11-17-2020, 05:05 AM | #23 |
PdV Motorsports
121
Rep 165
Drives: 2014 335i xDrive sedan
Was looking for a used set but at this point I'll pull the trigger on new parts once I see there is/isn't a cyber Monday deal.
Ryan M. PdVMotorsports.com Owner https://www.youtube.com/@pdvmotorsports
2014 EB M-Sport 335i xDrive - PdV/BC custom coilovers, PdV spherical rear shock mounts, PdV big brake kit, MHD Stage 2+ Next up: PdV genuine GTX3582R Gen2 turbo kit, Nostrum HPFP & Stage 2 injectors, PdV PM5 w/ "Veyron" Bosch E5LM |
11-18-2020, 01:24 AM | #25 |
521
Rep 1,288
Drives: 2015 335i xdrive Msport Mbrake
flatoutsuspension.net sells individual parts...
11-18-2020, 11:28 AM | #26 |
Modder of everything I own
147
Rep 491
Sweet!!! Sub'd
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
11-28-2020, 02:15 AM | #29 |
PdV Motorsports
121
Rep 165
Alright game on. Looks like BC doesn't like doing sales so I'll start ordering parts for one front and one rear today to kick off final design and custom component ordering.
No spring thoughts yet. Day job stuff has had me 60-120hrs/wk since Aug. so I haven't given any thought to anything else. I'll start making a new spreadsheet for my car and probably make some comparisons through wheel frequencies to what I liked on my vette and what some forum sleuthing says is good for a 90/10 daily/track type driver. It's a tuning process anyway, I'll have 2-3 sets on hand to start.
pauli18c211.00 |
11-28-2020, 05:18 AM | #30 |
115
Rep 1,004
still going with the BC dampers? i remember Anze used to use bilsteins to start out, he rebuilt a set of my AST, he was/did deal with penske. that was in like 2016. i know its a pretty small world for companies that actually rebuild the dampers. are you saying you are building 2-3 sets to sell or just for R&D purposes? i just picked up a 340 so i am on the hunt for a set of coilovers. being winter here in the northeast has me in no rush. i was strongly considering ohlins but seems like they are pulling their f30 kit to rework them to make them work with the new Z4, or at least that was what i was told by an insider.
11-28-2020, 05:39 AM | #31 |
PdV Motorsports
121
Rep 165
Yeah still starting with BC's cause they're cheap and rebuildable and I am capable of polishing a turd when it comes to dampers.
I supported Anze a little when I was with Penske. I'm basically doing what he's done by mixing my own parts and others. I meant 2-3 sets of springs to test different rates.
12-09-2020, 06:50 PM | #32 |
PdV Motorsports
121
Rep 165
Joy
Need a new vice, build table, shim kit, kick ass shock oil, and some custom tooling. Based on my convo with BC, I'll be the only one in the world running digressive pistons on their BR series coilovers. Not sure why they designed the pistons to only fit gigantic 53mm bores but the 46mm bore in the BR series does not create a shim reliability or flow issue. First thing is to get these measured up and then installed to start evaluating what they provide out of the box while parts are being designed/ordered.
pauli18c211.00 |
12-16-2020, 08:52 PM | #33 |
115
Rep 1,004
any thoughts of spring lengths, im going 7 in front and probably 9 in the rear. seriously considering mcs 1 ways, my friend is a dealer and trying to figure out his dealer pricing. Hugh at hi speed motors in CT. where did you used to work?
12-16-2020, 10:31 PM | #34 | |
4024
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
You'll also need to determine when your bump stop engages too to prevent bottoming out (either the damper or main spring going into full bind).
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
12-17-2020, 05:06 AM | #36 |
PdV Motorsports
121
Rep 165
No not yet, trying to survive the end of year push at my day job. Currently at a startup designing active suspension for OEMs. Used to work at Penske Racing Shocks.
12-18-2020, 06:35 AM | #37 |
PdV Motorsports
121
Rep 165
Looks like I'm bringing back the old vlog! Started documenting my progress on the turd polishing project. Rear damper model is 75% done. Just need to take it apart to measure the shaft bearing and sealing cap on the other end of the main tube. The main piston and floating piston are basically done and already out for quote. On to the fronts tomorrow.
12-18-2020, 07:34 AM | #38 | |
112
Rep 216
Pics of the progress? |
01-25-2021, 05:19 AM | #39 |
PdV Motorsports
121
Rep 165
I have CAD of both front and rear dampers now but most of the progress is in the detail drawings for part ordering. Not stuff I want to post online. Now that I have rear CAD though I'm thinking about the cheapest way to invert the damper.
04-18-2021, 06:09 AM | #41 |
PdV Motorsports
121
Rep 165
No progress. I hired a contractor to help guide me on my custom wheel FEA which obviously takes priority. Along with that are my floating rotors for the custom Wildwood BBK. So dampers fell to 3rd place for a bit but I'm almost done.
04-19-2021, 06:03 AM | #44 |
PdV Motorsports
121
Rep 165
Thanks
