BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    Worlds first M5 F90 Stage 1 ECU tune
Closed Thread
      06-28-2018, 05:03 PM   #1
Halim@HCP
Denmark
721
Drives: BMW F80 M3
https://www.facebook.com/HalimCazimi...type=3&theater
Dynographs will be posted tomorrow, we were very close to 700AWHP! All on 98RON(93OCT) and a stock car
Dynoroom temps were above 40 degrees celcius
somer966.00
      06-29-2018, 12:29 PM   #2
koko f90
12
Drives: bmw m5 f90
Any news?
Is the tune is true obd or you removed the ecu?
Did you check performance and acceleration time ?
      06-29-2018, 12:31 PM   #3
Halim@HCP
Denmark
721
Drives: BMW F80 M3
Originally Posted by koko f90 View Post
Any news?
Attached are our first version of the Stage 1 tune on 98RON. WHP/WNM and crank HP/NM
All measurements are done in AWD mode
Dip down low is a throttle closure that we will fix next time on dyno
      06-29-2018, 12:46 PM   #4
koko f90
12
Drives: bmw m5 f90
Very nice
Jb4 made the same gain but your draph is looking better
They did 7.3 sec 60-130 mph
Do you have some acceleration info?
Do you cracked the ecu or you flash the car true obd?
      06-29-2018, 12:50 PM   #5
Halim@HCP
Denmark
721
Drives: BMW F80 M3
Very nice
Very nice
Cool, the issue with a piggyback tune is that the AFR is high 14. And those runs were on E85 mixes.
It's a real flash tune, ECUs unlocked on bench without opening. Rest is done by OBD
      06-29-2018, 12:56 PM   #6
koko f90
12
Drives: bmw m5 f90
Without opening?!
Interesting!! Good job
Yes it was with e85 mixed (terry said it was Few liters)
Did you check some acceleration times??
      06-29-2018, 01:02 PM   #7
Halim@HCP
Denmark
721
Drives: BMW F80 M3
Without opening?!
No acceleration times yet as it's over 40C ambient there. Hopefully soon the temp drops to 20-25C. Should do 5.9-6.2 seconds 100-200km/h
We will try racegas too, I'm sure it can do 750whp easily
      06-29-2018, 01:53 PM   #8
koko f90
12
Drives: bmw m5 f90
Great!
How much psi do you raise?
      06-29-2018, 01:55 PM   #9
Halim@HCP
Denmark
721
Drives: BMW F80 M3
Great!
Stock was 1.45 bar boost max, we run approx 0.2 bar more in the midrange over stock and 1.6-1.7 bar at high rpm
      06-29-2018, 02:03 PM   #10
koko f90
12
Drives: bmw m5 f90
Sounds amazing
Just 0.25 bar over stock to gain that power and do that time
Is crazy
      06-29-2018, 03:24 PM   #11
shahin
170
Drives: 18 M5 FE,15 M6 GC, 12 M5,06 M5
983 Torque!!!
Is that correct?
      06-29-2018, 03:27 PM   #12
onfireX5
3619
Drives: F90M5,F85X5M
What are the mods on the 636 rwhp graph ?
Have you tried a 2wd dyno. I’ve read conflicting reports that you can not dyno in 2wd as the transfer case can force the front wheels to operate ?
      06-29-2018, 03:33 PM   #13
Halim@HCP
Denmark
721
Drives: BMW F80 M3
We tried 2WD and it put down less power ~10whp
      06-29-2018, 03:36 PM   #14
onfireX5
3619
Do you think you could dyno test it on a 2wd dyno even though the power reading would be down 10rwhp ?
      06-29-2018, 03:38 PM   #15
Halim@HCP
Denmark
721
Drives: BMW F80 M3
We did and it put down 580whp
      06-29-2018, 03:40 PM   #16
onfireX5
3619
With the front wheels on the ground, not on rollers ?
      06-29-2018, 03:40 PM   #17
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
Holy F*** this is amazing... Subscribed.
      06-29-2018, 03:45 PM   #18
onfireX5
3619
Just saw “cluctch hp”. Disregard the 636 question.
GREAT JOB !!!!
      06-29-2018, 07:18 PM   #19
koko f90
12
Drives: bmw m5 f90
Dme tuning working on they stage 1 tuning
It will be great comparing
The problem with flash tune is the warranty
If was a way to flash and keep the warranty I would do it right now
      06-29-2018, 09:54 PM   #20
somer
966
Drives: F10 M5 CP
Originally Posted by shahin View Post
983 Torque!!!
Is that correct?
newton meters, 1000nm = 737lb/ft
      06-30-2018, 03:21 AM   #21
maciejm
Drives: BMW M5 F90
By the way:
+ 147 HP + 125 Nm ->
https://www.chiptuning.shop/en/bmw/5...441kw-4395ccm/
maybe this should have its own topic?
      06-30-2018, 03:40 AM   #22
Halim@HCP
Denmark
721
Drives: BMW F80 M3
They are not working on this. We are the only one in the world with access to the ecu.
All others just buy files of Homepages and claim they are tuners lol
Appreciate 2
Mcc420475.00
FSociety3812.50
Closed Thread
