06-10-2022, 01:58 PM | #111 |
5260
Rep 10,638
If you want the warranty, it’s only available for the 91 octane tune because as Dinan has explained in this thread, it has no idea what octane you will actually put in the tank.
ScottsG80M315.00 Dinan_Engineering3916.50 |
10-11-2022, 12:26 PM | #112 |
146
Rep 279
Drives: F90 M5
Has anyone purchased the E85 tune for $800 for F90 M5 yet?
10-15-2022, 04:30 PM | #114 |
5260
Rep 10,638
As Dinan wrote on the previous page:
Currently switching back and forth between octane maps would require a trip to a dealer to get reflashed. Not ideal by any means. Work is ongoing on getting a DIY option available. The E85 tune has an operating range of E60-E85 so pump variability will be of little to no concern. |
10-15-2022, 05:26 PM | #115 | |
28
Rep 43
10-15-2022, 07:43 PM | #116 |
5260
Rep 10,638
Is E50 less than the operating range of E60-E85?
Griffin33746.50 afo818259.00 |
10-15-2022, 09:35 PM | #117 |
146
Rep 279
Drives: F90 M5
You should be fine in an emergency. According to E85 calculator you can have up to 6 gallons of 91 gas make it E60 total in the tank. I talked to Dinan rep and he said our tanks can have all E85 no problem with their tune, as low as E60. It seems like noone with M5 has tried this particular tune.
10-17-2022, 07:35 AM | #118 | ||
3917
Rep 3,130
epicaccord146.00 |
10-17-2022, 10:37 AM | #119 | |
146
Rep 279
Drives: F90 M5
10-17-2022, 01:08 PM | #120 |
3917
Rep 3,130
Yes, the E85 tune/fueling on an otherwise stock car is perfectly fine. As far as how -- some callibration/software magic is about the depth of my knowledge on the topic. Ultimately the stock fuel system has enough bandwidth/capability to be tweaked through software and allow necessary flow to support ethanol.
epicaccord146.00 |
10-17-2022, 05:55 PM | #121 | |||
28
Rep 43
Logistics question; so I get my car tuned for e85 at a local dealer. I have 91 in the tank and need to drive to get e85 how do you recommend I handle that? Or could I fuel up with E85 without the tune and drive to the dealer? thanks |
epicaccord146.00 |
10-17-2022, 06:24 PM | #122 |
5260
Rep 10,638
Run a blend of E30-E40, which the stock tune can handle, in half a tank of gas. Drive mildly after flashing to the gas station and fill up with E85.
epicaccord146.00 RoseyLA28.00 |
10-18-2022, 11:09 PM | #123 | |
146
Rep 279
Drives: F90 M5
10-19-2022, 08:46 AM | #125 | |
3917
Rep 3,130
If they were different however the tune would need to be altered and the sensor table rescaled so that reporting was correct and everything jived. |
10-19-2022, 04:40 PM | #126 |
30
Rep 67
Are you talking the MAP's at the Intake or at the Inlet manifold.
They are different. The ones at the inlet manifold are 2.5 bar. Carbahn's stage 3 tune changes these. See this post for the location - part 9. https://f10.m5post.com/forums/showpo...9&postcount=18 (yes its an F10, but same same). |
epicaccord146.00 |
10-19-2022, 05:20 PM | #127 |
5260
Rep 10,638
I saw a couple that were 3.5 bar but did not look for more. Now you have made me curious so I will look for the others and apologize for the incorrect statement.
I just did a little research and apparently F10 M5 BM3 tunes had an option for 3.5 bar pre-intercooler map sensors. They could give better resolution than scaling the 2.5 bar. I will look at my F90 M5 BM3 tune to see if it has the same option and, if so, consider picking up a set of 3.5 bar for the pre-IC. It looks the the existing 3.5 bar sensors are the post-IC. Last edited by pbonsalb; 10-19-2022 at 07:39 PM.. |
10-19-2022, 05:49 PM | #128 | |
30
Rep 67
And the tune 100% needs to be scaled for it. |
10-19-2022, 07:54 PM | #129 |
5260
Rep 10,638
If the option is there with BM3, I will look further into the benefits. Selecting the option would change the scale. The option appears to be there, in the 4th from last screenshot in this link:
https://www.protuningfreaks.com/prod...mw-f90-m5-tune I just took a quick look under the hood and these other map sensors must be buried pretty far down. Do you have any pictures of their location? The 3.5 bar sensors are pretty cheap at about $65 each but it might take me some time. No DIY are popping up. I think they are sort of at the front corners of the intake manifolds but am not sure. Not a priority so this might wait until I have to get in there for something else. This is the best I have found for a DIY and it is for the F10, but likely pretty similar: https://f10.m5post.com/forums/showthread.php?t=1324228 Last edited by pbonsalb; 10-20-2022 at 07:04 AM.. |
