BIMMERPOST Universal Forums General BMW News and Cars Discussion    My Big New Coupe: Dinan Supercharged 840i
      11-22-2015, 07:12 PM   #1
JEllis
JEllis's Avatar
532
Drives: E36 M3, E92 M3
BIMMERPOST
     Featured on BIMMERPOST.com
A few months ago I purchased a full Stage 2/3 E31 840i OBD1. I was able to get what I believe was a tremendous deal for what has turned out to be an epic car.
Heres what the for sale pictures looked like.
41889262188.398631936.IM1.06.565x421_A.562x421 by JEllis, on Flickr
41889262185.398631936.IM1.03.565x421_A.562x421 by JEllis, on Flickr
IMG_0078 by JEllis, on Flickr
IMG_0061 by JEllis, on Flickr
The car showed up with some known issues. One of which was the braking. I took the car for a short drive and was immediately shocked at how bag the brakes were. Not only did the brakes not work well but there was grinding also.
IMG_0926 by JEllis, on Flickr
The previous owner included new brake pads and I set out to change the pads. Here you can see the Dinan upgraded front brakes. I believe they are CSI calipers and rotors.
IMG_0919 by JEllis, on Flickr
IMG_0921 by JEllis, on Flickr
Upon closer inspection I noticed this damage to the drivers side rotor. Turns out the previous owner had one of the pads in backwards. Easy fix. Rotor has to be replaced but the braking and feel was great after changing the pads with the correct orientation.
IMG_0920 by JEllis, on Flickr
IMG_0922 by JEllis, on Flickr
Rotor marks on the back of the pad from being installed backwards.
IMG_0924 by JEllis, on Flickr
Old pads
IMG_0923 by JEllis, on Flickr
The interior is in pretty great shape considering its age. The steering wheel will be replaced and I conducted a leatherique regiment to the leather.
IMG_0918 by JEllis, on Flickr
IMG_0917 by JEllis, on Flickr
Post Leatherique. I also use Griots interior cleaner to get all the stains/discoloration out of the carpeting.
IMG_0928 by JEllis, on Flickr
IMG_0927 by JEllis, on Flickr
I took the car out and discovered two more concerning issues. The rear wheels were rubbing badly on the fender and the car would go into limp mode during heavy acceleration.
Here you can say how bad the rubbing was on the tire.
IMG_0915 by JEllis, on Flickr
The previous owner was using way too big of a spacer so the rubbing was an easy fix. The limp mode was concerning and potentially expensive. But I pulled the codes and narrowed the problem down to a possible bad MAF. Getting to the intake required removal of the passenger headlight and I wasn't quite prepared for the mess the intake was in. I am not sure if the intake or filter were ever checked on.
IMG_0916 by JEllis, on Flickr
IMG_0933 by JEllis, on Flickr
Here you can see where the steel reinforced flex pipe is coming apart. There were multiple holes in the flex pipe. It was also soaked with oil from "blow-by" due to a faulty PCV.
IMG_0930 by JEllis, on Flickr
IMG_0934 by JEllis, on Flickr
IMG_0936 by JEllis, on Flickr
IMG_0937 by JEllis, on Flickr
I purchased some silicone hose, a custom AFE filter and associated hardware and came up with this.
IMG_0940 by JEllis, on Flickr
IMG_0941 by JEllis, on Flickr
IMG_0942 by JEllis, on Flickr
Here you can see everything buttoned up again. The Dinan SC kit is a later version using a Powerdyne unit. Dinan drilled holes in the housing to lower temps in the belt housing to prevent belt slip and ultimately extend SC life.
IMG_0944 by JEllis, on Flickr
I hate the plastic bleeder screws and replaced the original part with a brass part from TMS.
IMG_0943 by JEllis, on Flickr
Old dirty MAF comes out and brand new OE MAF goes in.
IMG_0935 by JEllis, on Flickr
The crumbling wheel well liners played a part in the nasty air filter. New parts ready to go in.
IMG_0931 by JEllis, on Flickr
IMG_0929 by JEllis, on Flickr
Old rusty hardware.
IMG_0932 by JEllis, on Flickr
Front plate comes off. New front plate delete panel waiting to for paint.
IMG_0912 by JEllis, on Flickr
Back on the ground.
IMG_0914 by JEllis, on Flickr
All buttoned up for now.
IMG_0925 by JEllis, on Flickr
The car drives amazing after fixing the brakes, removing the rear spacers and swapping out the MAF and dirty intake and parts. The car pulls hard! The SC has never been rebuilt and I have my doubts its making full boost but it pulls very well. I am in love with this car. More to come.
http://www.m3post.com/forums/signaturepics/sigpic14547_7.gif
Instagram: jellismotorwerks
Appreciate 13
      11-22-2015, 07:29 PM   #2
TomHudson
658
Drives: 2011 E90 M3
You did a great job bringing it back to life!
Beautiful car..
      11-22-2015, 08:20 PM   #3
SilentAttack
SilentAttack's Avatar
163
Drives: 08 E90 Jerez Black 6MT
Awesome job!
Stupid Photobucket
      11-22-2015, 09:32 PM   #4
Raek
Raek's Avatar
Drives: 08 M3, '17 Macan GTS
!!!Beautiful!!!
I did a lot of things to it.
      11-22-2015, 09:38 PM   #5
Hujan
Hujan's Avatar
Drives: M3
Looks good, J! I forgot how terrible that filter looked. Oof!
      11-23-2015, 12:43 AM   #6
STooK
STooK's Avatar
Drives: 2013 E92 M3 ZCP
Wow, I bet the car felt like it was having coronary artery disease and now back to normal. Glad the car fell in the right hands!
2013 BMW E92 ///M3 AW/BLK ZCP CF Roof 6 Speed - Perfection
2011 BMW E90 328i xDrive Space Grey/Black - Daily
2011 BMW E93 ///M3 MW/FR/BLK 6 Speed - Gone but not forgotten
      11-23-2015, 10:21 AM   #7
JEllis
JEllis's Avatar
532
Thanks gents.
Here is a shot of the original owners binder. Every receipt from new. He even kept the thank you cards that were hung from the rear view.
IMG_1870 by JEllis, on Flickr
Appreciate 4
      11-23-2015, 06:54 PM   #8
RobsgottaM3
Roll Tide Roll!
RobsgottaM3's Avatar
Drives: E90/Slick-Top/Single Hump/6MT
Originally Posted by JEllis View Post
Thanks gents.
That is a true gear head! What a great find.
"You should never underestimate the predictability of stupidity."
      11-23-2015, 07:33 PM   #9
Upgrade+
Good life
Upgrade+'s Avatar
130
Drives: 2008 E90 M3 AW
More pics please! One of my personal favs from BMW. What are your plans for this beauty?
Current: 08 E90 M3 Alpine White Former: 11 135i Msport Space Gray -Former: 07 335i Titanium Silver E92- Former: 08 135i Alpine White E82- Past: 06 Subaru STI WRB- Past: 04 Audi S4 Imola yellow- Past:97 Honda prelude Ice blue
      11-24-2015, 12:31 PM   #10
Malek@MRF
Malek@MRF's Avatar
Drives: E92 M3, E46 M3, G82 M4
Great work J! I can't wait to see this beast soon, one of my all time favorite BMW's.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport.
Facebook | Instagram | Yelp! | Flikr
Phone: 949-233-0448 | E-Mail: info@mrfengineering.com
      11-29-2015, 10:58 PM   #11
SneakyDeeky
driver mod in progress
SneakyDeeky's Avatar
Drives: with both feet
2015 VW Golf R  [5.50]
2014 Audi SQ5  [10.00]
Love both of your cars!
      12-08-2015, 01:34 PM   #12
JEllis
JEllis's Avatar
532
Thanks all
      12-08-2015, 02:42 PM   #13
Beedub
United Kingdom
423
Drives: 2007 Z4 M roadster vt2-500
that is seriously sick. what a beauty , that will make you some money one day.
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com
      12-08-2015, 03:19 PM   #14
Patrón
PAZUZU
Patrón's Avatar
Drives: '15 M4
2015 BMW M4  [0.00]
2009 BMW M3  [10.00]
beautiful ride/project.
2009 M3 DCT ESS625+ SOLD
2015 M4 BSM/Silverstone F4LCON
@texasMclub IG @jagemoets
      12-08-2015, 05:16 PM   #15
whats77inaname
Drives: when at all possible
....that never changed the filter....or the MAF....or fixed the rubbing issue....and installed the front pad incorrectly....and never fixed the wheel well liner....
I always liked this car. Glad you found a keeper. I was never aware that Dinan made a s/c'er for it, so I learned something new today
Appreciate 2
      12-08-2015, 11:29 PM   #16
M3sicko
M3sicko's Avatar
Drives: BMW
Awesome ride you got there! And where is the GTR you acquired not too long ago?
      12-09-2015, 12:27 PM   #17
JEllis
JEllis's Avatar
532
You are thinking of someone else. Never acquired a GTR.
      12-09-2015, 12:29 PM   #18
M3sicko
M3sicko's Avatar
Drives: BMW
oops, it's someone else. Just remember after i posted it.
      12-09-2015, 11:56 PM   #19
Flying Ace
Flying Ace's Avatar
4985
Drives: G05 45e, 997.1 & 991.1 GT3s
Only pimps drive these cars. You're a pimp. That's a good thing.
      12-10-2015, 01:33 AM   #20
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Doesn't inspire confidence in seller if pads were in backwards
      12-10-2015, 03:20 AM   #21
djDori_C
djDori_C's Avatar
110
Drives: E93 M3
Good job on bringing her back! Congrats on the new ride
Safe motoring
      12-10-2015, 01:52 PM   #22
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: '18 Frontier Pro-4X, '06 Z4MR
Awesome car, cannot wait to see more!
-Matt
| Z4M Build Thread | @violetnites | flickr |
