I didn’t know I’m new to this haha
      06-20-2021, 03:18 AM   #35
Socket
Socket's Avatar
4547
Drives: 335i
2008 BMW E92  [0.00]
No worries at all
      01-06-2024, 09:00 PM   #36
witnesscf
Drives: E90 330i USDM
Only get it after drifting around in the snow so I assume it’s a heat thing. Seems to throw me in second gear to start off with the error. Restarting the car clears it and it doesn’t come back until an hour of drifting around or so. Car still shifts smooth and the diff is fresh so I know that wouldn’t cause any problems.
